Originally Posted by GoodToGo1
How close are the speakers to you?
I think I may have only 2 inches space between rear port and wall..is there any down side to that?
I was reading your earlier posts and thinking you may be one of the best person to ask and bang, in comes your reply
I am sure you are enjoying your RF-82's!
I am sure you are enjoying your RF-82's!my Ht is my Living room - to really enjoy my setup - i should have more room and sit futher back - but cant have everything - 2 inchs is tight but you can try to angle them in a little too - that would help also -
i am sitting about between 4 feet and 5 at most from the speakers and TV etc. - - the closer you are to the wall - the deeper the bass - but they do need a little breathing room - if i had the room - i would keep mines at least a foot away - but i dont and they are 6 inches - give off great bass - its not boomy - just deep - being that you are using the 62's - they are not as deep - so you may just like them that close - would add to the lows -
there is really no way to know for sure till you use them in your place -
did you buy them already - would you be able to return them if they really didnt work out because of the space -
i was worried also about space and because of that - i didnt get the RF 83's - good thing - because the 82's are the max that can fit in my space also - i think you will like them - try to see if you can angle them - that way it will have a little more space to breath rather than keeping them straight in front the wall - you can try it both ways and see which sounds better -
post back when your done and listened to them -
