Originally Posted by
MSchu18
why dont you just go into manual mode after running your calibration software and pump up the db's on whatever channel your ears thinks needs it?
If possible, you want to get your speaker levels within Audysseys limitations of -12db to +12db. If the level doesn't fall within this window, Audyssey will be unable to EQ the speaker correctly.
It is very strange that TVMan is getting a -12 on his center unless his MLP is very, very close to the center - how far away is your MLP TVMan?
And this is very good advice:
TVMAN, make sure your center isn't pushed back in a cabinet, you want it sitting out a little and pointed up/down, towards the main listening position.
