Originally Posted by
sherr127
hey big marcelo,thanks for the suggestion..
are you saying that gx300 sounds better than pl300?can you describe more?
the PL300 requires a lot of room and nice amp to sound its best ...
with my room limitations (about 10m x 5-6m ) I didn't think my room was big enough for the PL, and the PL needs a lot of space behind it also.... the GX is like a mini-PL ....
if I thought the differnce of the G and PL was large, I would have bought the PL ... and probably waited a little longer to buy the Sub.. I had a good price on the PL300... but with my set up, and my environment I thought the GX300 would be a better fit ...
ie: I would have needed to upgrade my amp from Cayin 88 to something larger, and needed to upgrade from Linn Akurate to Linn Climax (another $10k upgrade just for that) ...
what I am aiming for is 'balance' .. no point having one component much better than the other, or not suitable for the location .... I do prefer the looks of the PL300 ... I was also not sure how the leather face of the PL300 would whistand the humid and hot environment here in Singapore.... I don't think there has been any issues with owners.. but ...
another point I took into consideration was the fact that the existing PL range is about 5 years old or so ... a lot of the PL technology has trickled down to the GX range making it a great value for money buy .... now, if/when they release an update to the PL range... would be a different story...
if you have the room (specially a dedicated audio room) ... definitely go for the PL300 ....
