AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › OLED TVs: Technology Advancements Thread
OLED TVs: Technology Advancements Thread - Page 124
post #3691 of 5872
Oops, Samsung/CNET retracts the spring launch date...reiterates second half launch.
http://crave.cnet.co.uk/televisions/...ring-50006947/
post #3692 of 5872
How would one mount an OLED tv to the wall. Isnt the tv too thin for mounting screws? Also, are all the internals to run these (LG or Samsung) OLED TVs contained in the monitor?
Also, isnt an HDMI plug too big (most of HDMI blugs are deeper than 10 mm)?
post #3693 of 5872
http://www.avforums.com/forums/forum...y-day-1-a.html
Sony had three Professional Monitors set up, a CRT from 1999, an LCD from 2006 and between the both, an OLED from 2011. With the lights out the blacks on the CRT looked far better than the LCD, as you would expect but the black levels on the OLED were just astounding, completely black, so much so that you couldn’t see the screen at all. The image accuracy and colour performance was also very impressive and the pixel response was as quick as the CRT screen. However before anyone starts getting excited, the 25” OLED Professional Monitor sells for 25,000 euros but at least its good to see that Sony are working on OLED technology. It was also good to see just how incredible the image on an OLED screen can look, it truly is the new black!
post #3694 of 5872
Saw that coming a mile away.
They are going to have to make choices about how the final product works.
The LG prototype had no electronics on board and needs to be tethered to a port/power box by an "umbilical". I've spoken repeatedly about how much people hate that design. Some AVSers like it, but really, not one model with that design has ever been successful or liked. It's an option for LG, however.
Alternatively, they can add a small amount of depth to the design to support standard plugs and cables.
As for mounting, so long as they have a way of attaching a mounting plate, they'll be fine. The design is light enough that they can create a small system of rails/grooves and let you slide a plate into then then lock that down with a couple of tiny screws. The plate would be designed to work with VESA standard mounts.
post #3695 of 5872
Do we know the width of this 55" Samsung? Smaller form factor may let me go bigger in the same space and let me replace 50" Pro110.
post #3696 of 5872
If they keep getting lighter, you'll be able to mount them on the wall with these.
post #3697 of 5872
Originally Posted by specuvestor View Post
Doesn't even look like new display tech. Looks more like a substitute for color filter. IMHO not impossible as an improvement for existing tech but it's a chicken and egg problem since REC709 gamut is limited anyway. You need better gamut spec for this to be useful.
We have a winner! The whole production chain would need to change. Again.
post #3698 of 5872
^^ It's just color filter, not the entire chain
Again as discussed on multiple threads, these pictures are good marketing tool, but not totally truthful. Light bounces off the back structure of CRT and plasma while LCD will block light. OLED cathode can be transparent.
But better comparison for AVS is in a dark room, where OLED will be like invisible while giving other displays more justice
As rogo mentioned, it would just be like hanging a picture with the right THIN mounting plate
And yes as I mentioned before, I think these sets would have separate box and probably we would see a "as-it-is monitor" comeback in TVs
post #3699 of 5872
I did see a press release from Lg that said they are going to have 2 options If its on a stand all the hook ups that are thick (hdmi...etc) are going to in the stand.
If it is mounted the TV will have a back pack(removable) making it thicker no size listed but I would guess maybe 1/2-3/4 inch or so.
So they are thinking of what people want.
Samsung said they are keeping it all in the base. I did not see anything about a wall option could just not be released yet.
post #3700 of 5872
I'm rarely in a position to predict anything, but in this case I'm confident that all OLED displays will have a "hanging" option.
post #3701 of 5872
Bravo to LG then, that's the right approach -- especially if the stand piece is somehow able to be converted into the backpack.
I see the future, and it matches your prediction.
post #3702 of 5872
I wish I could get my wife to read AVS.
post #3703 of 5872
This was Samsung's solution to mounting the C9000 series from 2010.
I'm guessing whatever they come up with for OLED will be along the same lines.
http://video.search.yahoo.com/search...-s&fr2=piv-web
post #3704 of 5872
That looks pretty cool.
I would concur that the end result will be somewhat similar.
post #3705 of 5872
Looks like kind of a pain in the ass to me. I prefer the LG back pack idea.
I do agree I can't imagine Samsung being that short sighted to have no option for wall mounting.
post #3706 of 5872
I must of missed it. What's the back pack idea ? How does it differ ? On the surface it seems to me that they would be the same thing. Being that the Samsung solution serves as a base and a wall mount ?
post #3707 of 5872
haha agreed. Looking at that Samsung video I kept thinking "holy crap, that looks complicated as heck to do for the average person."
They need to come up with an easier way than unscrewing and screwing lots of screws.
post #3708 of 5872
Screw drivers are just too high tech.
post #3709 of 5872
Behold the idiocracy (not posting to incite, just a general trend that can be seen).
post #3710 of 5872
Konica Minolta's first commercial OLED inkjet printing head will be available to display makers this spring.
http://www.flatpanelshd.com/news.php...&id=1329392549
post #3711 of 5872
From the link: "According to industry sources, Dupont's OLED printing technology is not optimized on the sub-pixel level, however. Each pixel on a display panel requires three sub pixels in red, green blue (RGB) to form one pixel."
Can anyone explain what they mean by this? I'm sure Konica is using RGB.
post #3712 of 5872
I read that too. It implies they can print OLED material, just not very well. Since the "very well" is the entire problem with RGB manufacturing of large sizes right now, I don't really know what to make of that comment.
post #3713 of 5872
Any guesses when we might be hearing more info on the Samsung or LG OLED tvs?
post #3714 of 5872
Some go as high as 35,000-50,000 hours we don't have the first gen to say yet but Oled that lasts 10plus years is way more than most people keep their sets around and long enough for me.
At $10,000 for a 55" set, my freakin grand kids better be able to use it.
CES 2013.
post #3715 of 5872
^You're taking bets on neither of them making it to market in 2012 then?
post #3716 of 5872
I really doubt you'll hear much of anything before the summer. And I'm very skeptical of Samsung shipping this year.
post #3717 of 5872
They'll rather use the holosuite.
post #3718 of 5872
The stage is set.. .and not unexpected:
" Feb. 20 (Bloomberg) -- Samsung Electronics Co. said it will spin off its unprofitable liquid-crystal-display division as the company changes its focus to the next generation of TV displays.
The new company, provisionally named Samsung Display Co., will be set up April 1, Samsung said in a filing today. Samsung may merge the unit into the Samsung Mobile Display venture that makes organic light-emitting diode, or OLED, panels, Nam Ki Yung, a Seoul-based spokesman, said by phone.
Samsung’s LCD business had an operating loss of 750 billion won ($668 million) last year as TV sales slowed. Merging its panel-making operations will help the company expand its OLED business by utilizing LCD-manufacturing resources, according to Korea Investment & Securities Co. and Hanwha Securities Co."
post #3719 of 5872
Me too. I am not super set on that larger blue subpixel Sammy will have to use seems like it will make a blue shift in the colors.
post #3720 of 5872
Yes, I think I have a $5 bet with spectator or saprano that there will be no OLED for sale in the US before Dec 31, 2012. I'll have to check. Good news for me so far is Samsung and LG announced there 2012 model available and pricing sheet and there is no mention of either OLED set.
http://hdguru.com/samsung-2012-hdtv-prices-leaked/7349/
