Originally Posted by dryden3
Thanks for your advice. I couldn't find a setting in the "home" menu for DST, but I did find one for "factory set" which appeared to reset everything to factory original condition. I did this, set the time/date manually, and let it go through the auto channel set. I hope it stays working from here on out.
DST or Summer Time setting is usually associated with the clock/date/time setting, and it really needs to be set off, assuming there's a setting in the first place. Too bad you couldn't find something.
