So I guess I'm asking would you say there are better subs for the buck if I can can the RC-52 II center the RW-12d sub combined for $500 to the door? I've looked at Hsu, eD, and SVS prices man those are in a totally higher budget space.
I got a Yamaha 671 AVR for good deal then a set of new Klipsch Quintet SL's for $76.20 brand new at shell shocker price. My plan is upgrade center quintet to RC-52 II, newegg has it for $349 w/ $150 promo gift card. The $150 promo card slap down on newegg dicounted $349 Klipsch sub.RW-12d. Replace an old infinity 750 sub that was part of a set. Eventually migrate 2 other front quintets to presence speakers, add some proper R/L front floor standing. Nothing will go to waste.
Right now, I can get the RC-52 center + RW-12 sub to the door $500 combined seems pretty tempting. Combine w/ $76.20 quintets, it should be awesome. I've compared the specs of the quintets to the RC-52 II and it's the same components, slightly smaller sizes by .25 inches. Same Klipsch design. And the RW-12 has IR commands that will work with Harmony One.
Would you say I could do better given this mid-range solution and so far I'm very happy with the Quintets as is - just wanna punch it up a bit more.
