AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 978
post #29311 of 35178
Originally Posted by DaJoJo View Post
well... the RB600 = RB-61.  the RB-61II the other one. it has newer crossover and go low to 43hz . thats about it. you can get the RB-61 for less.
These are the specs that the RB-61II show on the Klipsch website, its almost the same as the RB-600.
RB-61II : 45Hz-24KHz ± 3dB
RB-600: 45Hz-23KHz ± 3dB
when you say I can get the RB-61 for less, do you mean less than the II or less than the RB-600?
post #29312 of 35178
I see the RB-61 goes down to 43.
43Hz-23kHz +/-3dB
I can't seem to find any even on eBay. I know they exist because the Klipsch site has them.
post #29313 of 35178
43Hz-23kHz +/-3dB
http://www.crutchfield.com/fg_37900_FFBrand|Klipsch/Klipsch-Bookshelf-Speakers.html?cm_re=landing*block2*_
post #29314 of 35178
You can get the 61II in cherry for the same price as the RB 600.
post #29315 of 35178
& from Crutchfield & others, iIrc.
Edited by SanchoPanza - 12/20/13 at 6:36pm
post #29316 of 35178
it seems more the customerservice isn't all that. i cannot say anything about the sub itself as i don't have one and don't know the thing, but i'm pretty sure ur better of with a SVS. instead of the PI200 save some money and go for the SVS one.
Thats the plan. I'm leaning towards a HSU VTF2 MK4.
post #29317 of 35178
less then both II and 600..
what u mean allmost the same ? did you even look at the thing lol  61=600 just take it from me :D
43Hz-23kHz +/-3dB
i see the RB-61II goes up to 24khz and has a new crossover and tweeter
good point.. the 61II is better.
options enough indeed.
post #29318 of 35178
560$ and Q-tuning option, good plan :)
that's about the same money i put in tuning mine. things get cheaper by the day lol
post #29319 of 35178
i have learned over the years that
that's the sub that i want as well ,hsu rocks and an excellent choice smile.gif
post #29320 of 35178
i want another yammie sw800 :D
only downside is the're nowhere to be found
post #29321 of 35178
that'a too bad dajojo ,maybe it's time for an hsu lol
post #29322 of 35178
nooooooooo ! :D
where most subs move air this one moves building lol
yammie :
HSU:
Edited by DaJoJo - 12/20/13 at 10:47pm
post #29323 of 35178
yeah and they say it is a budget sub. Not sure I'm going to describe it to the wife as a budget sub.
post #29324 of 35178
just tell her it's a new sort of vibrator and it'll do better then the washingmachine ^^
or a within-budget sub
post #29325 of 35178
post #29326 of 35178
that is a long walk from here lol
but there is shipping invented.
Originally Posted by Louis Bartay View Post
Then look for a RC-62 or the 62II. I had the first model 62 and played them with my Cornwall as fronts for several years until I watched a movie with 4 KLF-20/C7 and SVS PB 13 Ultra. Like I said these
5 KLF series are hard to beat for 5.1 HT use. You should be able to set the volume on a RC-62 to blend in with KLF-30 the RC series has a Ti tweeter. And maybe purchase Crites Ti diaphragms for the tweeters in the 30's to match the RC-62 or 62II
just a suggestion. It may take years to find a C7 but if you see one local pay the price for it, if you keep the KLF-30's. Bob Crites has KLF-30/Heresy drop in woofers that have a bit more punch to them. I always liked the twin 12" in 30 series better for music the twin 10" 20's .
YMMV on that as both are three ways and have that "Klipsch" sound to them when adjusted and placed correctly. Shame they quit making them.
post #29327 of 35178
yammie :
have to agree with you, mine did just that for the year plus 1 day it worked; mine has been broken for 10 years plus...
post #29328 of 35178
So I am still waiting for my new subs to arrive...also am thinking of going 7.2. Currently use a single rc62ii as rear surround, any opinions on using a 2nd rc62ii at the back? I dont want rs speakers,would maybe consider rb61ii or even rb81ii if price was right, I have my doubts lol.Im thinking cheapest would be another rc62ii,anyone against this idea?
post #29329 of 35178
I wouldn't use another center speaker for rears. Get the 61's or 81's.
post #29330 of 35178
I would use the same second speaker as the first for Surrounds (and/or Back speakers) and using 2 RC-62 would suffice, but not give you anything significantly over using almost any other alternative, imo...Heck, sell the RC-62, buy a pair of surrounds and spend more money on your subwoofer(s).
post #29331 of 35178
Hello my Klipsch friends, yal have been a tremendous help so far. I really appreciate it. Lovin my new RC-62!
But I'm having a really hard time deciding on what sub/s to upgrade to. Can yal help a fellow Klipsch lover out one more time? Thanks!!!
http://www.avsforum.com/t/1507029/two-pb12-nsds-or-one-pb12-plus
post #29332 of 35178
80% movies. I would look at two of these in that room for the budget you have.
http://www.svsound.com/subwoofers/cylinder/pc12-nsd#.UrbWffRDt8E
post #29333 of 35178
I would say get a front firing sub if you have a concrete floor. Down firing subs dont do as well on concrete from what I've read. I would get 2 PB12 NSD's for your size room. You should be more than happy with the end result unless your a real basshead! biggrin.gif
post #29334 of 35178
How about the 18"-driver flat-pack DIY builds for the same price (or less)?
See https://community.klipsch.com/index.php?/topic/145539-build-thread-4-stereo-integrity-18s/
post #29335 of 35178
He said no diy in a remark awhile back
post #29336 of 35178
Hey Heresy fans, here is a deal on a 1979 build pair.
http://phoenix.craigslist.org/nph/ele/4238500119.html
post #29337 of 35178
Wish I had the extra coin these are one of my favorites..........same year as my Cornwalls. Removable backs, plywood cabinets not MDF and X/O on a separate board.
post #29338 of 35178
RW-12D Port noise? Hello all, I have had this RW-12D for about 4 months and love it but the port noise is really starting to bug. I think I have it set up pretty good but on some scenes the port noise is very irritating. Has anyone been able to eliminate this? I am actually considering getting a different sub just because of this. Would elevating it help? Maybe getting one of those subwoofer foam mats I see everyone putting their subs on?
post #29339 of 35178
Run it in punch mode rather than depth. It cut my port noise all together
post #29340 of 35178
I just changed it over. I will play the movie this evening and see what happens. Thanks for the advice.
  Back to Forum: Speakers
