Originally Posted by rlhaudio
* forgot to mention I may add the Denon 4311 or similar integra amp. The sales rep stated its only 140wpc in (2 channel modes, when playing all 7-9ch its more like 75wpc) Is this true? It stated its a monoblock design. I assumed it discretly played all channels with 140wpc. Or is he just trying to upsell me a more expensive amp? ic. McIntosh, Parasound Halo, etc. Should I use a seperate amp for power and buy a cheap pre with the codecs for surround sound? thanks for your thoughts..
He is trying to upsell you by telling you the truth, and it probably won't even give you 75. Yes on the separate amps. Check out the emotiva UMC-1 for pre/pro, I've heard good things about it and it's fairly inexpensive and comes with a big ol discount for the new emotiva that is coming out this year (xmc-1 I think?). Speakers like that are going to love more power and you will be able to push them like they should be. I hope this helps =^)
) and a PS3 set to use Linear PCM. I did the MCACC auto calibration - but it didnt fix the problem. I vaguely remember having to set up something a certain way to avoid this problem in the past, but I cant remember!
