Originally Posted by tsonka
Question
When building a set up I feel that it is generally best to use all speakers from the same series. I have a question about Klipsch's naming
It would seem logical that the RF-62II, RC-62II and RS-62II would all go together due to thier naming.
However if you look at spec, which I did when I bought my RC-52II to go with my RF-62II the RF-62II reccomended power does not match the other 62's
I would think that you would want all speakers to have the same reccomended power rating? That was my reasoning for purchasing the RC-52 over the RC-62, so they would match electronically
The RF-62II has the following spec -- 125W RMS / 500W Peak
The rest of the 62's line has ---- 150W RMS / 600W Peak
Question
Here is what Klipsch calls the RF-62II Home Theater: http://www.klipsch.com/na-en/product...ii-1-overview/
Fwiw, that's not much of a difference and I had a situation where my RF-3 speakers had a different rating on them than their published specs and when I asked Amy at Klipsch she said there was a mistake on the labels that were put on some of the speakers.
Good Luck.
