AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 930
post #27871 of 35275
So, maybe this would work best... What do yal think?
UPA-200 (2 x 125wpc) to power my front towers (KF-28)
UPA-500 (5 x 80wpc) to power my center and side/rear surrounds (C2 / VS-14 / VS-14)
post #27872 of 35275
Well that sounds good if I can get away with the 200W option ( Minister of war and finances could be the problem there ).
Maybe I will wait to see what the other quotes come in as and if in budget then ill be able to sell my 2 existing amps and upgrade.
So excited
post #27873 of 35275
Or I could do what you are looking at doing.
SO MANY CHOICES :(
do you have to have the same power across the board so the preamp knows what to do?
post #27874 of 35275
Finally found the perfect solution for my Samsung F8000 not fitting on the RC-62 II.
My solution, a custom build plexiglass stand.
Sent from my GT-I9505 using Tapatalk
post #27875 of 35275
Those stands are annoying arnt they :)
post #27876 of 35275
Originally Posted by zaijiashangs View Post
yes,hat thin form factor which looks great wall mounted comes with sonic sacrifices with respect to the horn depth and cabinet volume, which is why all the the Klipsch floor standers are traditional 'big' boxes.thanks
Is this why the Heresy line is held in such high regard?
post #27877 of 35275
^^^ No, that's the non-sensical post of a Spam-bot. Suggest you remove your post & I will remove mine.
post #27878 of 35275
I gotta say the more I listen to my new reference setup I am enjoying these Rf82's
a ton more.!
My svs sub is down until tomorrow and I didn't want to bring my klipsch sub back upstairs, so I decided to play with 2 channel mode for some music today to see what the towers can do.
I set them to full and xover at 40hz and I must say I am quite impressed with the bass output! Even with my room and setup being far from optimal.
Totally different machines when driven with some more wattage and full range.
post #27879 of 35275
a ton more.!
Same here with my new RF62s. Even with only 50 watts they sound incredible.
Curious though, why would you set a crossover if not using a sub? Is that to limit the output in the lowest range?
post #27880 of 35275
I guess since I set full range that didn't help anyway
post #27881 of 35275
just ordered
2 RF7II, RC64II, 2 RS62II SW115 should be arrive next few days
the question is i have Pioneer VSX-1120-K should i keep it or buy new one?
post #27882 of 35275
Originally Posted by gumati View Post
just ordered
Good show! What other speakers do you use? I'd use the Pioneer as a Pre-amp & buy an external amp to power Front 2, or 3, or maybe all 5, depending on listening habits (source type & how loud?)
post #27883 of 35275
i have in-ceiling speakers but i use them with sonos for music and radio
source will be HTPC for movies and PS4 for gaming
not that loud since my grandma house very close to my home theater
post #27884 of 35275
OK you RF-7II owners chime in, please.
post #27885 of 35275
just ordered
+1
post #27886 of 35275
Wasn't getting much of a response in the main forum so figured I would try my luck in a dedicated Klipsch thread.
I have 4 in ceiling CS-650-R speakers in my new place (600 sq ft studio) that have been installed by the former tenant.
What would be a good budget center speaker (200 or less) that would match? Would it ideally be a Klipsch?
Looking at the 500W 5.1 Yamaha Receiver and the small Dayton 800 sub as well to complete the setup.
Any comments or suggestions about the center specifically or the setup in general would be appreciated.
post #27887 of 35275
Anyone familiar with the RC-500, RS-400 limited edition speaker line?  Are they the same or similar as the reference line?
post #27888 of 35275
Look on that auction site and Klipsch factory forum for nice used Klipsch RC-62 the RC-62II are the newer model and more expensive and not many used one's for sale.
I had a RC-62 for several years and liked it with my Cornwalls but I sold it and purchased a older used Klipsch C7 (bigger tweeter horn) as my Cornwalls are so huge I had to run up the gain on the Rc-62 to get it to blend in. Try to purchase the best center speaker you can afford for 5.1 DVD/Bluray audio.
post #27889 of 35275
Thanks for the reply. I like the idea of getting a good used Klipsch center. Even used the RC62 is still a bit over the budget but I will consider it. Are there other similar more affordable ones to look at? I saw that the RC42, RC52 and RC3 look more affordable - are any of this a notable alternative?
Thanks agan!
post #27890 of 35275
They are the same as the last version of the Reference line, this per Klipsch tech support. The specs on the towers and bookshelf models differ from the current version in that the crossovers were lowered on the current version. The RC-500 (RC-52) is identical in published specs with the current RC-52II as is the RS-400 (RS-42) with the RS-42II. Dimensions, weight, crossover........ all the same. There is a slight visual difference as the woofers are a different color and a slightly different shape.
I can't tell much about the surrounds since they really don't see much action in movies that I have watched so far and I don't listen to multi-channel music. But the center is fantastic. A bigger upgrade than the mains in some regards.
I don't have access to discounted Klipsch prices out here, so I saved $370 over what the current versions would've have cost.
post #27891 of 35275
Thanks agan!
I sold my mint black RC-62 for $225.00 plus $25.00 to ship. I assure you the extra $50.00 is worth the wait for you to save for, all the others sound good in a small/medium room
as I looked at them too when I purchased mine. I am retired and have budget my monthly SS check carefully. IMHO wait and save just a little more, it is worth the wait. The center
is one the most important in a 5.1 HT system. The RC-62 just had a more natural sound to it vs the RC-42/52 I listened to. Play them all at a lower level and they will be OK
but later on you will be up-grading everything. wink.gif enjoy what you do choose.
post #27892 of 35275
Thanks agan!
The RC52II is a good center and would think it would do fine with those ceiling speakers. Ofc the 62 is better but for your setup I think you'll be more than happy with the RC52II.
post #27893 of 35275
I like ATI amps too. The AT2007 I bought is top notch and made in the US. I'll always be skeptical of these internet companies who contract out to foreign manufacturers. Not saying there's anything wrong with that, but I am saying I have more faith in a company with their own factory that uses top quality parts and hires Americans. http://www.classicaudioparts.com/ is where I bought my amp from; they are a division of the ATI that sells overstock and factory b-stock. It's definitely worth calling them if anyone is looking for an amp.
Originally Posted by Mongo171 View Post
IMO, separates are the way to go. Amps pretty much hold their own with technology. My ATI amp is 15 years old. Still going strong. With AVR's, their technology changes just about every year. Cheaper just to keep up with technology with a Pre/Pro.
I play loud, too. 105-110db at MLP.
post #27894 of 35275
hey guys ,finally got my xpa 5 and palying arround with it and wooooooooow this what it feels like to have power ,hey fast man i st my expectation button to low but guess what i am impressed .
i have my xover at 80 and the bass very tight and punchy ,highs and mids perfect i love it ,i 'll post pics of all my setup as soon as i tidy up the wiring mess and calibrate .never knew the klf s can wake up that much people .
post #27895 of 35275
Is the the Reference line made in America?
post #27896 of 35275
Some Reference is assembled in ArKansas, I think.
The 2 I own(ed) were made in China.
post #27897 of 35275
Some?
post #27898 of 35275
RF-7II some one else will need to confirm.
post #27899 of 35275
reset the crossovers down to 40 & see what happens you'll pleasantly surprised I predict
post #27900 of 35275
40 is very deep fast ,love it but it might too much even for me i did also try full band again way too much bass and i love it in music but movies i think i might just stick at 80hz ,maybe cauz my sub doesnt work at 40 i don't hear it working ,i don't see in the back that it goes down to 60 and nothing else maybe i am missing something .but anyways i love this amp guys it feels really solid .is there any bad sides except energy bill slightly higher ?
can i hurt the amp if i watch tv long hours and keep it on long time or is it ok ? btw it's dead silent when i pause movie/show or music i am again very impressed i have lotr fellowship on right now and the last battle is rocking ,i know this scene and watchrd it a million time that center neve sounded that crisp and airy /natural......
xpa all the way ,maybe on day the umc 2 if anything happens to the onkyo 818
  Back to Forum: Speakers
