Originally Posted by Reference_head
Really you can't see the bass response of all the speakers with the Antimode 8033? With the sms-1 I can see all the speakers because it hooks up 2 ways. It runs rca to your avr for video (to your tv) and audio. Then separate out puts to the subs. The sweep runs though both outputs so if I shut my subs off I can see how the other speakers perform. This is key so when you run everything you can adjust the subs to the room, and how they work with the other speakers. Because depending on what you use for a crossover point there is always overlapping between the other speakers and the subs. I can't use it to adjust the bass to the other speakers but can see it on the screen. And adjust the subs accordingly. Amazing tool
http://www.blu-ray.com/community/gal...Reference_head
With Antimode 8033 you cant see anything, including the sub.
I didnt know that SMS-1 will allow me to see the response of other speakers. Basically it will let me run the sweep and see the curve instead of me me having to use a laptop and use REW (Room EQ Wizard)? That would alone be be a good reason to get it. But at $498? May be not. I may get a laptop and use REW as I can use the laptop for lot of other things. With a laptop and REW, the measurement is automated.
My only issue with SMS-1 is that it only has offers 8 filters. Are these 8 only for manual parametric EQ or it uses only 8 filters for automatic sub correction also. Are 8 filters good enough? I have used BFD 1124p with 12 filters and I could not get a flat curve using 12 filters. I had to use The FBQ2496 which has 20 filters. But the manual measuring of the response was painful. So I gave up BFD and got the Antimode 8033. Unfortunately with Antimode I would still have to do the manual measurement but at least the correction is automatic and does a better job than BFD 1124p or FBQ2406, I presume.
I will wait for the Audyssey XT32 gear prices to drop :-)
I have my Pop's old 1979 Cornwall I (new Crires C/O) and my 1989 Heresey II try them for front and rear for HT Blurays and a Klipsch center speaker or one more Heresey and a sub. I use a RC64II for my center and two used Klipsch Synergy Sub12 300/650 Bash in a smaller 12X14 or so den.......Shakes the room with just a Yamaha HD AVR RX-V1900 130x7
