Yes. It was in reference to a Sammy Hagger song with the same title (he wrote after getting numerous speeding tickets)...My nearest neighbor is also 50-75 yards away.
Your analogy with the less pretty finish is spot on. My understanding is the original home version Jubilee was expected to price point around $20K. Furniture quality finish/looks. You can get a pair today, factory new, delivered to your home (lower 48) for "about" $8K as I understand. They do not have the wood HF horn and are not quite as finished as the prototype. Still...you can save thousands order them unfinished and pay someone to finish them!
Second, let's just say that the Palladium is a fantastic speaker in its own right...but for the extra thousands of dollars for the prettier finish.... the Jubilee indeed represents a better dollar/sound value and in my opinion sounds better.
Yes, I have heard them side by side
. I'm sure once I get around to bracing the insides as you have mentioned, I can only assume that will help as well. I am curious to rather or not I should repklace the10" drivers as well thou?? I did test them all as they fell withing specs 7.5ohms & such but since they are 14yrs old I wounder if I should just replace them? If I were to replace them any reccomendations to where I can get new ones??
