AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 587
post #17581 of 22400
agreed
post #17582 of 22400
Originally Posted by psgcdn View Post
Having had first a pair of La Scala and then KHorns in their place, I'll say that the KHorn sounds different than a La Scala augmented by a sub. The upper bass is better to my ears on the KHorn and makes for a fuller sound and more upper bass slam. Might not be worth double the price to everybody, and you need the room and the wide spacing. The KHorn combined with a loaded-loaded sub is awesome!
I listen to a Khorn theater often enough, and I'll agree with you. I haven't heard CornScalas, but likely the same is true. Between the three options I bet other variables are more deciding than the speakers themselves.
post #17583 of 22400
I would love to hear cornscalas.
post #17584 of 22400
Ya know yer not That Far from AR ...
I would @ least drive over & hear them before you drop a wad on any new RF7II's , if you are thinking about an upgrade
Best part, knowing your skill set on wood working you could have any finish you wanted .
post #17585 of 22400
Nezff you are looking at getting RF7ii?
post #17586 of 22400
Yeah, depends on where in Arkansas
I thought about it a while back. I might be doing something custom before the years end.
post #17587 of 22400
Ah ok. Well if you would like some ill sell you mine and the 64ii. I'm 90% about to go cornscala the other 10% will be decided when I go listen to them
post #17588 of 22400
Bob Crites is in Russellville AR & I know he does welcome test listening ,in his shop
Pm if you want his phone # ,
Me I'm in the SF bay area, 20 minutes north of the Golden Gate Bridge
post #17589 of 22400
One of the reasons I didnt got that route was because with custom, you can get more for your money. I already have a drawing of what they will look like.
The other reason was because the new center wont fit in my stand. it is wider.
post #17590 of 22400
I gotta go through texarkana to get there. lol
Its about 6.5 hours to there.
post #17591 of 22400
Hell if you actually want to go ill ride with you. I'm going after Christmas.
post #17592 of 22400
when you plan on taking the trip
post #17593 of 22400
I had that problem as well best part of the CS.1's is you can tweak the size of the cabinet to fit as I did (as long as the cubic volume stays the same ),when I build my 1st CS-1 center
the CS-1 & CS-1.5's make a great center for Cornscala's (the 15" woofer is not needed for a center channel )
post #17594 of 22400
I don't know. I emailed him. Going to see what he has in his shop to listen to.
post #17595 of 22400
where is your build thread at klipsch. I was looking for it.
post #17596 of 22400
Originally Posted by AtDaBeach View Post
hell, I thought the RC-62 II was just like the RC-62 I, in the way one driver was assigned part of the range and the other driver handled the rest. Just read today that was not the case.
I saw where you read that, I have never heard that before.
Might want to call Klipsch and ask them.
Id be curious to hear the "why". Not sure if they would come off the beans though.
Which is the "why"?
Why 62II is different, or why the crossover for the woofers?
I wasn't aware they changed it between the 62 and 62II.
They aren't really set up for one driver to handle part of the range and the other driver the rest. One driver is filtered above around 1150Hz so that only the other driver is outputing. Below this, both contribute equally. They had found that above about 1150Hz up to the horn crossover, off-axis response suffered because both drivers were cancelling each-other. With only 1 driver above 1150Hz, they eliminated this phase cancellation. Play a test tone and put your forehead in the horn. You'll only hear sound from one side.
I don't know specifically how they eliminated the problem with the 62II to not require the filter on one driver. I guess the "enhanced" crossover design at 1500 instead of 16-something somehow fixed it.
post #17597 of 22400
here
http://community.klipsch.com/forums/t/145812.aspx
post #17598 of 22400
post #17599 of 22400
after hearing them you would sell your RF7II's ... they are that good !
best part is the price if you can build the cabinets it's cheaper than a set of RF7II . Bob will make the motor boards (the front of the speakers) with the holes for the drivers already cut out by CNC router for you
So you're saying that if you heard speakers that sounded better than yours you would sell yours? (lol) Sorry that doesn't make sense slappy. My friend bought a new car and it's very nice. But I'm not selling my car anytime soon just because I drove his and its better than mine.
You had to know I was going to say something to that.
post #17600 of 22400
No kidding..you know, there are better speakers than Klipsch....so I guess once you hear them, you'll be asking for a second mortgage on your home!
post #17601 of 22400
gotta know your limits.
post #17602 of 22400
I like oranges better than apples ? L O L ......
Yeah Nezff is right know your limits , I'm Just happy I can do woodwork as it has expanded my limits .
post #17603 of 22400
that wasnt directed at you mike.
post #17604 of 22400
I know that !
post #17605 of 22400
Really impressed so far with the rf82ii and rc62II combo.
post #17606 of 22400
to be honest, when I moved from the RC62 to the RC64, I didnt notice a HUGE difference. It was there, just subtle.
post #17607 of 22400
Really??? Man I did!
post #17608 of 22400
I'm real impressed with the RC62. It just seems bigger than it is, and it hangs in there well.
post #17609 of 22400
Like I said, there was a difference, but not night and day with normal listening.
post #17610 of 22400
At some point the increase is bound to be small jumps. Now going from a procenter 2000 to the 62, huge.
  Back to Forum: Speakers
