AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 2
post #31 of 22814
Anyone have experience making a center channel with Klipsch components? I'm wondering if, instead of paying 400 for a C7 to match my KLF30s, I might buy the horns and either 2 10" or 12" drivers from the KLF line, and make one.
I think I'm giong to a projector set up, so I'l lhave plenty of room under the screen for a big center...so let's say I got a KLF-10 for parts...I'm guessing just setting it on its side wouldn't be optimal since the high freqs would be offset to one side. I guess I would do a driver on the left, then stack the two horns in the middle, then a driver on the right? I'm also guessing a 3 way center would be preferable to the 2 way C7?
post #32 of 22814
I currently use RF-35's in the front with an RC-35 center, and RS-25 for surrounds. I have a 12" DIY Stryke Audio av-12 for bass. Currently have an HK-635 but will be comparing against a Pioneer Elite 56txi I picked up.
I have had all the JBL S,N, and E series-great value, but not Klipsch Reference.
post #33 of 22814
Capa,
I built my center utilizing all klipsch drivers. 2-10" KV1089 woofers, K52 midrange from a KLF30, and a alnico T35 horn tweeter. It timbre matches very nicely with my La Scala's and the bottom end does a good job of keeping up with the La Scala bass.
If you can find a KLF20 or 30 then you could use the cabinet and just change out the front motorboard so you have a horizontal center. Check ebay daily and you will come actoss some. You may have to buy a pair but see if anyone is willing to buy the other one from you or you could build 2 centers and then sell one. Check out my center channel construction page and see if its any help to you.
http://www.geocities.com/scooterb4u/Custom_Center.html
post #34 of 22814
Originally Posted by rcarlton View Post
My home theater consists of K-horn's in front with LaScala's in the rear. Center is a KLF-C7, sub is an SVS PB12 plus/2. Run them through McIntosh amps .
Holy Smokes ...
In the wrong hands that could be used as a weapon of mass destruction.
post #35 of 22814
Indeed. But they can be so sweet!
post #36 of 22814
I like Klipsch speakers and have owned several models. Currently my setup included Khorns for LR, KG4.4 for center and rear LR with a recent purchase of RS300 as my LR for my 7.1 system. I have a KSW12 as my sub. I power with a Marantz sr9300. My analog system is a michell gyro SE with Van den hul frog cartridge and michell tonearm. I have a Marantz dv8400 and Marantz vp12s2 as a projector. I love the Khorns as my 2 channel when listening to my vinyl. Sweet! One thing however, you need the right room for the khorns to be most effective. My last home, they sounded terrible because of a narrow room
My 7.1 system using the above mentioned system is just outstanding and really brings any movie to life. Some say the horns are too bright but I find them perfect for me. The only speakers that compare IMHO are 3 to 4 times more expensive (such as B&W nautilus series). I listen to music every night (2 or 3 albums) and never get tired of the sound. With a great analog system, I hear every thing from the smallest bell to the thunderous drums with a sound stage that brings the concert home. I am sold on Klipsch.
post #37 of 22814
I like the Klipsch for HT, but not so much for music. That horn crushes me! The RF 7's are sweet speakers, as are the K-horns, but having a properly designed room for the K-horns is a little ridiculous to me.
post #38 of 22814
RF-7s up front, RS-3IIs sides, RF-3IIs back, RC-3II center ... looking for a good local deal on the RC-7 ... yamaha rx-v1400 ... RMX1450 powers the RF7s ... two SVS PC+ 16-46 ... X1 modded with screenplay firmware ... RB-3s in the bedroom
post #39 of 22814
Oh I just gotta blow my horn, if you haven't clicked on my link, my items are
6 RF-7's, mains, rears & surround back channels
RC-7 center channel
RF3ii's are pulling duty for my dual surrounds located above my rf-7 surrounds
RB10's for my presence channels
Dual SVS PC-ULTRA's EQ'd with the velodyne sms-1
All channels are driven with Kenwood km-208 amplifiers (pics not up yet)
APC J-15 power conditioner with battery backup
92" tensioned electric draper projection screen
panasonic pt-ae700u projector
yamaha rxv-757 - until HDMI & HDaudio are firmly established
Buttkicker amp & LFE shakers
Wish list is room treatments, wicked amp & for HDaudio to arrive and be worth paying for!
post #40 of 22814
I auditioned speakers for about a year until a decided to go with the klipsch. In the price range i was looking for the best bang for the buck and best sounding were the klipsch. I paired them with a Pioneer receiver and they sound great for movies and ok for music but that has to do more with my subwoofer that needs replacement soon.
Sony 34XS955
Panasonic DVD-S35
Scientific Atlanta Explorer 8300HD
Pioneer VSX-D912
RC-25
RF-15's
RB-10's
KSW-10
post #41 of 22814
Anyone have RT-10D subwoofer? Thoughts?
post #42 of 22814
My Klipsh system consists of RF82's mains, RS62's surounds, RC35 Center, SVS PB2/Plus 2 900watt Subwoofer, which are connected to my Denon AVR-3805 Receiver, and Outlaw 770 Power Amplifier "200watts per chanel, 7 chanels", for my space "Townhouse" this system makes my walls and floor shake, I also use a Klipsch Synergy II Quintet II and a Klipsch KSW 10 Sub hooked into a Onkyo TX DS595 Reciever for my bedroom setup, you can tell I am a Klipsch kind of guy, I just love the Klipsch sound.
post #43 of 22814
RC-7 center channel
Good god man if your not deaf you must just be nuts (6 RF-7's) Thats gotta be just plain insane if you wont to get loud.
I just replaced a full Polk set up with a pair of RF-35's, a RC-35 center, RS-35's surrounds, & RB-35's surround rears & couldn't be happier. Im powering everything off three Crown amps. A 602 running my fronts, another 602 running my center & IB, & a 402 powering my surrounds. And at the moment just a single RB-35 running off my receiver for the rear center.
post #44 of 22814
Sound System for our small Library HT
Denon 4802R THX Ultra II AVR=>RF-7's/RC-7 up Front with RF-3's (A)/RS-7's (B) Surrounds with RB-75's in the rear. RSW-12 front sub/RSW-15 rear sub.
Sound System for the Bedroom HT
Denon AVR 3805=> RB-75's/RC-7 up Front with RS-3's & Phase Tech 10 sub in a 5.1 configuration.
FWIW, I highly recommend upper end Denons with Klipsch Speakers . Being able to have 2 sets of side surround speakers means having tremendous options when it comes to Movies Vs. Music.
post #45 of 22814
Yes I too really like this option. I use two sets of side surrounds plus two more on the back wall.
The Grand Carriage Cinema
http://www.geocities.com/scooterb4u/ScootersHT.html
post #46 of 22814
Granted, i only used a Denon 2805, but I wasn't that imressed with the receiver and the Ref 35's with it in particuliar. Does the Denon 4000 series have an improved sound? The Denon seemed to sound rather flat in my room.
post #47 of 22814
I have no experience with the 2805 but the AVR-3805 that I have with my Bedroom setup (listed above) is phenomenal and in no way could be described as flat. I have the Denon AVR 3803 driving a Klipsch Legend 5.1 system (KLF-20's/C-/RS-3/KSW-15 sub) in a 1200 sq ft workout room with a drop ceiling and it is more than able to drive that HT without sounding bright (which would be the problem with under-power, imo) much less flat.
I have never heard the RF-35 system described as flat but I feel the 3806(?) (or better yet a used AVR 3803 to 3805 being the best bang for your buck) would be the AVR to go with; IMO, the 4806 would be overkill.
FWIW, I listened to the RF-35 series and thought they sounded good, but I feel the RF-7's/RB-75's/RC-7 a considerable step above. They may be able to be found discounted since they are discontinued, but I wouldn't really count on it. My 2 cents.
{edit: I didn't mean to sound like I was ditsing the RF-35 system, which btw are great speakers at that price point. I also think people should stay in budget--sometimes I get overly excited by my HT's }
post #48 of 22814
Sony KDP-51WS550 HDTV
Yamaha HTR-5660 AV Receiver
Mitsubishi DD-6040 DVD
Klipsch RF-82 Main
Klipsch RC-62 Center
klipsch RB-61 Back
Working on the sub...
Promedia 4.2 THX in the office.
post #49 of 22814
I've been very happy with mine!
F-3's for L/R
C-3 for CTR
Sub12
S-2's for surrounds
My rears are JBL's from the "boneyard" right now, but I'll have these changed out soon.
I'm driving these with the Yamaha HTR-5990 currently. This combo has worked very well for me.
Greg
post #50 of 22814
No, I meant the Denon 2805/RF-35 series was not quite what I was looking for. I then tried an HK 635 and now have a Pio 56txi. The 56txi is a great fit. I just can't do the R-7 series due to their size-WAF. Once the basement is finished off then that is a different story. I had a chance to get a RC-7 for $350 and it was tempting. I am happy with the speakers though. I have a friend with the R-7 series so I get my fill...
post #51 of 22814
Seems like the Denon/Klipsch combo works well for others as well...
My System
Denon 3803
Klipsch KSF 8.5 Synergy Tower
Klipsch KSF C5 Center
Klipsch KSF S5 Surrounds
Klipsch KSW-10
Decent sound. Looking to upgrade to reference line and bigger Denon in a year or so with a dedicated theater.
SF
post #52 of 22814
Although I run my La Scala's with a big Onkyo dual mono block amp I do like my denon. The denon's amp section is used to run my center and surrounds and does so very well. As noted above a lot of Klipsch users also run with Denon, must be a reason for it.
Denon AVR 3801 Digital AV Reciever
Onkyo M504 Dual Mono Block Power Amp
Technics DVD A10 DVD Audio/Video Player
Pioneer DVL-909 Laserdisc/DVD Player
RCA HS10 HD Digital Satellite Reciever
Zinwell Briteview Pro 3000
Mitsubishi HSU-575 Hi Fi VCR
Infocus SP4805 DLP Projector
Draper Luma 106" Diag. 16:9 Screen
Klipsch La Scala's Main Speakers
Klipsch Heresy's Side "A" Surround
Klipsch RSS6 Side "B" Surround
Klipsch SS.5 Back Surround
Klipsch KSW-12 Subwoofer
Custom Built 3 way Center Speaker utilizing all Klipsch Drivers
post #53 of 22814
My question was not whether klipsch owners used denon. There are klipsch owners that will attest to every major manufacturer out there.
What I was wondering is in what model there begins to be some real performance. The 2805 did not cut it for me. But with an improved amp section, DAC's, etc, the 4xxx series might. Or is the 3805/6 truly better?
This is just the same as my trying out the Pioneer 1015 with the same speakers. I did not like it at all. Yet I now have the Elite 56txi which I love. You cannot say that all Denon and Klipsch go together. There are distinct differences throughout all the lines.
post #54 of 22814
I have the following speakers in storage. In the process of moving and can't wait to set it up in the townhouse
Klipsch Pair RF-83
Klipsch Pair KS-525-THX
Klipsch RC-64 (One heavy center)
For back surround Definitive Tech. Pair of BPVX/P
Velodyne DD-12
And Denon AVR-5805 pumping out the wattage to the speakers
Cable is RAM bi-wire (Yes I click the sponsor link to purchase it )
Now all I need to do is find a center stand thats about 2-3.5 feet high to hold that beast (RC-64)
I love the knife edge look of the RF-83
all in black
post #55 of 22814
I was just going to get a JBL sub, but I ended up with a full set of Klipsch. I had a Best Buy friend make me an offer I couldn't refuse! I sure don't miss my Bose 301s!
I listen to mostly rock and metal, and they sound great, plus movies have never sounded better. This is definitely just the beginning of an expensive hobby for me!
F3s, F1s, C3, and a SUB12.
post #56 of 22814
Nice HT BikerTrashXB. I too am a fan of having towers all of the way around.
FYI, I experimented with several different heights and came to the conclusion I wanted to keep the side surround's tweeters (which are pretty directional) at the same height as my mains (raised 10 inches). I also tilt my center channel and my 2 back speakers towards my ears--Really works for me.
post #57 of 22814
Ok I have to chip in....All my speakers are still in the box and I can barely stand it. I have RF7's , RC7, and RS7's. I was staying with a 5.1 but after reading a lot decided to go with a 7.1 I bought some 5800w's for the rear. I hope they do alright.
I got a great deal on a Rotel1098 pre and will go with a RMB1075 (5x120) for the surrounds and a 1080 (2x200) for the fronts. That will break the bank so to speak......Oh my pj and dvd player are also just sitting around. I will say I am now getting ready to pull my wires and cables then drywall will start. If you haven't guessed I am finishing out my basement...
I got my first pair of Klipschs maybe 10-12 years ago. Quartets. Low on the Klipsch scale but man did I love those speakers. Made me a Klipsch fan for life....
post #58 of 22814
I've converted 3 people already after hearing my demo.
My System
Sony DB930 Receiver
Klipsch KSW-12
Promedia 2.1 (great when compared to pc speakers of same cost)
If you own a 5.1 system of Klipsch reference towers, you should be very happy. You currently own the best "bang for buck" system in the world under $10K.
I.
post #59 of 22814
If only there was a customer loyalty program.... I'd upgrade to reference today.
I.
post #60 of 22814
Bet the sounds monsterous.Your prolly ready to upgrade the TV.One question though.How come you have F-1's for rears?They look weird especially stacked that high onto a old floor.I would have just purchased the S-1.
  Back to Forum: Speakers
