Originally Posted by derekisdman
Another question...How important is it to have surround sound speakers for your surround sounds speakers? For example, if I had the RB-61's as my two fronts, and the RC-52 as my center, would it be essential to have the RS-42 as the rear speakers, or would using the RB-51's work just as well? I can get them for cheaper than the RS, so if there would not be much difference, I figure I should just go with the standard bookshelfs.
When used strictly for home theater, the surrounds typically only carry ambience and some special effects, so you can get by with less expensive, though still voice matched speakers.
However, if you also use the system for multi-channel music playback, you would be happier in the long run to invest in better surrounds.
