AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 373
post #11161 of 22394
Originally Posted by indybrian View Post
Quick question for any RS-62 II owners.
I am trying to place my Seymour screen this weekend but my speakers are not here yet. I do not want the bottom of the frame to block the speakers. The Klipcsch website has the overall height of the speaker, but I am looking for the height to the center of each tweeter.
Can anyone break out a tape measure and check for me? Thanks.
probably a typo.. but RS62 are surrounds.. how on earth would they be blocking the screen..where are you trying to use them ?
post #11162 of 22394
kk20, I've had extensive conversation, regarding your question,on the phone directly with a Klipsch consultant. He caught wind of my delima through a local store I called. I got a phone call saying, "this is Ken in Hope, Ark". I was very impressed at their concern. He spent an hour on the phone with me jawing back and forth.
Anyway, he directed me to the RS62II in that application. My only option as I saw it was to use the KL or KS in walls. He said that without question the RS62II would be a better performer in the system. I'm now using the RS62II in an otherwise Heritage system, and it works seamlessly. I'm very pleased. I can't speak for the RS42 however.
From my personal experience and that phone call, I'm convinced that in wall solutions serve a particular purpose, and you pay a price for that purpose in performance.
As spdntrxi noted, my side surround problem is a speaker height issue. My options are:
KS-7502 in ceiling
RS-42II
RS-7 (older model, still available at some stores)
SS-1 (older, ebay ??)
Another idea I had was using a monopole like the KL-7800 and mount it on it's side. I know dipoles are usually preferred, however, I've read a few forums that monopoles on their side can often work well.
Also keep in mind that the side surrounds are only 2" from my 10' high ceiling, one directly above a window, the other mounted on the side of a beam (for the KL-7800, I'd make a frame and surface mount it.
post #11163 of 22394
KS-7502 in ceiling
RS-42II
Fwiw, The RS-7s were discontinued in 2006 so I doubt there are any stores selling them new, but it would be between them and the KS-7502. I have no experience with in-walls, but the RS-7s are 5 dB more efficient. The other two are bottom-of-the-line models which probably wouldn't do the other speakers in your HT justice.
post #11164 of 22394
I agree... in ceilings or RS7's.. forget the bottom 2... as for turning a KL/KS-7800 on the side..not so sure about that one...think I'd rather get RS7 then do that.
post #11165 of 22394
Oops, yet meant the RF 62 II. Would be a very noob move to put the surrounds behind the screen.
I also edited my original post.
I do not think it can be avoided now that I have been measuring like crazy. I guess I will have to build some sort of stand to set them on. Any suggestions on construction methods?
post #11166 of 22394
Hi all,
Shopping for front speakers and considering the RF-52's. I see Klipsch now has RF-52 II. Since a better deal can probably be gotten on the RF-52 is there much of a difference between the two to make it worth considering the RF-52 II? I do like how those news one look but I'm not sure that is a good enough excuse alone.
Also, the VF-35 have a slightly higher retail price than the RF-52 so is there a big improvement there? The VF-35 sounded good at Best Buy playing movies, but they are slightly bigger than I'd like, which is a reason I like the RF-52 to begin with. Is there a reason I should reconsider? Are the VF-35's better speakers?
post #11167 of 22394
Originally Posted by Hurricane434 View Post
Hi all,
HI ALL. Well BB is good for everyone. But if your picky about this and that for sound and you want to stay with us= KLIPSCH; then you need to check out the reference series. The new line is has been re engineered to be cost effective for them. An hopefully they put more quality assurance for components. I am very happy with what I have and the next week I am moving and tweaking the system.
post #11168 of 22394
Originally Posted by ILOVEMYHDTV View Post
HI ALL. Well BB is good for everyone. But if your picky about this and that for sound and you want to stay with us= KLIPSCH....
Fwiw, the VF-35 is a Klipsch speaker. http://www.klipsch.com/na-en/products/vf-35-overview/
post #11169 of 22394
HI ALL. Yes i know. It is just that there SOOOOO much to pick from. Picky is as picky is.... but if you picky your nose then ..... your a picking your nose.....
post #11170 of 22394
Quick question for any RF-62 II owners.
19" from the floor to the bottom of the lower woofer without using spikes.
post #11171 of 22394
Thanks! Looks like I am going to set them on some cinder blocks. No one will ever know since they are behind the screen.
post #11172 of 22394
How high is your screen. I have a Seymour screen and the RF-62 II and my speakers are not blocked.
post #11173 of 22394
The bottom of my DIY aluminum frame is 23" to 26". The velvet covered frame to hide it will be 21" to 26". There is a picture in me build thread. I had to raise the screen a little more than standard since my riser for my second row is only 6" high.
post #11174 of 22394
Hurricane434 -- The VF series (and the WF) is made for sale in "big box" stores and is a cheaper speaker with a higher mark-up (so that the B&M stores can make more profit). Stick with the older reference series designs, either the RF-52 or the RF-52 II. Personally I would prefer the R-52s, as I believe that they are slightly higher quality speakers than the new version II models. Since they are being closed out (replaced by the 52 IIs), you should be able to get a better price on them, if you ask.
Several months ago, I bought a pair of RB-81s and a pair of RS-62s for a very significant discount. AFIK, those models are no longer available. I had purchased a RC-62 center channel speaker last year (and wanted to make sure that I got a sonic match, so I jumped on the purchase).
post #11175 of 22394
Another recommendation for the reference series line here.. Like what CT_Wiebe mentioned, the new reference II's are making their way into the market so the now "older I" line can be had at clearance prices.
I don't want to insult others but in my journey to find speakers I looked at the VF and the WF series. I didn't like them, they looked and sounded like something you get at a toy shop and when compared to the reference series..well.. there really can't be a fair comparison. IMO the reference series are at another level of build and audio quality.
post #11176 of 22394
Repeating the "I don't want to insult others but...."
What I find kind of funny is the above comment, you finding the VF and WF series as something you get at a toy shop when compared to the RF series.
Then, you hear the Heritage series and feel the RF's are something you get at a toy shop.
Then, you hear the commercial lineup and feel the Heritage are something you get at a toy shop.
I own some LaScalas and used to own Khorns so I'm not bashing anything, just smiling at the initial comment.
It is however, true that the larger you go, the better it gets.
post #11177 of 22394
Yep... it's a totem pole of sound out there and if you have the money there will always be something bigger and better. I still think, for the money they can be had at, the reference series I's are a great way out of the big box store speakers and into a new world of sound and build quality.
post #11178 of 22394
Here are my thoughts:
....For most people it seems that the THX ultra IIs are the smallest footprint to compete with this set up that would not need that requirement for TOP Quality sound....That being said for 2 Channel sound the RF-7's footprint IS where Size v Sound capability in a horn/woofer config seems optimal if space is a concern. {Edit: with the next improvement in sound being either the Cornwall or LaScala which requires at least twice the Floorspace.} My 2 cents.
I agree that the upper end Heritage sound nice (I am not a fan of the Heresy), but their larger footprint and cost along with not being able to hear them at a local dealer unfortunately is going to make them a collectors item with a limited market in the age of Home Theater.
post #11179 of 22394
I've always felt the Khorn was the most space efficient. They are FAR less "room intrusive" than my LaScalas or Interface D's. I'd contend they'd be far less intrusive than RF's, VF's or most others....even HPM 100's or Mach ones and the like. Then you get to the Jubilee which has the same footprint.... oh, yes....visually, they (Khorns/Jubilee's) are behemoths..... but.... for actually intruding into the room, they are nice & tidy!
post #11180 of 22394
I have always said this as well. I find it funny when people say that my Klipschorns are way too big, but then turn around and say that their bookshelf speaker has to be on a stand 3 feet away from any wall! That would get knocked down by the kids at my house!
post #11181 of 22394
Well said! I guess the opposing force's only argument for Klipschorns is that you must have two adjacent corners. Unless you are willing to put the effort forth for the construction of "false corners" as per the Klipschorn user's Manual. [found on the klipsch.com website]
post #11182 of 22394
I haven't considered Khorns because of room setup. My understanding is that in my 18x32' space with a seating distance of 19', that I would not be in position for the best imaging. Is that correct?
Not that the LaScalas are leaving me wanting for anything, but I would like to own Khorns just because....
post #11183 of 22394
Is the sound quality gap between false corners and actual corner placement great? Indistinguishable?
post #11184 of 22394
My Jubilee's are about 16' apart. Room length is (guessing) 25/29 feet BUT, only has three walls, opening up opposite the speakers to a dining room and foyer on the other side. So it's quite open.
I'd love to have your space!
I would however, strongly suggest prior to you ever buying Khorns....get your hiney over to Knoxville and hear the Jubilee's. I know a couple guys locally that have Khorns. We can dash to their house and do a quasi side by side or, you can listen to my stock LaScalas as a Khorn stand in. (essentially, listening to the midrange which is the same)
I had the Jubilee's for maybe 1 1/2 years before I went back over to this guy's house. He cranked his Khorns up to appropriate "omg can you believe this" levels.... and for the first time ever, I finally understood what some people mean when they say the sound gets congested. Granted, this was barking pretty hard at us and the room was untreated so it might not be all the Khorns fault BUT.... I know I've had my Jubilee's hitting harder than that and had nowhere near that congested sound.
It was an interesting moment/revelation for me. One that I've kept pretty quiet about and did not discuss with him.
post #11185 of 22394
I've never heard false corners so I can't comment. I will mention that the 60th Anniversary comes with an enclosed back. Others have enclosed their backs. The Jubilee not only has an enclosed back BUT, is redirected back out towards the front (much like a LaScala).
Regarding the Jubilee, I was told by Klipsch that they can be around 10" removed from the corners and still keep their extension. Evidently, anything beyond 10" starts to chip away at their bottom end.
I would speculate Khorns with enclosed backs (or false corners) would garner you some of this flexiblity of placement though, only to a degree?
post #11186 of 22394
I'll add that you can count the amount of jubilee users on your fingers and toes. Finding a used pair would be a hopeless search, since I gather most would hold them until the grave. One can find Klipschorns in larger circulation thru craigslist, Klipsch.com forums, and yes eBay. I got mine for well under 2K and the guy had custom re-veneered them in Zebra wood..
New Klipschorns are great, just cost a good amount. The alternative is to "roll your own" with the Jubilee by contacting Klipsch directly. I gather you'd save a little but gain a good amount in sound.. and Coytee might be able to elaborate on the setup and config.
I haven't heard false corners either, but I think that falls into the last 5% of sound quality.. which is worth it to most but not to many ;-)
post #11187 of 22394
Yep... and you can bet that every one of those toes are curled!
100% hopeless
Sweet! I'll bet those are stunning!
I don't know what you mean by 'roll his own'. Asthetics aside, the Jubilee is fully engineered and ready to plug/play. For a small upcharge, the front panel can be had in Walnut (same as in the Khorns). Hard to hide that top horn though . There is no guesswork on the Jubilee's (and I realize he's made no reference to having an interest in them, this is for any other casual readers benefit). Roy Delgado at Klipsch has taken PWK's last project and put it together in two formats. One which most have used, using the large....ok, freaking huge K402 horn on top and the other with the much smaller K510. The K510 COULD be put into a tophat much like a Khorn if someone wanted to build a top like that. I personally think that would look very nice. You could bury a passive in there like the Khorn or stay with the active crossover. If someone ever contemplates buying a NEW pair of Khorns then consideration of the Jubilee is at minimum a no-brainer. It will cost less and sound better (period). If they are debating a used pair of Khorns then obviously, the entire cost equation changes.
post #11188 of 22394
Ya know, I have to think Klipsch doesn't sell many new Khorns anymore given their cost and availability in the used market, not to mention inavailability to audition at a dealer...
post #11189 of 22394
Anyone compare the Klipsch RF-7 II to the Cerwin Vega XLS-215?
http://www.cerwinvega.com/home-audio...s/xls-215.html
post #11190 of 22394
Zen, From my phone call with the fella in Hope, he said that the US market is very weak for Heritage products, but the European market is greater than they can keep up with!
  Back to Forum: Speakers
