AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 751
post #22501 of 35176
Originally Posted by Mongo171 View Post
Welcome to the Klipsch Thread!
Are your front speakers RF-82 or RF-82 II? The RS-52 or RS-52 II will be your speaker of choice for surround duty.
Thanks smile.gif It's RF-82 . But I would like to buy the new model RS-52 II , not the old one smile.gif So RS-62 II is not a better choice? .
post #22502 of 35176
Originally Posted by Skylinestar View Post
Any reason why Klipsch Reference 7.1 speaker packages recommend RB bookshelf speakers for rear surrounds (SBL+SBR) instead of RS surround speakers? Why not RS for all surrounds (SL+SR+SBL+SBR)?
This is a very subjective hobby we've chosen. Many pretend they know specific answers to certain things but they really don't. What may work for them may not for you in your HT. I use RS speakers as surrounds because I don't have a huge room and they diffuse the sound for a wider sound field and don't throw sound directly at you like the RB series will.
post #22503 of 35176
Rule of thumb is to stick to the same series for lcr. Anything else and your taking your chances. It may sound better but I couldnt say.
post #22504 of 35176
Hi klipsch owners. Just want you guys to ask I saw this sale on newegg Klipsch Synergy F-20 does anybody from here tried this one? How does this sound? I know its a horn tweeter I jever heard frok horn tweeter. If I will buy them im using them just only for mu surrounds.are they ok for surrounds? And how they will sound with my fronts energy rc 70's and rc lcr. Thanks.
post #22505 of 35176
The RS-52 II's will work fine for you. The 62's are beasts and recommended for the RF-7's. I will be buying the RS-62 for my system. You can get the 62's if you want. They will perform better than the 52's. No one's NOT going to TELL you what to buy. These are all recommendations for you to consider.
The most important thing to remember is to keep your LCR timbre-matched. The surrounds can be of different series or manufacturers.
post #22506 of 35176
Ok . I think I will go for the 52 II 's. They are cheaper also smile.gif But I have the old RF 82's. Do you think I take a big chance to
buy RS-52 II and RC-62II senter? The old series are not available here and I dont want to buy used ones.
Iam going to buy a subwoofer also. klipsch SW-115? http://www.klipsch.com/sw-115
post #22507 of 35176
Thanks for answer. Anyone here have the old RF-82 with the new RC-62 II or RS-52 II ?
post #22508 of 35176
The Craigslist post for the Quartets for $400 has been removed. It looks like that ship has sailed, and just when I got my hopes up. frown.gif
I guess I'll keep looking. I'm not in any hurry, and except for the Quartets I really didn't have my heart set on anything. I'm hoping I know a good deal when I see it.
Thanks everybody, for the advice and the help.
post #22509 of 35176
With the RS-52 II's, there will be no problem running with your mains. The RC-62 II Won't be an exact match with the sound of the RF-82's. If buying new is your only option, then get the RC-62 II.
The SW-115 is a good sub. Most people go for subs made by other companies. I have an SVS sub and am quite happy with it.
post #22510 of 35176
wheres the help from this thread? does anybody here using floor standing speakers as youre surrounds? how do you like it?
post #22511 of 35176
I don't know anything about the specific speakers you asked about but I do use Klipsch RVX-54 as my surrounds. They sound very good. I also use Klipsch RSX-5's for my rears and although they aren't floorstanders, they do have horn tweeters too.
BTW, sometimes it takes longer than an hour to get a response from a forum.
Edited by lflorack - 6/1/13 at 12:32pm
post #22512 of 35176
People use floorstanders as surrounds. They will do fine as surrounds. Just make sure that at least the tweeter isn't blocked by anything to prevent hearing it from the listening position.
post #22513 of 35176
Which are better speakers for movies, rf-62 or f30?
Edited by blee0120 - 6/1/13 at 1:33pm
post #22514 of 35176
All depends on what you want to use them for and your room configuration.
post #22515 of 35176
I'm buying an AT screen and I want to use three for my front stage. Going to go with the lower model for my surrounds. I'm going to start off with a 5.2 system at first. But they are going to be mainly for movies in my HT. The room is 20x14 and the AT screen is 12ft wide
post #22516 of 35176
RF62's are better IMO
post #22517 of 35176
post #22518 of 35176
First time poster, long time lurker.
Looking to build a home theater and music system for the basement. Big room 20 x 28. More concerned about music. I like hard rock and metal. Plans include a Marantz 5007 reciever and the Klipsch rf 82 ii and the corresponding 62 center and 52 surrounds. Probably a SVS or Rythmic sub. Any comments or suggestions in general? More specifically, I have listened to other speakers, like Polk, but none seem to have the livelyness or punch that Klipsch have. Before I pull the trigger, any other brands I should seek out and listen to in the same price range? Anything with a similiar sound or kick if you will.
post #22519 of 35176
Considering changing out my system and going with a full Klipsch Reference setup. Looking for my final retirement system.
Currently have kit built speakers from ACI - Audio Concepts that is now out of business. Jaguars for mains, Essence center, dual Titan IIs for subs, 4 Emeralds for surrounds. Room is 18 feet wide by 22 feet long with 8 foot ceiling and the front mains are 7 feet apart due to corner fireplace and front doorway opening. No other opening. Usage is 90% blu-ray and 10% music so looking for home theater impact. Not able to fit the older wide style Klipsch box speakers in.
So considering the RF-7 IIs mains, RC-64 II center, pair of RS62 IIs for side surrounds, pair of RB-81 IIs for rear surrounds.
Might go with a single or pair of Seaton Submersives for subs or keep using my Titans for a while.
I would think this sounds pretty dang good. No where near here that I can find to audition this stuff as so many audio stores have closed or no longer stock the higher priced stuff. I last heard Klipsch about 30 years ago and those were the Klipschorns.
I just want to get some idea of how the RF-7s sound so my question is--- If you are an owner of the RF7s, what speakers did you previously own? Did you come from anything higher priced or considered competitive to these? Did not find much on the web for reviews.
Just getting the bug to do something different and have sons to hand down my current stuff to.
Just wish Klipsch offered something inbetween the RF-7s and the Palladium as there is a large gap there in price.
Thanks!!
post #22520 of 35176
For a front stage, I would use the F-30's. WDST's aren't very good for LCR use.
post #22521 of 35176
You have a very good system in mind. Should do very well for you. I know both SVS and Rythmik both make very good subs. I went with an SVS PC13-Ultra because I don't have much space for a conventional sub. It is awesome with rock and metal. Well, this IS a Klipsch thread. I think we'd all recommend Klipsch speakers to you. lol
post #22522 of 35176
I think I'm going to go with the F-30s
post #22523 of 35176
Mongo knows his stuff, good choice!
post #22524 of 35176
He does
post #22525 of 35176
I would def go with the RF62ii's rather than the F-30's. The Reference line is much better sounding.
post #22526 of 35176
Good choice, i love mine!
post #22527 of 35176
I guess opinions vary. I demoed the lower-mid reference speakers along with the Synergy F30, and i preferred the F30.
post #22528 of 35176
I owned the F10's before and the Synergy line is good but my ears prefer the Reference. Either way they are Klipsch and they make great speakers in all their speaker lines
post #22529 of 35176
Thanks!!
There is a large gap in price between those two and I'm sure both sound great.  I don't think I've ever heard the RF series.  I have heard the Palladium and it is outstanding.
If you can deal with physically (much) larger speakers, you can get a middle price point and in fact, beat them both in sound quality.  Have you heard of the Jubilee?  It was originally designed to become the Klipschorn II.  For various reasons, it's now in the cinema lineup.  I'll spare you the story.  Do a search on various forums for Jubilee & get a pot of coffee.
post #22530 of 35176
The Jubilee --- um I think it has ZERO chance of passing the WAF!! I bet it sounds great but just not going to fit in well in my living room!
Thanks for the suggestion.
  Back to Forum: Speakers
