Originally Posted by
fireman325
If the RB-35 is working OK for you then great, but I think if you were to put the RC-62 in its place, you would be blown away at the difference it would make. Also for your surrounds, since your space is small and budget seems to be getting thin (a problem all too common around here LOL) I would recommend selling the RF-52's and buying a pair of RS-52's (or RS-62's if you can find a pair at a good price). The Klipsch wall-mounted bipoles are AWESOME. I have a pair of the 62's and they are the way to go. Not to mention that they're smaller AND you can easily mount them at the proper height. Click the link in my signature if you want to see some pics.
I never considered selling the rf-52's. I guess I figured the size would deter people for buying them. I know they are some of Klipsch's smaller towers, however; they are still towers. Maybe I should think about it, I do not know what the market would be however.
The RS-62 are the surrounds that I want, but I can't seem to find them for a price within my range, not even used. You got me determined to keep looking though.
As for the RB-35 that I am using as a center, it's going ok right now, I will try and put it through its paces this weekend and make some considerations. I do not have a reference point to compare it with the RC-62, I haven't even heard it, the specialty store where I bought the RF-82 and RF-52 went out of buisness last august. (That hurt, I loved that place). However, if I feel that I still need more with the center I can look again to the 62, I could always move the 35 to the living room setup. I do not like the Synergy center I have up there what so ever.
