AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › OLED TVs: Technology Advancements Thread
OLED TVs: Technology Advancements Thread - Page 114
post #3391 of 5890
Originally Posted by rogo View Post
1) Again, it doesn't matter that LG that is using "white" OLEDs because they aren't. They are using a stack of red, green, and blue OLEDs to make white light. That said, this method is allowing them to use a fluorescent blue that has -- according to the people who make it -- better stability over time than the blue that other companies will use.
2) There would be two issues with the aging problem that could lead to burn in:
A) The blue layer aging differently at all will cause color shift over time. My sense is LG is shooting for something like 20-30K hours before that sets in at all. Even at 8 hours of use per day, that would equate to years of trouble-free operation.
B) OLED pixels will age -- just like plasma pixels. If they only have, say, 30,000 hours to half brightness, they will be susceptible to burn in. But, like modern plasmas, it will be tricky to achieve said burn in.
If they could actually use a white OLED layer, they could avoid the "blue problem", but since no such practical OLED material exists for the purposes of building a TV, they are not doing this and thus are not really getting any panacea from the Kodak method. Again, however, it is allowing a substituted blue material which should help.
Two of the key features of White OLED (yes, it's multi-layer device that includes Blue) for display purposes are its lifetime and its excellent color stability: all emitters decrease at the same rate. There is plenty of technical documentation from Kodak on the web as pointed out in several topics. One documented example has virtually unchanged CIE coordinates (less than 0.003 CIE units) after the 50% lifetime period, so that aging effects on color balance and grey scale should be minimal.
post #3392 of 5890
Ferro, I'm not arguing that point so much as pointing out the mechanism by which it's achieved -- presuming that it pans out in real-world use.
The stacking method doesn't magically allow the blue to age evenly when blue aging has been a problem. What it appears to be doing, however, is allowing for the use of a blue that can't be use in a non-stacked, non-white OLED. And that blue doesn't suffer the aging issue.
It's a technical point.
Anyway, I actually trust that LG isn't bringing anything to market that won't perform well for at least 5 years of heavy use (and 10 years of lighter use). But I believe Samsung will manage to achieve the same using their entirely different approach as well.
post #3393 of 5890
^^^ I would think that's "magical" I still don't understand why that would be the case.
There's a lot of time between now and then, of course. LG's manufacturing method is highly scaleable, but the timetable for these things has a way of getting away from what's intended. They will not be able to displace even a meaningful fraction of LCD production in 4 years, so there is no reason to sell OLEDs that cheaply that soon -- even if production cost has fallen that fast. They'd still charge at least a small premium since they will be supply constrained somewhat.
And your quote on the other thread. I just want to ask: How long does it take for OLED 4" top reach LCD 4" in cost parity? Don't you think it took faster than either of us even expected?
Originally Posted by RichB View Post
Are they using white LEDS with filters?
If so, then it the probelm would be limited to the degree that OLEDs reduce light output with age.
- Rich
It's OLED. Not LED. And it is not white. It is RGB stacked to produce white and later separated with RGBW color filter.There are many reasons why they do this.
Originally Posted by Nielo TM View Post
As far as im aware the curent OLED are based on AM
Yes, but genuine question: Does AM automatically means it is sample and hold? Most of the literature I read is that it is pulse based. And it is current driven vs LCD which is voltage driven though both are AM. Here's xrox's recent post:
Originally Posted by xrox View Post
PDP duty cycles is ~35% "effective"
CRT duty cycle is ~ 10% or less
LCD duty cycle is 100% intrinsic (can be altered extrinsically)
OLED duty cycles can be intrisically controlled
Your previous post suggests that OLED is inherent 100% S&H like LCD. It is not. As I said, manufacturers may choose to do so to maximize life.
OLED has the advantage of an intrinsic short response time and controllable duty cycle. This enables the optimization of motion via combinations of duty cycle control and interpolation or BFI.
Originally Posted by HDPeeT View Post
I play a lot of FPS (first-person shooter) games on the PC, and if you have a fast enough graphics card it can render many games (especially older, less graphically demanding games) at well beyond 120 frames per second. The display I'm using is a 120hz twisted nematic (TN) LCD that CAN accept a 1080p/120hz signal over dual-link DVI and ACTUALLY DISPLAY 120 unique frames per second, not the interpolated frames we talk about with 120/240hz TVs.
Thanks for the info. I'll have to read up more. I'm obviously falling behind because I've not read anything producing 120fps natively. What graphics card setup do you use?
post #3394 of 5890
Any "3D Vision" capable display will accept a 100/120Hz input, and any modern graphics card should be capable of sending it that. (it was introduced in 2008) Most of these displays are TN LCDs, though there are some DLP projectors as well.
Most games these days are console ports, where the graphics hardware is less powerful than PC GPUs by at least an order of magnitude. If you have SLI, it's not difficult to reach 120fps with most modern games. (personally, I find microstutter from SLI to be problematic, and stick to playing all games at 60fps)
If you aren't playing the very latest gameswhich is often the case with competitive gamingyou can run just about anything at 120fps.
post #3395 of 5890
It is still Sample and Hold, but since OLED doesn't have backlight or pixel response issues, you can simulate pluses very accurately without introducing flicker or brightness dip.
Also it has to be done due to the short lifespan of OLED.
post #3396 of 5890
You should dump NVIDIA and move to our side
120Hz cuts lag by ~8ms (from ~16ms).
Most consoles games are still 20-30fps, which has lag of 33.3 to 50ms. Add that on top of lag caused by the controller, processing and TV, well ...
post #3397 of 5890
Based on all the published material about the LG WOLED TV's, they are using White OLED with colorfilters. Which means that the blue filter will have the same deterioration (or non deterioration) as the other color filters.
Also no indication of stacked OLED layer(s).
Do you have any more accurate information that LG is using "stacked color OLED or are you confusing LG WOLED with Samsung's "Super" OLED?
True-OLED vs WOLED-CF
The basic OLED TV design (called a "True-OLED" TV) uses 3 color OLED sub-pixels (Red, Green and Blue) to create each 'pixel'. But some companies are using a different archicture, called WOLED-CF which uses four white OLED subpixels with color filters on top (RBG and W). This is also called a RGBW design.
Background informations about LG Displays WOLED-TV technology
post #3398 of 5890
I think you're right, Coolscan.
Yesterday I posted on the LG Official Announces 55" OLED thread that it appears LG is using four stacked white OLEDs, with three being filtered RGB, and one unfiltered (white). I posted a link to this article:
http://www.oled-info.com/kodak/kodak..._and_interview
I also bemoaned the fact that I couldn't find a diagram I had seen that supports this, but you just posted it.
So the stability of the white is the reason for the color stability of LG's WOLED. They get around the blue issue entirely by making blue (and red and green) with a filter.
You know, every time I see the name Kodak (who also developed digital photography, ironically, I feel sad that the US sells its patents, and that we presently are unable in many instances to conceive, develop, and manufacture in this country.
At least we're back up and running with the auto industry.
post #3399 of 5890
Frankly, I see no reason why Kodak couldn't develop this WOLED further and started selling it's own panels to others, except for financial difficulties they're in, but I think the company couldn't change fast enough and personally I think it didn't believe in it's own new tech, that it will take over so quickly.
Of course it's always 20/20 vision after the fact, but still I think Kodak wasn't changing it's ways fast enough even with the headstart they had. It's a shame, because Kodak was an Icon.
post #3400 of 5890
Originally Posted by pete4 View Post
Frankly, I see no reason why Kodak couldn't develop this WOLED further and started selling it's own panels to others...
Kodak sold all their OLED assets to LG in 2009, so I don't think this is possible.
post #3401 of 5890
Yeah. You have the great engineers and technicians, and then you have business people, marketers, lawyers and the rest who either support the innovators correctly, or screw it up.
Kodak was an icon, and now it seems they're focusing on printing technology. Funny, because the deposition of OLED material on panels is like and may become more like printing.
And you're quite right, ferro. Kodak gave up its patents.
post #3402 of 5890
Originally Posted by slacker711 View Post
There are two separate facts which the companies have separately announced.
1) Sharp is transitioning a Gen 6 a-si fab that was used for televisions to IGZO and it will be used for tablets with production slated to start before the end of their FY (ending March 2012). This is a large amount of tablet capacity and if Apple is not the customer they are going to have a problem.
2) Apple invested billions to insure their LCD supply a few months before Sharp made the IGZO announcement.
I dont think either Sharp or Apple has acknowledged whether an investment has been made in the company though it has been reported in the Japanese newspapers. The WSJ has said sources indicate that the IGZO supply is destined for the iPad 3.
I would put a very high probability that the story is true. Maybe Sharp will have problems and Apple will go with an alternatitive, but I certainly think they are trying to get it into the iPad3.
Slacker
According to the most recent rumors, Apple has dropped Sharp as a supplier for the iPad 3.
The reports so far have been a little light on details so it would be tough to say if this is a "They can't build enough displays for us" issue or an "IGZO isn't ready for prime time issue".
Makes me wonder what it means, if anything, for LG's OLED mass production plans. Is IGZO really gonna be a solution for OLEDs in the near term?
post #3403 of 5890
I vaguely remember them retaining the right to use their own technology for some number of years. Anyone know if anything like this occurred?
Moot point- I don't think Kodak could do anything with it now.
post #3404 of 5890
It's not quite there yet. Most of Samsung's phone lineup for 2012 uses LCD (yes, really). Only the higher end lines use OLED. But, yes, they've done well to drive cost down. Perhaps faster than we would've hoped, although in fairness to Samsung, they've also sold a ton of those phones -- more than we would've guessed. More screens = more learning curve effects = lower prices.
Color filters don't deteriorate meaningfully over time any more. The issue is that the white is made of three layers of OLED material and in the past blue OLED has deteriorated more quickly. As addressed elsewhere, the blue LG is using should have much less of a problem (or none) in this regard.)
I'm not confused, some of you are, however.
Listen, what you just wrote is true and unbelievably misleading -- as is that diagram.
No, that's 100% wrong. They get around the blue issue mostly by using a blue OLED material that is fluorescent and wouldn't work at all in a "conventional" RGB OLED. Why does it work for LG? Because all they need from their blue is for it emit a blue light true enough such that with their red and green OLED, the final output is white.
I've explained exactly how LG is doing this several times, but I'll have to draw a diagram that actually reflects their method, because the ones people keep linking do not.
The key facts are that:
1) Every pixel on screen does have 4 sub-pixels. The emitters for those pixels are all white OLEDs.
2) Every pixel on screen has three tiny flecks of color filter, one each for red, green and blue. In that regard, they make light almost exactly the same way an LCD does -- light passes through the color filter which is bonded to the screen front (or very nearly depending on protective layers and where the BEFs and ambient filters wind up). The reasons why this is better than LCD involve the pinpoint control of the light source, whereas LCD uses a light valve approach. The light emitters are very close to the screen on OLED, so the viewing angles will be better than LCD -- even using LG's method.
3) There is no need to "pattern" the OLED material at all. It's applied in three layers using vacuum deposition. I'm not sure of the order, but for our purposes, imagine it goes red, then green, then blue. Since OLED is transparent by nature, the light all passes through the layers and comes out as white before you see it. Each transistor on the backplane controls the equivalent of one sub-pixels worth of OLED emission... One fourth of a pixel of white light. Whether that light emerges from the panel as red, green, blue or white is determined by the patterning of the color filters placed in front of the OLED layers.
4) It's convoluted to do this. Take red green and blue to make white only to use white to make red green and blue... But it results in much simpler manufacturing and allows for two key layers -- the TFT backplane and the color-filter front -- to be almost identical to what's being done on LG's existing LCD production. They aren't identical since LCD uses 3-subpixels on LCD not 4 and therefore patterns its color filters very differently, but the basics are very similar. LG is already more than expert at making TFT backplanes and color filters...
And their method of depositing OLED material is very simple. I suspect their only real challenge in manufacturing is getting the deposition just right so that the backplane illuminates the OLED material in a uniform fashion so that those 8 million sub-pixels turn on as expected and are all very similar in brightness.
Kodak's method appears to have been genius, even though it will result in a more power-thirsty display than Samsung's "true" RGB OLED. LG's displays will still use less power than LCDs (which require a lot of light because of the way the LC material blocks so much of it and the polarization requires much light to be tossed) and will be slim and lightweight. LG's method is not entirely optimal for making mobile displays, but that's not a market they are currently tackling with this method anyway.
post #3405 of 5890
^^ Just want to add that:
1) The subpixel you see is the color filter
2) It should be FOUR tiny flecks of color filter: RGBW
There is no white emitting layer. They probably condense it as white as the net result of the RGB emitter is white.
This is breaking news if true as the whole supply have been ramping for iPad3 since December. Can you please provide link?
Interesting... So it is PERCEIVED as a pulse even though it is actually S&H? It is more platypus than I thought.
If you aren't playing the very latest games—which is often the case with competitive gaming—you can run just about anything at 120fps.
Probably that's the problem with using Tom's Hardware as a reference.
post #3406 of 5890
I wish they stop trying pulse driving on current LCDs. All it does is creates multiple ghost images
post #3407 of 5890
http://english.etnews.com/news/detai...d=201201100006
I believe that was the original source. There are about ten billion other articles out in the last week saying Sharp has been dropped as a supplier for the iPad 3.
It'll be interesting to find out if that has anything to do with IGZO TFT quality/yields.
post #3408 of 5890
Really? 10bio? Amazing how cute people can get overnight. Do you actually know how much capacity Sharp has committed to this project?
I would take ETnews with a pitch of salt. Sharp was meant to replace CMI which cannot make retina display, and to a lesser extent Samsung for obvious reasons. I would be keen to see what Sharp say early next month during their earnings results
post #3409 of 5890
I wasn't trying to be cute, I was just pointing out that the ET article has been parroted by just about every single Apple fanboy site on the internet.
post #3410 of 5890
I wrote three tiny flecks, because where the white emission occurs, there won't be any color filter in theory. The white will simply pass through the front glass.
Yep.
post #3411 of 5890
It's been mentioned a few times already and seemingly over looked when I read this thread.
There is no such thing as a "white" OLED subpixel with today's tech they're using. They use a blue OLED which also emits energy (light) near ultra violet and they add a mix of phosphors. The mix of phosphors causes some of that near UV spectrum to be converted into red and green. Thus you end up with a "white" OLED when it all combines.
So technically speaking the LG unit is all blue OLEDs + phosphors...
There's a lot of things to discuss, like are they really doing this for the color blue?
BLUE OLED + phosphors = white output -> blue color filter
Seems a bit inefficient to me but maybe you get a better blue out of it to hit the CIE target.
Or is there some organic material they can use to make an efficient white OLED? I've seen some documented for prototypes but they all seemed to have issues.
Perhaps I have my info wrong, anyone?
Articles like this make it sound just peachy
http://www.oled-display.net/backgrou...tv-technology/
One of the concerns for OLED technology has been the lifetime of the blue color, which has historically been less than red and green. Over time, this results in very dim blue pixels and shifting of the display toward yellow. With this new architectures to overcome this issue, in particular a very stable White OLED formulation, which can be used in combination with a color filter array to produce a full-color display. LGs White OLED architecture boasts a lifetime in excess of 100.000 hours.
LGs W-RGBW approach does not suffer from this problem because Lgs white emitting structure is highly stable and the white spectrum does not shift in color during long term operation. Hence the color emitted by the OLED display remains constant over time. The benefits include scalability, no need for shadow mask, lower manufacturing cycle time and better production yield.
Perhaps my question should be what is LG using for a white source?
post #3412 of 5890
Not true. Polychromatic single layer white OLEDs are made by doping RGB emitting materials into the single layer IIRC.
I'm not sure what exactly LG's design is. I suspect it is a version of a two stacked design combining monochromatic single layer blue with polychromatic single layer Red and Green.
post #3413 of 5890
Thank you for this information, and for your informed posts in general. Given that LG has not released much material about their design, all of this is a real learning curve.
post #3414 of 5890
Perhaps I mis-spoke.
I said...
Covered the other designs I've read about
I've seen stacked designs and or aggregate side by side designs that combine RGB to make white but they are all prototypes. And they all still have stability issues/compromises.
LG claims to have a 100,000+ hour stable white. In order to make that claim they would have to use an inorganic blue I would think as you said. Or have hit a home run on their materials for blue
post #3415 of 5890
Perhaps I misunderstood?
I thought you meant that WOLED had to be three distinct RGB layers. Sorry.
The blue is not inorganic? The LG papers that I have only cover a two stacked design using blue fluorescent material and a seperate RGY phosphorescent material mixture. They claim a synergistic brightness effect is achieved using this design.
They claim increased blue life via new ETL and non-carbazole HTM.
post #3416 of 5890
Based on articles about Kodak's work with Novaled, it appears that LG is using Novaled's stacked White OLED. The same 100,000 hour lifetime is mentioned.
http://www.oled-info.com/lifetime/no...ent_white_oled
http://www.novaled.com/news/2011_07_13_pr.html
post #3417 of 5890
(...) LGs W-RGBW approach does not suffer from this problem because Lgs white emitting structure is highly stable and the white spectrum does not shift in color during long term operation. Hence the color emitted by the OLED display remains constant over time.
... but this doesn't mean the shift in brightness won't occur. So burn-in is still possible. Do you guys know any manufacturing method for compensating the life curve of oled materials in per-pixel (not per panel) regime?
post #3418 of 5890
Correct that makes sense, yes burn in will be possible. My thoughts when making those posts was 100% directed towards the color of white (white balance) being stable in the long run.
I read a patent on a compensation algorithm last year sometime for the white balance. Wish I would have posted it now. Finding it again will probably be a pain.
post #3419 of 5890
Thanks, that'll help fill in some of the gaps for me. If these numbers jive LG's OLED set should be really good.
Be interesting to see how Samsung is doing their blue emitter.
post #3420 of 5890
Filling in the gaps is an apt way of putting it. Understanding LG's design is a work in process for all of us.
It sure looks promising, even at this point.
