I attended the KC blind Sub test at Archaea's and I really loved the SubM. I also thought the DIY dual opposed sounded similar but ran out of juice. So I thought I would do 4 cabs with 2 MFW-15's each dual opposed with the Dayton SA1000 modified by Seaton and Motor City.
So I tracked down a guy with 4 of them that he never put together. It turns out he also has 2 DTS-10's and I could go that way as well. One of them has an air leak that he can't find.
I have not been able to listen to a DTS-10 so I am still up in the air on the subs. I have listened to the Orbit Shifter at the meet and that is my only experience with a horn sub. Needless to say it was mind blowing when he let them go at the end of the meet.
Are you guys suggesting horn subs bc it will blend better with my horn speakers? Or just because it would be cool to have an all horn system. Is there a sound quality preference?
I have a pair of DIY Khorns in the shop Dad built in 1960 when I was a kid that need some love and $$. The reason I asked about the folded horn sub you have.
. I have Bob Crites crossovers & Ti tweeters already so maybe Bob could help as well. Its not that I dont like the performance of the KG's as I do like them very much, its just in my thinkinging I thought they would look so much better with the gold drivers... just more or less of a face-lift per say.
. I also realise the "smart" thing to do would be to just get the RF 7 II's but just going buy the measurements I dont think they will fit into my HT are as the KG's barley fit already. Thanks for they reply
Also, don't sell yourself short. My room is nothing special. Certainly not expensive, just alot of sweat equity.
