Hi,
I am building a HTPC which also acts as a home media server.
I have the ASUS K8N-E Deluxe motherboard which comes with dual RAID controller. The RAID 5 chip is Silicon Image. I plan to use RAID 5 for fault tolerance with maximum capacity. I currently have 3 300 GB Maxtor drive configured for RAID 5. But after I get it working, I have many concerns about many possibilities of losing data.
First, RAID 5 was first configured with its driver and XP partition and format it. Thus, it seems that if either XP or the hard drive went bad, I will have to install a fresh XP again. But can the new driver and XP recognize the RAID 5?
Second, if the mother went bad, can I use a different RAID 5 controller to retrieve the data?
I been told that since RAID 1 has mirror image, in the worst case, if 1 drive is still good, I can simply take that good drive and plug it into any PC and be able to retrieve the data just like a normal drive. Is this true?
Your advice is very appreciated.
Duc
Duc
