Originally Posted by Jetson23
Hello Klipsch owners. I recently started this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1316819
talking about putting together a 5.1 system. I've already purchased a Denon AVR-591 and two Klipsch F-20 for the front speakers. Specs are here:
http://www.klipsch.com/na-en/product...pecifications/
Room is fairly small, 15x13.
I would like recommendations for the sub and rear speakers. It does NOT have to be Klipsch, I've been told I can get better value for an entry level system elsewhere.
Also, I was told in my thread linked above that I should stick with the matching C-20 center speaker, as the center and fronts should match. So, unless I hear otherwise, I plan on doing that as well.
As far as my budget, I don't want to say it's not an issue, other than I want to spend what is consistent with an entry level system, basically what is consistent with what I need to go with the items I've already purchased, and price points near the same range.
Thanks in advance for any help.
OK, I just wanted to follow up on this post I made a few pages back.
As per the recommendations from several of you, I went with the C-20 center to go with my F-20s, so that my center and fronts match up, both brand and line. I also went with the HSU STF-1 sub. I know some recommended the STF-2, but I honestly don't think I'm going to need the step up, again, I'm a noob at this, I just want a good entry level system. At an entry level price.
So all that stuff is a done deal, and I'm pretty much good to go, for now.
But on to the surrounds. Most of you did recommend just getting the S-20s.
http://www.amazon.com/Klipsch-Synerg...8570770&sr=1-1
Specifications
Power Handling: 100 W RMS / 400 W Peak
Impedance: 8 ohms compatible
Frequency Response: 83 Hz - 23 KHz
High Frequency Drivers: Dual 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
Low Frequency Drivers: 5.25" (13.3cm), IMG woofer
Sensitivity: 91 dB @ 2.83V / 1m
Inputs: Single binding posts
Dimensions HxWxD (inches): 6.85 x 14.3 x 5.5
Dimensions HxWxD (cm): 17.4 x 36.3 x 13.9
Weight: 7 lbs (3.2 kg)
Finish: Black Ash vinyl
Or maybe looking for s-2s to save money. Didn't really have any luck on that, not many S-2s, and they're always expensive. But what about S-10s:
http://www.amazon.com/Klipsch-Synerg...=3IBSCBKVAAB8O
Specifications
Power Handling: 50 W RMS / 200 W Peak
Frequency Response: 95 Hz - 23 KHz
High Frequency Drivers: Dual .75" (1.9cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
Low Frequency Drivers: 4" (10.2cm), IMG woofer
Sensitivity: 89dB @ 2.83V / 1m
Crossover Point: 2800 Hz
Dimensions HxWxD (inches): 5.6 x 11.8 x 4.6
Dimensions HxWxD (cm): 14.2 x 30 x 11.7
Weight: 5 lbs (2.3 kg)
What I want to know is, am I going to be able to tell the difference? Or maybe just "are the S-10s good enough?" Again, remember, I'm a noob. I'm coming from TV speakers. For $330, I'm adding surround to my system. From what I've been told, here and elsewhere, that's probably the least imporant part to a good home theater. So for the extra $150 for the S-20s, what am I "really" getting? Am I going to think the S-10s suck?
I'm almost done, this board has been a great help. I just want an actual reason I can understand to spend that extra $150. What will it buy me?
