AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 621
post #18601 of 22807
Originally Posted by MCF34 View Post
Thanks. Any good suggestions for in ceiling speakers that would go well with the RB-25 left and right and center channel?
And actually my left and right channels are in built-ins that are about 6' from the ground and my center channel is on a floating shelf below the plasma and that shelf is about 5' high. Lastly my SV Sub (2x12" subs) is located in the back left corner of the room (u can see the cherry enclosure in one of the pics in post above). Looks like my system is pretty much screwed up all around.
You could look at the Klipsch ceiling speakers such as this one. http://www.klipsch.com/CDT-5800-C-II the driver and the tweeter can be aimed. Give us a shout if we can help you.
post #18602 of 22807
We are proud to announce that AVS is now an Internet Direct Klipsch dealer. We are excited and proud to carry this new line. Clean reference levels are easily achieved using Klipsch's horn loaded technology. For those with interest and questions regarding these speakers, please contact us.
post #18603 of 22807
Originally Posted by DualEdge View Post
Hey guys,
I'm looking to get some feedback on some upgrades I'm in the process of doing. I recently picked up a Yamaha RX-A2010 and decided at that time to make a few upgrades to my HT. Right now, I currently have the 1st gen Reference 52 lineup (RC-52, RF-52, RS-52). While doing some in-store research on a good sub to supplement my Klipsch RPW-10D, I accidentally found a great deal on the RC-64 ii Center speaker from my local electronics store. So I had them order me one as they were out of stock. While I was there, I happened to get a quick audition of the RF-7 ii pair that they had and I was pretty impressed. Unfortunately, their demo room is not the greatest so it was hard to gauge how they might sound at home. Still, I was impressed enough that I am planning to pick them up, so my question is, how much of a difference should I expect to see between what I have now and changing out the fronts and center? My basement is not huge by any means (maybe 12x14?) but I do like rich sound and there is always the possibility that I might move into something bigger, so I don't mind if this all sounds like overkill. I am also seriously considering adding the Emotiva XPA-5 to the set, but I'm still researching it like crazy because I've never owned an amp before.
the RC-64 & the RF-7's would be a Killer system paired with a XPA-5
post #18604 of 22807
What's the point of adding an amp if you already have a receiver with a built in amp? In pro audio, the idea is the less components the better so you won't get as much 'noise'. Am I missing something here?
post #18605 of 22807
Hi guys, I'm a first time Klipsch owner, and I've had my (4) WB-14's and (1) WC-24 for about three months, and they just seem to be getting better and better. They are part of my 5.1 system and powered by my Onkyo 709.
Quick question, Audyssey set the x-over at 60hz for the 14's (L/R/Surr) and 50hz for the 24 (Center), but I felt that was far too low, so I changed it to 90hz for all 5 speakers..........What do you guys think?
post #18606 of 22807
Yes you are missing something ,modern AVR's don't have the robust amp sections that older AVR's had . The new feature rich AVR's only have a certain amount room in the box by design , add more PCB's & the less room there is for the robust amps that were in the less feature rich older style AVR's .
The Emotiva amps have a very low noise floor, lower than a stock AVR amp section has . Add in the more watts in the Emo's per channel , the ability to run @ lower levels means lower noise floor as well . Then also Add in the added headroom factor & then added amps make a lot of sense .
post #18607 of 22807
Fair enough. That all makes sense to me =^)
post #18608 of 22807
Hey guys, i recently bought a pair of RF82ii's and using an onkyo 805. I love these speakers and have been immersed in this thread....its HUGE!
Question, i ran audessey and it set my speakers ( i am using a powered sub) to full range which i changed to 80hz. After reading i will play a bit more with the crossover freq, but does anyone have a good setting for pairing these with the RC 35( which is what i am using)?
Anyhow, glad to join a great community!
post #18609 of 22807
It depends on what SPL at the seat that you want and how hard to drive the speaker may be. Some speakers have some pretty low impedance dips.
post #18610 of 22807
The RF7's that dualedge is asking about are one of those speakers.
post #18611 of 22807
Anyone know the correct angle adjustment screw size for a RC-25 center channel? I have misplaced mine and have angled my center channel using some rubber feet stacked on top of each other and it does seem to help some with sound direction.
post #18612 of 22807
Correct, but I don't think the RF-7 II's have as low an impedance dip as the RF-7's. That dip is why a lot of people noticed a difference when connecting up a more powerful amp to the RF-7's.
post #18613 of 22807
Try setting the fronts as "Small" this helped my RC-62 center. And I used 80 as my cross over when I had my 805. Worrked great on movies. For music I use "Pure Direct" no processor and set cross over at 80 but I have Cornwalls and two Subs in very small den.
post #18614 of 22807
anyway you say it the 7's & the 7II's still pull alotta watts for those 2 large woofers . & that mostly happens only during dynamic scenes in a movie .
running a 7.1 set-up off just a modern AVR is going to over tax the AVR's amps . Might not clip,but it will be missing alotta dynamics , that's where Amp headroom comes in . I know there are people who say most AVR's need only push 5 to 10 watts a channel to make music. but in Dynamic music passages & in action movies, headroom is needed to accurately present the sounds.
post #18615 of 22807
Thanks for the response, unless I overlooked it, I dont think there is a setting for "small", just full band and then specific crossover frequencies. I feel like the center is getting drowned out by the 82's, I will play with it more and report back.
post #18616 of 22807
When setting a xover, you are basically setting it to small. All avrs are different in this aspect
post #18617 of 22807
It's beeen two years.... I have a Yamaha RX-V1900 HD AVR now. It has YPAO room correction I changed it to "small" from "large" with my huge Cornwalls for movies and my RC-62 center is balanced better in my room.
The older I get the more signal gain I add to the center. Have you tried to add gain to the center to see if this helps?
post #18618 of 22807
Not yet, but that's what I will try next. Not that any of it sounds bad, just looking for that sweet spot
post #18619 of 22807
by setting your crossover to 80 you are taking alot of bass dynamics outta your Cornwalls. I set my CornScala's @ 40 just above rolloff that way I get the full benefit outta the 15" woofers as well as my subs
post #18620 of 22807
OK I will try that. Thanks ...
post #18621 of 22807
Originally Posted by Chuck Miller View Post
I'm planning my home theater and have pretty much decided on the THX Ultra2 system. A couple of questions. First, I see that Klipsch recommends locating the two subs next to each other. Their diagram shows them together at the front of the theater. Have you THX U2 owners experienced an advantage with this setup? Or, do you recommend something else? I realize a lot has to do with room dynamics, just looking for general experience here.
Second, I like the idea of buying a system that's been designed to optimally work together. However, I also read a lot about the great capabilities of many other subwoofers. That would seem to be about the only place that I would think about substituting another brand in the system. Any experience with this? Using maybe a couple of Hsu's instead of the KW-120s? Or are the 120s simply that good that one wouldn't consider other approaches?
Thanks for your advice.
Chuck
I heard this system at a local av store you won't be disappointed with sound as a whole or the subs.
post #18622 of 22807
Anybody have any feedback on the SW-115? I'm trying to decide to go with that or the SW-112. If I go with the SW-112, I'll probably eventually go with 2 of them. What do you think would be better to go with, 2 SW-112s or a SW-115?
post #18623 of 22807
With these two subs the choices are:
Good SW-115
Better Two SW-112
Best two SW-115
post #18624 of 22807
klipsch LaScala's on sale over @ Audiogon listed ToDay !!
http://app.audiogon.com/listings/klipsch-lascala--3
post #18625 of 22807
I will let you know in a few days when my 115 comes in.
I have high expectations for the 18hz and 121dB, But I am only buying one for now.
Good SW-115
Better Two SW-112
Best two SW-115
Truth^
Pictures would be nice!
post #18626 of 22807
Originally Posted by MSchu18 View Post
[b]
not my sale .... just referencing them here as there are some here looking for a pair .. my 4 CornScalas work fine with me !
post #18627 of 22807
I just made a deal for a RC64ii for $800NIB... pick it up tomorrow.
Happy Happy Joy Joy!
post #18628 of 22807
HI I am a newb but I am a Klipsch owner. front L/R=VF-35 and center= SC-1 drivin by Yamaha RX-A800 and JVC sub with cheap Fluance Bipolar surrounds. viewed on a Sony Bravia ex 55 lcd. so Hi all.
post #18629 of 22807
Welcome !!
post #18630 of 22807
I've asked someone to move my thread but no one didn't so I'm posting it in here.
Right now I have a pair of Klipsch VF-36 towers. I came across an ad selling a pair of Klipsch RF-3's. I looked at the specs of both speakers and there is not much if any difference in Frequency respose. My question is would it be smart to pick up the RF3's or just keep my VF-36's? I know the
RF3's are older but what is the difference in the 2?
Thanks for your time.
  Back to Forum: Speakers
