Isochroma, large OLED screens are definitely going to happen and I personally am looking forward to that. They do offer significant advantages over PDP and LCD. But the garbage you post about PDP is really tiring. You are the Auditor55 of OLEDS
Originally Posted by
Isochroma
Your 10-lumen-per-watt plasma tech doesn't yet exist, while OLED does. Not what physics says you can actually get out of a UV-excited phosphor.
10, even 15 lumens per watt has been demonstrated and prototyped in several different configurations. As for physics (LOL) how did you even come up with that one
Isochroma
….but that's not going to stop me from stating my opinion on PDP technology.
We all know about your vocal anti-plasma opinion. But that won’t stop us from correcting you whenever you post misinformation
Isochroma
The advantages of OLED are too many, and its potential easily great enough to surpass PDP.
The list of OLED advantages is shrinking every year they tack on to its ever growing TTM. What will the current products be like when OLED is “finally” released in HT size displays? Maybe we should follow your style and go over OLED problems and start spouting out doom and gloom for OLED? Fact is that all technologies have some issues that others don’t (including OLED). Both OLED and SED are not perfect by any means.
Isochroma
PDP is just an absurdly inefficient …….blah, blah, blah……
remember that a 100W incandescent gets 16 Lu/W, and 4' T8 triphosphor fluorescent 80-90 Lu/W, and metal halide 100+…..blah, blah, blah
The efficiency of a light bulb and that of a pixel can not be compared. A PDP pixel is essentially a tiny fluorescent bulb. Using your logic it should be 80-90 lumens per watt
Same goes for OLED pixels verses OLED lights.
Isochroma
Regarding SAH, it is not a defect but a positive attribute; flicker causes headaches, and a significant fraction of individuals can see it. Both fully held and short duty-cycle and schemes in-between have their values, depending on the use. However, not all technologies can support these different modulation schemes.
You didn’t even consider OLED-SAH until I pointed it out to you, now you are twisting into an attribute. The main reason SAH is used in OLEDs is to extend lifetime. This comes at the expense of motion blur. Improve lifetime and then you can tune the duty cycle.
Isochroma
PDP cannot, as it is currently designed, support continuous discharge because gas ionization is nonlinear, which is why it uses on/off PWM to obtain grayscales.
What are you talking about? Gas discharge is quenched as the dielectric layers become charged. Then the polarity is reversed and the discharge is repeated. Learn how AC-PDPs work before you speak.
Isochroma
That is an inherent defect of the technology, which is based on its fundamental construction and thus cannot be removed.
It is the principal of PDP operation, not a defect ??
Isochroma
It is possible to pulse the PDP's PWM faster to make the flicker less visible (or even invisible) but running circuits at all three: high voltage, high frequency, and high power, is a guarantee that you'll also get the other three: high cost, short life, high operating temperature….. Hotter electronics can't be done because the electronics already run too hot and have a relatively high failure rate, much higher than LCD
How is life reduced by increasing the addressing speed? And you may not realize this but addressing speed has been increasing every year in PDPs. Panasonic already has a 1080 line (16 subfield) 100Hz addressing speed on the market. So again, according to you this can’t be done (LOL)
Isochroma
Depending on its design, OLED can be fully held like LCD or flicker at 60 Hz. like PDP, or anywhere in-between. OLED emitters don't have the nonlinear characteristic of PDP's gas-fill.
Too bad it is limited by the lifetime, and BTW OLED emission is very non uniform and thus leads to severe mura.
Isochroma
Finally, OLED can do something neither LCD nor PDP can: it can run at hundreds or thousands of frames per second, since the emitter has a response time in the microsecond range. This allows a third alternative, rather than the duality of SAH/flicker: using interpolation or a high-speed external signal, it can show flicker-free silky smooth motion.
Which will just add to the already high cost and many people don’t even like the interpolation effect (including me)
