AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 689
post #20641 of 22392
Okay, fellas, here is my question: I am running a 7.2 system with the following components:
KF-26
KC-25
S-3 (X2)
SB-20 (X2)
Sub 12
BIC Pl-200
Pioneer Elite VSX-52
However, in a few weeks, I will be replacing the floorstanding and center speakers with RF-81ii (X2) and RC-52 ii, respectively. Will my receiver have enough juice to power these new fronts and center? Do I need an additional amp, or should I be just fine? I use it mainly for movies, games, and music. Room is about 12 X 20.
post #20642 of 22392
KF-26
KC-25
S-3 (X2)
SB-20 (X2)
Sub 12
BIC Pl-200
Nice receiver. You should be all set to go.
post #20643 of 22392
Awesome! Thanks for the info (and the compliment).
post #20644 of 22392
I'd put em on the sides.
post #20645 of 22392
Looking at upgrading my Klipsch B-2s and was looking at the Klipsch KF-28s. I was wondering if this upgrade would be worth it. If it helps at all my AVR is a Yamaha RX-V671, center is a Klipsch c-1 and sounds are s-2s and my sub is a Klipsch SW-450.
post #20646 of 22392
Guys looking for some input on the following Klipsch Reference speakers for a 7.x setup:
RS42II - I'm going to be using a pair of these as my surrounds L and R of the seating area. I was going to get a pair of RB51II as rears. I need to wall mount the RB51II - what wall mount can I use for these? How does the keyhole work exactly for mounting purposes? Is the best mount pinpoint am40?
post #20647 of 22392
The keyhole is to hang the speaker from a screw in the wall. I placed two of the bumpers at the lower left & right edge on my RB-41 II's, so they sit even on the wall, to allow the back port to work. Look up a few posts, there is a mount that was linked that works for the larger sized speakers like the 61's, 81's.
post #20648 of 22392
I just purchased a pair of RB51II last night as my rears. I checked out the dimensions and it looks like the Pinpoint AM40 should theoretically work - has anyone tried this? Anyone actually have the RB51II and able to provide any feedback. It looks like the RB51II cant be flush wall mounted since it has a rear firing port that shouldnt be covered.
post #20649 of 22392
Does anyone know the differences between the KF-28 at best buy and the KF-30 at H.H. Gregg?
I'm wondering if I should bother with either. Presently I have Monitor 70's as my main speakers but a pair of Klipsch as my surrounds. The surrounds tend to stick out during movies at times....maybe because they're closer to my ears. The thing about them is that their sound seems more pronounced than what I get from my fronts and I think I may want to type of sound from my mains.
thanks
post #20650 of 22392
Looks like that site misprinted. The specs are identical on the klipsch website. Dual 8s, aluminum tractrix 150w handling.
post #20651 of 22392
Are Sunfire amplifiers a good match with Klipsch speakers? Specifically referring to the TGA-7401. Will be using with RF-7, RC-7, and RS-7.
post #20652 of 22392
Possible overkill, but I'd say yes as it is rated to 4-ohms. The impedance dip of the RF-7 is what you need to be concerned with and that amp appears to be fine with it.
(I don't believe in matching the sound signature of an amp to speaker, if that's what you meant.)
post #20653 of 22392
Just ordered a pair of RF-82's and RC-62 on clearence sale. I have an Outlaw 755 amp, rated 200 watts rms x 5, sound like a good combo?
Pre is an Emotiva DMR-1
cheers
post #20654 of 22392
cheers
you will be a Happy Camper with that set-up , what are gonna use for the surrounds ? ? ? smile.gif
post #20655 of 22392
Thanks! I have 2 pairs of Monitor Audio SFX, SVS 20-39 sub for lows.
post #20656 of 22392
Guys,
My basement is 20 * 20 with a 10 feet opening on the left side. I am considering the following for mostly watching movies (99%)
http://www.sounddistributors.com/buynow.asp?action=detail&prid=686&crid=234&cat_name=Search - Klipsch RF-52ii System FREE SUB
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=3974&sc=27 - Klipsch RF-42II 5.1 Home Theater-SW-310-Marantz SR5007 7.2 Channel with AirPlay
Both are coming around $1700. I may sell the Marantz SR5007 as I have a Onkyo 608. Any suggestion please?
I am also getting the Klipsch RF-82II CHERRY 5.1 System Marantz SR6007AV SW-310 for $2600.
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=2018&sc=27
I also bought a PW-505 sub for $180 from Amazon in case if I need to replace/sell the SW-310. Will this sub pair with any of these above systems?
Need to make a decision by Monday morning or I will loose the deal, Can you give your thoughts?
post #20657 of 22392
Also any idea how the "Klipsch RF-52ii" compares with "Klipsch - Icon Dual 8" 2-Way Floor Speaker" tha BB sells other than the Aluminium and Titanium cones. Do they really make any difference, by spec wise the Klipsch - Icon Dual 8" 2-Way Floor Speaker looks good.
post #20658 of 22392
Originally Posted by RR Cholan View Post
Guys,
Go for the RF82II system if you can afford it. Sell the Onkyo, not the Marantz. Also, why would you replace the SW-310 with the PW-505?
Edited by djPerfectTrip - 11/24/12 at 10:44pm
post #20659 of 22392
I thought of selling the Marantz as Onkyo would have enough juice to power these speakers and also to make some money out of it.
AS SW-310 is a 10" sub I was considering the RW-12D or the pw-505, as I am in a impression that a 12" will produce more bass and moreover people are sayig the 310 is over priced for what it gives.
post #20660 of 22392
The Marantz is going to power them better most likely, and it's a more updated unit, so future proofing is going to be there. I would say that the 310 is going to out-perform both of those subs, but I suppose I'd have to look at charts to be sure. Ask them if you can get an SW-115, I love mine.
post #20661 of 22392
even I am planning on getting 82ii along with rc 62ii and rs 52ii. Also, ordered the Yamaha RX 671, will this be fine. Or should i return it and get a higher end receiver. I don't need airplay or 4K upscaling. The specs are
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v671_black_u/
Views anyone ?
post #20662 of 22392
The 5007 has full 7.2 preouts if that means anything to you. It also has Audessy MultEQ XT (never remember how to spell that). I'm biased towards it because I have one powering my Klipsch set-up. Also, wait til the 29th for the RW-12D to come back in stock. It's been said in multiple threads that at 300 it's the best buy.
post #20663 of 22392
That make sense for pre-amp and I am waiting to jump on RW-12D , missed it last time. Thx.
post #20664 of 22392
Views anyone ?
bump....some one please help. should i return the Yamaha rx 671 or their aventage series like the A2010 or A1010 . There is a huge cost difference but I didn't want to screw up my new Klipsch by underpowering it. Wanted them to have an ideal set up. specs are here
http://usa.yamaha.com/products/audio-visual/aventage/?selected=384536_383289_239656_239655_384537_&mode=compare
will appreciate your input.
post #20665 of 22392
Views anyone ?
Aud2012 - I would upgrade to a higher end version. The 82iis will handle 150 watts RMS. The RX 671 only puts out 90 watts per channel with only two channels driven, must less in a 5.1 system. While the Klipsch speakers are very efficient they do like and can handle a lot of power.
post #20666 of 22392
Thanks for the response. I was recommended Yamaha A2020 Rated Output Power (1kHz, 2ch driven) 155W (8ohms, 0.9% THD) and Dynamic Power per Channel (8/6/4/2 ohms) 165/210/285/405W. Won't this blow my Klipsch 82ii off along with the 62 iiand 52ii . The power rating for 82ii is 50-150W
whereas the specs for A1020 are Rated Output Power (1kHz, 2ch driven) 120W (8ohms, 0.9% THD) and Dynamic Power per Channel (8/6/4/2 ohms) 135/165/210/280W.
So does A1020 stays within the specifications for 82ii setup and A2020 is too much to handle ?
post #20667 of 22392
I might be overstating this, but I seriously doubt any receiver would blow the RF82. I think I've seen guys running the Emo XPA-5s and those are rated for 200W / channel. It's not the power that kills speakers, it's distortion. Also dynamic rating at 2 channels would probably never be attained during any real passage.
post #20668 of 22392
I agree on the power, I am running a Rotel RMB-1095 with 200 watts/channel RMS with my reference system and it sounds great, especially with great Blu ray movies. I have a large room which can eat a lot of power to listen at loud volumes. I tend to watch movies at -10 to -5 dB from reference. It is loud, but better than a movie theater.
post #20669 of 22392
cheers
Where did you order these on clearance from? I am looking to purchase these as well and I am looking for a good deal.
post #20670 of 22392
Go to amazon and search for thema and select used. You'll see some that have new in open box for cheap
  Back to Forum: Speakers
