AVS › AVS Forum › Audio › Speakers › Klipsch owner thread
Klipsch owner thread - Page 11
post #301 of 35217
RB owners, I have a question for you? Have any of you placed you're Klipsch bookshelves on a shelf in your entertainment center. I have been looking at the RB-61s and the RF-62s. In my room the RBs would work out better but I would need to put them in my entertainment center.
I have been doing a lot of research and I have found out a lot about why you shouldn't put your bookshelf speakers on a bookshelf, or in my case, in my entertainment center. I'm quite happy with my entertainment center and I would really like to place my speakers into it. So I was just wondering if any of you are doing that now or if you have tired it? Did it sound okay or was there too much muddy bass from the EC?
The Klipsch RBs are front ported so I would think that would be better than a rear ported design, in this situation.
post #302 of 35217
You could certainly try it and see how much compromise you would be will to put up with, but it has been my experience that even good bookshelve speakers don't sound all that good in an entertainment shelf. They tend to become part of the shelf acoustically, which is not a good thing.
post #303 of 35217
I have a Yammy RX-V2400 and just ordered RF-62 mains RC-62 center. I'm going to be looking for surrounds soon and I plan on building a sub possibly with an TC Sounds LMS4100Neo (if they ever release the specs) and a Crown XTI1000. As for surrounds I'm still not sure....don't have a ton of money to spend but been considering Syenrgy's and Ref possibly even quintets.
post #304 of 35217
If your are going with the RF-62 and RC-62, I strongly suggest that you stick to the reference line for your surrounds.
post #305 of 35217
I think I may get a pair of RB-51's or RB-61's and then 6 months or so I'll maybe get another pair or a pair of RS-52's to complete 7.1.
post #306 of 35217
I have the RB-61 as back speakers for my RF-82 based system. Love them. Either of your choices would work fine.
post #307 of 35217
I 'm a big fan of Klipsch speakers and am in the process of rebuilding my theatre.
I already have a Klipsch C3 center. Here's my problem. I don't have enough room for floor speakers up front with this massive wall unit I got (only about 7 inches left). So I was wondering what you Klipsch folks thought of me buying some Klipsch bookshelf speakers like the RB-61's and putting them on top of the wall unit.
How do you guys think thew would sound for music as well as part of the surround setup?
post #308 of 35217
The following are the speakers in my system...
Center Front Academy, Fronts L&R Khorns, Cornwalls L&R rears, sub SVSPB12
My Office Heresy I's
post #309 of 35217
Got the RF-83's, RC-64, and RS-62 surrounds in my finished basement. It's a lot of speaker, but if you like it big and loud, these are great choices. I got them for 50% off MSRP at Ovation here in Indianapolis last month, so they weren't a bad price either. I have an older Denon-3801 receiver, waiting until after CES to decide what HDMI receiver I'll want to replace it with.
post #310 of 35217
Howdy all... hoping some folks a little more familiar with klipsch's line can help me with this.
I've listened to a lot of stuff in the past few weeks, and have decided on klipsch for the room I'm building. The room is ~15x15
The problem I'm having is that I want to do 7.1, and the placing of the side chanels is turning out to be a pain in the butt. The wall on the right side of the room has a 105" sliding glass door right in the middle of it. I've ordered a blackout curtain for it, which should have the added benefit of deadening some of the sound reflection from the glass -- but I can't hang speakers on it. The surrounds I was looking at (the RS-42s) are A) bigger than I thought (might not be so bad), and B) only made to be mounted on a wall. So that's out for the sides. it is still possible for the rear channels if the consensous here is that it won't over power the RSX-5s (mounted on these) which I was thinking of using on the sides instead. (any thoughts on that?)
For the front, I was thinking either RF-82s or RB-51s and for the center, the RC-52. I'm also not opposed to using RB-51's for the surrounds. As long as I can find mounts that are high enough, that is.
The whole thing is, since I'm limited to what I can do on the sides, I'm kinda stuck. I could go with all rsx-5's, but I dunno, I've always steered clear of small systems like that... just seems so......not big enough.
What are the thoughts on all satellites? or satellites for just the side, or the side & rear?
Any help would be greatly appreciated.
post #311 of 35217
where is the best online place to buy Klipsch products
post #312 of 35217
Does anyone have the the thx ultra 2 system ? Right now I'm torn between this speaker system and the Polk Lsi's. I am not familar with Klipsch so input would be great.
post #313 of 35217
Forgive my terminal newbieness, I'm getting ready to set up a HT for the first time.
I have a pair of Klipsch Chorus II, and would like to use them for the front L/R. I also have access to a Promedia 5.1 system with bad amp. Can I use the 5 satellite speakers for surround? Will they be horribly unmatched?
I will be buying an A/V receiver, and would like to spend the money on that, instead of on surround speakers if I can squeak by with the existing surrounds.
I also intended to not have a sub, as the Chorus II seem to do quite well in that department. Or at least no sub yet.
Comments or suggestions? TIA
post #314 of 35217
I'm not sure timbre matching is really possible with the Chorus II's, is it? So, that said, anything will not be a perfect match, so you might be able to get by with the ProMedia surrounds. Just don't expect big sound or power handling from them. Be careful not to pop some cones, hehe.
I have the ProMedia's and they sound really good for what they are. Like I said, don't expect big sound from the little guys.
post #315 of 35217
Long time Klipsch owner.. I have Promedia 5.1 in the office connected to the computer, I have Quintet IIs in my bedroom, and in my living room, I have a mix of a bunch of different pieces:
My living room equipment is about 8 yrs old now.
an RC-3 (When I bought this, I was told to go higher end on the voice (Center) speaker than the regular ones because voice was the most critical.
2 KSB 3.1 Bookshelf for my fronts
2 KSB 2.1 for my Rears
and a KSW 12 for my Subwoofer.
It's being driven by an Onkyo TX-SR803 which I just bought last year.
Of those speakers, is the RC-3 Still a good speaker to keep? I remember it costing me more than the others. Assuming I were keeping the Sub and the RC3, what Floorstanding or bookshelfs would you all recommend? I have speaker stands in the rear for the KSB 2.1s to sit on. Is there a particular reason to go with Bookshelf over Floorstanding?
The room is probably best described as a rectangle, about 12X8 or something in that range.
post #316 of 35217
Hi. I just got rid of my previous Klipsch Ref's for the new ones. I got rid of an RC-3 for the RC-62 and got rid or RB-5 8" bookshelfs for the RF-82 floorstanders.
Wow. What a difference. The difference in the RC-3 center to the RC-62 is HUGE. The highs are so much more smooth and accurate now with the newer horns (also, less bright) and the low-mid response is jaw dropping. This new center has more snare/kick thump than the old bookshelfs, yet alone the old RC-3. Must be the vented design.
And then there's the RF-82's ... what can I say, coming from bookshelf speakers? Mind-blowing difference in the fullness of sound. Crisp, tight thumpy mid-bass and low-end, smooth, pristine highs. It's amazing what Klipsch has accomplished in 6 years. I'm extremely pleased with the new Reference stuff. K really did a good job toning down the horns - my old Ref stuff would rip my eyeballs and eardrums out if I got carried away with the volume - 2Khz-8Khz was really exaggerated on the old stuff. The new horns and crossover points really fixed that IMO.
I think I'm gonna go listen to 'em some more, hehe. I just got 'em a week ago and had the chance to time-align 'em and throw in Saving Private Ryan in DTS last night. Holy smokes. Night and day, I could go on and on. Now I need to get rid of my 3802 and get a 4307 or somethin' - more powuh.
post #317 of 35217
Greetings Cob,
Nice to find you here. You may know me as psg on the Klipsch forums.
post #318 of 35217
I think I'm about to pull the trigger on two RF-82's and an RC-52. Best Buy/Magnolia Theater does not carry the RC-62 as of yet. Do any of you see any problem with that front l/r/c setup? Should I hold out for the 62?
One slight problem, the 62 may be too big. I'm having to purchase an omnimount center channel speaker shelf just to fit the 52 on my Sony LCD tv.
I was blown away by the rf-82's, and can't wait to have them sitting in my living room. By the way, the BB/Magnolia folks will really work with you on prices.
post #319 of 35217
Interesting. Is the RC-62 alot larger than the RC3? I think the RC-3 is a bit on the large size (It doesn't bother me too much as my Sony 50" LCD Projection compensates, but it takes up a considerable amount on the shelf above it.
The other issue is $$. I'm getting married in 3 months so I don't have the money to blow right now..
post #320 of 35217
The RC-62 is REALLY meant to go with the RF-82's - I would think the RF-82's might overpower the RC-52 ... however this is theory - they may work fine together, but I spent quite a bit of time listeneing to JUST the RC-62 vs. the RC-52 and the difference, to me, was significant. Fuller sound, thumpier mid-bass, which will translate into a better match with the RF-82's and better dialogue performance from the center. That said, try n listen for yourself. I would venture that if Klipsch recommends the 2 together, there has been some heavy engineering behind their recommendation. And no doubt, the RC-62 is friggin' BIG. It's really made me work a lot to get things "right" as far as furniture and placement - I basically had to build around the center channel. It was well worth it though. In this case, bigger is better.
The RC-62 is 1/8"-1/4" taller and at least 3"-4" deeper than the RC-3. It's a beast. But it sounds SO friggin' good - night and day from the RC-3. Almost like the RC-3 had a brown grocery bag over it in a side-by-side comparison (ok, a little exaggeration there, but significant.)
post #321 of 35217
I am thinking of upgrading my fronts to F3s and moving my F2s to the rear. Does anyone know if the F2s would make a good surround speaker or is it better to go with a true surround style speaker? My listening area is square with 12' ceilings.
Also, is there enough difference in the C2 to C3 to warrant an upgrade?
post #322 of 35217
Try and demo both speakers side by side if you can - in the Reference line, the difference between the dual 6 1/2's to dual 8's was pretty big - enough for me to pick the 8's.
I think using the F2s as rear surrounds depends completely on placement and your room. They might not sit high enough to be able to hear properly over couch backs etc. If they could be focused well enough, at the right height, I think they'd make great rear surrounds, but they sure wouldn't work with my room / seating.
post #323 of 35217
I need some help from you guys.
I want to pick up the RF-82's, because they were incredible when I listened to them. However, most of my listening will be the home theater variety, and not a whole bunch of music (although mp3's over the xbox 360 is really nice).
I want to also pick up the RC-62 center channel, with the 6 1/2 in woofers. Will there be a timbre match problem with the center and the floors, considering the woofer size difference? Should I pick up the RF-62 floors to ensure the best possible match?
If the matching will not be problematic, I'm definitely going with the 82's.
post #324 of 35217
The RC-62 is the matching center channel for the RF-82.
post #325 of 35217
I agree the RC-62 is a close match for the RF-82, but on the Klipsch website, if you click on the RC-62, it suggests the RF-62 as a "matching product." http://www.klipsch.com/products/details/rc-62.aspx
Obviously, they have the same size woofers, so that would be the perfect match.
I don't have a location to compare the rf-82's and the rc-62, vs the rf-62 and rc-62. For some reason, BB does not offer the rc-62 or the rc-64.
On a side note, if any of you have TV's (not flat screens) that won't hold a center channel on top, you ought to consider this omnimount center channel speaker shelf I found - it solved my center channel problems with my Sony KDF-60xs955 - which wouldn't hold anything on top.
Just search for Omnimount Center Channel Speaker shelf, and you'll find it.
post #326 of 35217
But if you look at the RF-82 Home Theater System, it matches the rf-82 with the rc-62.... .
post #327 of 35217
So by that logic, the RC-52 matches with the RF-62s?
post #328 of 35217
Gotcha. My question then, is this. Anybody have or has listened to the RF-82's with the RC-62 center? Have you also listened to the RF-62 with the RC-62 Center? Is there any difference?
post #329 of 35217
I heard the RF-82's with the RC-62 and the RC-52, but I was not able to do it at the same store. To me, the RC-62 definately made a difference. I don't think it was drowned out by the 82's. I did feel that the RC-52 would have definately been too small for the 82's though.
I think it's possible that the bit of the product page where it shows the matching speakers may simply not show everything.
If you're concerned though, try calling Klipsch on Tuesday and see what they say, I found them to be most helpful. 1-800-KLIPSCH. I wouldn't have thought to call, but Dr. Who over at the klipsch forums suggested it, and I'm glad he did. My call was about mounts, but based on my experience, I'd expect them to be as helpful with anything else.
I did not have an opportunity to listen to the RF-62.
post #330 of 35217
The difference will not be in terms of mismatch of timbre between the RC-52 and the RC-62. Each will do a good job as a center speaker. The RC-62 will move more air in a larger room, and will provide slightly more impact and natural mids for a fuller sound.
  Back to Forum: Speakers
