Originally Posted by Chronoptimist
Am I understanding your post correctly, and you just don't believe that the delay numbers are accurate?
I have verified the delay numbers for my own set through various different methods, including but not limited to, high-speed photography comparing it and a reference CRT (1/4000s, 8fps) and measuring the audio delay introduced by the display for synchronisation. (changes with picture settings and matches other results)
Switching between game and theatre modes has an immediately noticeable impact on controlling games. Even if you don't believe that the measured results for game mode are accurate (the 33ms delay) the relative difference between game/theatre is.
For what it's worth, the difference between game mode and theatre is that it switches to 4:4:4 chroma rather than 4:2:2, drops to 60Hz from 480Hz and decouples the local-dimming array from the picture. (lags a frame or two behind the panel) The contrast is lowered to compensate for this. (only dims zones down to 3,000:1 rather than "infinite" black level)
Not sure I follow what you mean here, BFI does not operate at 30Hz. With my set, there is a subtle but noticeable flicker introduced when enabling 480Hz backlight scanning if you're looking for it. (and a very obvious drop in brightness)
Tests have shown that pilots can identify an aircraft from a single image flashed at 1/220s. (approx 4ms)
The best LCDs already cover the HD spec, increasing the gamut further is actually detrimental to image quality.
QDLED displays (rather than QD backlit LCDs) could prove to be an interesting alternative to OLED but I don't expect to see them for a number of years yet.
i raised the same question about qleds here a while back and got shot down by some stating their toxicity precludes widespread adoption. now we learn oleds have some toxic issues as well, so i'm not sure where we are.
