Originally Posted by Mupi
RF82 uses 2 8" drivers so it isn't a proper match for neither the RC52 or RC62, technically speaking. Both RC52 and 62 use the same tweeter. The main difference is in the slight extension in the lower range on the RC62 which isn't a big advantage at all. The conversions do not go below some 400Hz unless it is Barry White! So RC62 has no real advantage over RC52.
The guy does not have a sub. That is why I made the suggestion of using BOTH option. So for him sending the LFE to the fronts is the best option. He lives in an apt. So sub is just unnecessary when the fronts can go down to the 30's. Even if he moves out to a house and adds a sub later, there is no need for RC62. Sensitivity of RC52 is rated as 96db which is plenty to drive using his Yamaha AVR.
Just save the money on the RC52 II and set the fronts as LARGE and sub out as BOTH on the Yamaha AVR. You will be fine.
The rc-52 vs the rc-62 isn't even close. the rc-62 is a HUGE upgrade.
so I have been Rocking my small Den for years.
) Only a handful here seem to be into the Heritage line, most seem to be in the Reference or something like that?
