AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 710
post #21271 of 22410
Originally Posted by wraunch View Post
These will primarily be used in my theater for TV/movie watching and some video gaming. Do you think these towers wf35, ws24 surrounds wc 24 center and a pair of wb14 for $900 will be good enough?
Yes.
post #21272 of 22410
Hello all,
Just received a pair of rf-62 ii's! Starting to piece together a HT system that will replace all of my quiintet iii 5.1 (synergy 10 sub) speakers and so far so good! I moved my L/R quintets to the back for 7.1. I can tell already its going to be hard to wait to save up for the rc-62 ii center, hsu hb-3 mk4 sub and 4 rb-61 ii's for surrounds!
I have a denon 1913 running them and re-ran audyssey, but they don't seem as loud at the same volume level as when I had all quintets running. Is this because the rf's are so much bigger then the quintets and are being leveled so they don't overpower the quintets?
post #21273 of 22410
Originally Posted by undsioux7 View Post
Hello all,
Yes . . . Audyssey is "dumbing down" the high efficiency RFs . . . My suggestion . . . Until you get a sufficient center,at,least, is to run Audyssey with only the RFs connected.  Then, reconnect the rest,and make level adjustments by ear to your liking from primary seating position.   Don't bother using an spl meter, unless you already have one . . . Save your money for a center upgrade.
Audyssey is fantastic for eq'ing, but the disparity in size and differential in efficiencies of your,varied speakers just is not going to be overcome easily.
The bottomline, your quintets are no match for your Rf-62s . . . So, not enjoying the full capabilities your RF62s is the cost of an unmatched center and surrounds.  You will just have to tolerate it, at least until you get a center that can keep up with the RF62s.
 As well, there is not a really any sustained bass in an RF62 II; the 6.5" woofers that maybe reach down to 35hz, but only if do not have the crossover on the Denon set above that number and have the RF 62s set to Large.  Ideally, for HT, you want to have a dedicated sub that goes lower, and set the RF62s to small on the Denon with the crossover point set to around 80hz.
If you really want to hear what your RF62s are capable of, put your Denon into two channel mode (not 2.1, do not include the smallish synergy 10 sub) making sure you have set the RF62s as large and a crossover point lower than 35hz,  then with volume level low, put on your favorite Cd or vinyl album, and listen . . . Turning up the volume as you please.  Now you will know what the RF62s are really capable of.
The problem you are experiencing is mismatched speakers.  Your weakest speakers will become the primary determining factor when You run Audyseey.
You will definitely want to check out here,on AVS Forum the official Denon thread for your receiver and the official Audyseey thread as well.
Some people who upgrade only the fronts to a more powerful Klipsch speaker mistakenly think Audyseey will magically turn their smaller center, surrounds, and sub into something they are not . . . More,powerful.  Audyseey is an outstanding eq'ing feature, but it automatically calculates and sets the listening for all of the speakers attached, finding the maximal setting for the weakest speaker connected, and eq'ing the more powerful speakers (most,often down), finding the maximal,setting in which the weakest speaker can find room to be heard for Ht.
With your current mismatch, your best result will be 2 channel music listening with the RF62s.  For HT, you are just going to have to live with whatever result you can tolerate until you build with a matching center, then a great sub, then matching surrounds.
that is how many of us have to do it . . . Build one link in the chain at a time.  The most important of all for HT, is the soundstage (two fronts and the center) where most of the HT listening is to be had. Mthen the sub, for all of those concussive explosions, then the side surrounds, and finally the rear bookshelves to catch the little nuances.
as you upgrade the center, subs, and surrounds, consider pre-owned., you can often get some great deals from people who themselves are upgrading.
All of this?  just IMHO.
Congrats on your new RF62 IIs . . . A great speaker for HT!
Edited by Rhetor - 2/14/13 at 2:13pm
post #21274 of 22410
I'm assuming this does not include the surround speakers. If Audyssey really averages the surround speakers in with the FL/R/C there's a lot of people that would be getting less than stellar results.
post #21275 of 22410
Thanks for the reply! There is some great info in there! Especially running audyssey with jus the rf-62's. I really appreciate it.
It sounds like I am on the right track since my plan is to get the center next, then sub, then finish the system off with the surrounds. I should be able to get the center and sub within about 6 months, so I can deal with the system for now.
post #21276 of 22410
Just curious, if you set the fronts to large/full band with no sub, how do you set a crossover? There's nothing you're sending the lower frequency to. Ill have to check my 4311 but i don't think you can change the crossover in full band/large.
post #21277 of 22410
Hey everyone I have a couple questions. I am looking to buy a RC-25 center channel speaker and RB-51 bookshelf speakers. I was wondering how the RC-25 would compare to the new RC-52 center? And what towers would be closest to match up with the RC-25? Thanks!
post #21278 of 22410
Sorry about that . . . When you set them to large there is not crossover set . . . You aire simply going full range on the speaker.
post #21279 of 22410
In case anyone has the XF-48 tower speakers, I wanted to share my recent experience. On one of them, the internal amplifier quit working, so I simply ran speaker wire. I became annoyed by that on principal, so with the XF-48's still under factory warranty, I called Klipsch. Turns out the amps are quite costly to replace, and they would rather not take the chance on repair. They had me send back the XF-48's and are exchanging them for a pair of Rf-82 ii's! I am quite excited, as they should match up well with my RC-64, RF-52 mids, and the RF42 rears. In the mean time I purchased a pair of ML Motion 12 towers on newegg to tie me over until the 82's arrive. Seems the 82's are so heavy, they must be shipped by freight.
So, if any of you with the XF-48's had the same problem and decided to ignore it infavor of running them off your amp/avr, you may want to call Klipsch and see hwat they will do. Based of the original MSRP of the XF-48's, I asked for RF-7 ii's, but the best the could muster is the Rf-82 ii's.
Best to ya!
post #21280 of 22410
Just wanted to give all of you an idea of why Klipsch is going to be my next system:
I went to 2 high end dealers. I felt very comfortable at both. The problem with the dealer that sells PSB is that all he had on hand were Imagine Mini Bookshelves, and Image T5's. They had NOTHING else, so I couldnt hear any of the rest of the Image line, which is what I really wanted to hear. The Minis were awesome, but for a package with that, the Mini center, and B4's for the surrounds were going to be around $1750. The T5's I heard were too laid back for me, even though the soundstage was great. The guy also only put on a music CD, even though I stated I listen to about 5% music. No movie watching...probably due to the fact they had no centers. Not impressed with the dealer, but the expensive version (Imagine's) sounded great.
Second stop was another dealer that deals in the klipsch Reference series. They had the floorstanding version as well, and the 52 center which is pretty close to the 42 I wanted to hear. They put on the new Narnia movie, and I was highly impressed. It was very forward sounding, but not "fatiguing" as many have stated. This might be due to the speakers being the series II, or maybe it is just my preference for speakers. He also put on a music CD (lot of vocals and instrumental solos) and it too sounded great. Not only was the dealer very informative and friendly, but he was very laid back as well. He also gave a killer price, which he said, and he proved, beat Amazon prices as he states that is the reference (no pun intended) for their pricing. Here is his breakdown: RB51 (x2) for $350, RC42 (x1) for $220, RS42 (x2) for $500, so total would be $1070, which is $430 under my max budget! Is this a good deal?
Wanted to let you all know that it would be running off of a Yamaha 765 receiver and I would carry over my F12 sub. All in a 15x15 room.
Edited by border411 - 2/16/13 at 12:14pm
post #21281 of 22410
That may be the first I have heard of someone paying more for their surrounds than their mains but it seems like a good deal.
post #21282 of 22410
your using book self speakers for your mains?
the fatigue reference you speak of is main dealing with 2 channel music listening... and only because the system is not set up correctly.
post #21283 of 22410
That is what he said about the fatigue as well. I read that earlier in some posts. Unfortunately, I have size constraints, so that is why the surrounds are more than the mains. With a 16 month running around, as well as due to the aesthetics of the room, floorstanding speakers are not an option.
post #21284 of 22410
Unless money is no object or you plan on moving or something I would not spend that much on rears. Its just unnecessary.
post #21285 of 22410
get the RC52 instead to match the 51's & I'll bet your still under budget that RC42 will not keep up with the RB51's in timbre match . It's very important with movies to have the center match the fronts Trust me on this smile.gif
post #21286 of 22410
I have a brand new pair of RB51ii's I'm selling for 250.00 if your interested. Well just sold them. They went fast wow!
Edited by cchunter - 2/16/13 at 3:54pm
post #21287 of 22410
My surrounds are more than my fronts but it wasnt by choice. I orderd the RS52ii's and they were out and sent me the 62ii's instead without any additional fees. It actually sounds awesome just have to tone the surrounds down a bit to match the front soundstage. Not that big of a deal
post #21288 of 22410
The rc52 won't fit in my environment, and the speakers listed all come in under my budget of $1500. The PSB's I was looking at are over $1700, so these are a steal! biggrin.gif
Edited by border411 - 2/16/13 at 3:19pm
post #21289 of 22410
So, you listened to an RC52, got excited and are buying an RC42, mismatching to with RB51s bookshelves (because of the footprint, which by the time you put them on speaker stands would be the same footprint as, say, RF52s), with RS42 surrounds.
And the taxes on that amount?  Don't forget your governor's cut.
You asked, "Is this a good deal?"  Yes, you are getting good price deal each individual speaker new (unless you are in a state where you would not have to pay taxes ordering off Amazon); but maybe you are not getting a good sound deal in the end, unless you like the end sound result of your individual speaker purchases all plugged in together.  Too bad your dealer did not have all of the pieces for you to audition together.  (That is why you are reading some hesitation in our responses.). But, you did ask, "Is this a good deal?"
Remember, you like hearing an RC52; you did not audition an RC42, which you desire to buy.  They are not the same.
You have enough money left over in your budget to think about an RC52 and RF52 towers instead of the RC42 and RB51s.
And, if you considered used from someone else upgrading, you could get more bang for your buck.
But, it is your money, as long as you are happy with the result, we all will be happy for you, especially buying anything Klipsch to build an HT, instead of PSB mini-bookshelves.
Some of us are just suggesting you simply give a little more thought about the end result together, rather than just the price on each individual part.
I and others, I am sure, are genuinely excited for you putting your first Klipsch HT together!  Like you, I discovered a great speaker forum which helped me put together my first HT.  It made all of the difference in my selections and resulted in a four-year happy HT marriage until I upgraded.
All the best in your speaker quest.
Edited by Rhetor - 2/16/13 at 4:50pm
post #21290 of 22410
Yes, but your side surrounds can be leveled down to match your front soundstage.  And, you have the RF52s (not RB51s as the border411 is thinking about) for fronts.  Perhaps, because of your setup in your profile, you are in a good position to advise border411 on why RF52s and an RC52 front soundstage might be a more meaningful option than that of an RC42 and RB51 bookshelves as a front soundstage.
post #21291 of 22410
He said floor standing speakers is not an option.
post #21292 of 22410
With the money you saved you should get a better sub.
post #21293 of 22410
This is the RB61ii system with a FREE subwoofer. He has .02 cents to spare. Much better system than what hes looking at and he can prolly get it a lil cheaper if he calls ahead of time....
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1865&sc=52
post #21294 of 22410
Good deal. The PA 120 sub is much better than the F12 he has. He also already said that the RC 52 wouldnt fit.
post #21295 of 22410
As previously stated, floor standing speakers are out. I can not go with anything bigger than a 42 center. Tax is 5%, which is more than I will save by buying local. I do not like to buy used...been burned too many times. One thing I left out of my original post is that the bookshelves can not be bigger than 13"s tall. That is why the 51's are the biggest I can squeeze in there.
post #21296 of 22410
Im sure it will sound ok. With all those restrictions you cant expect great sound.
post #21297 of 22410
And he asked, "Is this a good deal?"  Sounds wise, not the best match in toto.  My opinion, like yours, is free, and I am free to share any insight as I will.
post #21298 of 22410
+1
post #21299 of 22410
Sounds like your mind is made up by your restrictions, then.  Let us know the outcome.  We are always interested in what different setups work for different people.  Will look forward to a review of your new system.
post #21300 of 22410
No kidding goofball. Quit being so defensive.
  Back to Forum: Speakers
