Originally Posted by bm01
Hey, folks. I have the Quintet II 5-speaker setup and I would like to upgrade the fronts to towers, but nothing too big, possibly a couple of F1's or F2's. I would move the existing two fronts to the back for full 7.1. I am worried that the Quintet II center won't suffice anymore. Any thoughts?
PS: I'm running a Denon AVR-789.
F2's would be a good choice. However, you're thinking is right about the center. While it would get you buy, I would try and go for the C-2 when you can. Moving the front sats to the back for the rears is a fine idea and will work great. In fact, that's exactly what people do with Quintet systems for a 7.1 configuration.
A dB is a dB is a dB
Now, with the addition of the 8008x3 the sound is fuller, the soundstage is larger, and the bass is tight and punchy..but over all volume..not that significant. I now have a 3806 and I like it's processing and adjustability over the 3805 much more. I compared the 43 and the 48 series, but for processing..I really couldn't hear any difference so I didn't spend the extra coin.
* I must say, in my room, it does a horrible job if so.* Learn something new everyday.* I stand corrected!* Thanks for showing me the light, guys.
