AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › OFFICIAL Toshiba firmware update thread: 2.0 and or CD is here!
OFFICIAL Toshiba firmware update thread: 2.0 and or CD is here! - Page 104
post #3091 of 3260
Originally Posted by Gate13 View Post
Hi everybody,i was not here a long time...
i'm updating my Toshiba HD-A1 player via ethernet connection,how long does it take normaly?because its been 30minutes since it started.
sorry for my english.
mine take about that time to, i don't use the Internet update anymore cause of that, i download the file now burn into CD and update it, is more fast take like 2 or 3 min that way
post #3092 of 3260
Oh i see,well thats another way to go.Never had problems so far?
post #3093 of 3260
no never had any problem
post #3094 of 3260
A1 would not play Lady in the Water without 2.0-
so I updated to 2.0
Disc plays, but picture quality looks soft.
(I checked to make sure I was playing HDDVD side- I was.)
I suppose it could be the disc transfer- but anyone else notice a softer image after update?
post #3095 of 3260
bokes,
Verify that the player is outputting 1080i and that it didn't change to 480 after the firmware update.
post #3096 of 3260
so I updated to 2.0
After you update the player you must reset the video resolution to 1080i or 720p....
post #3097 of 3260
This is probably a dumb question, but I have to ask:
If my HD-A1 only has 1.0, do I need to download and install 1.3 and 1.4 BEFORE I install 2.0? Or will going straight from 1.0 to 2.0 fix all of what was included in 1.3 and 1.4?
post #3098 of 3260
Pretty sure you can just load 2.0 and the previous updates will be included.
post #3099 of 3260
All previous updates are in 2.0, so just load that 1.
post #3100 of 3260
Can someone please tell me how to find out what firmware verson my A1 is running? Thank You
post #3101 of 3260
Guffy1,
Setup>General>Maintenance>Update
the first 2 digits of xx/xx/xx gives you the version.
post #3102 of 3260
I've been reading these pages looking for solutions to my own issues with the
HD-XA1.
1>Such as the softer image after the update
2>Pressing the Door button and the silver drop down door would close onto the DVD tray b/c it did not retract anymore by that one button . You have to use both open/close DVD and the door button.
Anyway, my point to this is ...........I saw the solution mentioned in this forum somewhere ...... ............... How To Fix these issues
Unplug the power cable from your Player........... for at least 30 sec. if not more
then let it reboot after you plug the power back in.
All my issues were resloved . Hopefully yours will too.
post #3103 of 3260
Heeeeeelp pleeeease!
Ahg! I've been trying to get my A1 firmware updated for over a month with no success. I've tried downloading directly via ethernet - wouldn't download. I finally actually got a hold of the toshiba firmware update disc (from a store)....STILL WON'T UPDATE MY PLAYER!
Has anyone had this problem? Anyone seen a solution?
I've had King Kong in HD now for so long...probably THE film I wanted HD-DVD for, and I can't even watch the *&#(&$%* thing!
(Sorry, but I'm truly at the pulling my hair out stage!)
post #3104 of 3260
R Harkness,
Please report on exactly what you did before attempting the online update (if anything).
And what is the origin of the update disc you are talking about.
post #3105 of 3260
I simply followed all the instructions for the ethernet connection (including unplugging my modem first for a while etc). I got some download error code (which I reported here before). Over and over.
It just never worked. The other option was apparently (via the instructions) to get some proxy id or numbers from my provider. My provider insisted those weren't needed, that the network just didn't work that way. If the download was going to work, it would work exactly as I tried it.
Next I downloaded the software update from a link on this forum and burned it to DVD. It wouldn't play at all on my HD-DVD player.
Finally, after weeks, I got hold of the official Toshiba firmware disc at a local AV store. The guy tried to update my A1 and we got the "update failed" error over and over. Sigh. He said he didn't know what was going on, that he'd updated plenty of A1s with that disc and had just used it.
I took the disc home. Have tried numerous times to load the firmware and I get the "update failed" every time.
Going nuts here.
post #3106 of 3260
Did you do what is required as stated in page 44 and 45 of the user manual? Did you set DHCP and DNS to ON?
It should be burn to CD, not DVD. And it should be burned as an "Image" file. If after unzipping you see the file with a .nrg extension and if you have Nero software, clicking on the file will open up Nero and it will be ready to burn in the "Image" format.
Going nuts here.
Once the CD was installed in the tray, you saw the update request question on your TV screen? And you clicked YES then you clicked OK?
Then you got on the player's screen the progress in %?
post #3107 of 3260
First thanks for the help!
It's been a while since I did it, but I do remember following the instructions regarding the DHCP and DNS settings. So I'd say "yes."
Ah. I'd originally thought I needed Nero, but was later told (on this board) that I didn't need it. I don't have Nero. So that throws that out the window (?) Yes it has the .nrg
file extension.
(BTW, I actually burned it to CD first, before DVD. The CD wouldn't play either.
Yes I got the update request. I choose "yes." Then I don't see any progress number report. Instead it says "Updating software, please wait" or some such thing. Then after about 4 minutes "Update Failed, wait a while and try again."
(Which I've done over and over).
post #3108 of 3260
any rumblings about 2.1 (or greater) yet...?
post #3109 of 3260
R Harkness,
Suggest you call Toshiba.
post #3110 of 3260
R Harkness,
Seems odd if you have the official upgrade disk. If you still can't get this resolved by Monday, PM me and I will send you the copy that I burned and used to upgrade my A1.
- Rich
post #3111 of 3260
Anyone have a 1.4 firmware that I can flash to and then try to flash back to 2.0
I am having problems with the HDA1 not playing HDDVD's and giving me an error message of Ox81000C03. I was told that it sounded like a firmware problem. I am guessing that one cannot just reflash 2.0 if 2.0 is already listed as the firmware on the player.
Any help would be appreciated
post #3112 of 3260
Once you have updated with version 2.0, you cannot go back to an earlier version. Some people have updated more than once with a 2.0 disc.
post #3113 of 3260
That's not completely true. You CAN backup to the previous firmware. The player just won't play HD discs with that firmware anymore. So, for his purposes going back and then re-doing 2.0 would work. I don't think the player will execute the update if you already have the version to which you are trying to update.
Having said all that, I'd be very surprised if this process fixed the real problem but its certainly worth a shot.
post #3114 of 3260
My old A1 had issues reading HD DVDS("NO DISC" error).
I was running 2.0, but figured it wouldn't hurt to try and reflash 2.0 again.
I was able to re-update to 2.0 again(burned disc), but it didn't fix the issue I had.
post #3115 of 3260
I don't know about you, but I have read far too many horror stories about firmware 2.0 on these forums with no "consistent" explanation except the obvious one.........The firmware is poorly engineered.
Non-gamblers have an alternative to get better sound.
Using the superior Firmware 1.4:
Hook up the SIX analog outs on HD-A1 to the SIX multi channel analog ins on receiver. I have a Sony STR-DE885 receiver.
Set movie to normal Dolby 5.1 (NOT DOLBY TRUE HD) and the HD-A1 player's audio to "bitstream" in the Setup menu.
Set receiver to "multi channel" or whatever your receiver's setting is for the multi channel inputs.
Huge improvement in sound over inherently bad HD DVD to DTS bitstream audio. Huge improvement over the 2-channel Dolby True HD.
It brings the sound up to the superior sound level that comes from any cheap SD DVD player and SD title.
It sounds really good that way and avoids possibly trashing your player's high quality video with poorly engineered 2.0 firmware as compared to properly engineered 1.4 firmware. If you now have firmware 1.4 don't DOWNGRADE to 2.0
2.0 will be the last. Makes no sense from a business standpoint to develop new firmware for an outdated player now that the HD-A2 is out. Since claimed sound improvement is the only reason to gamble with 2.0 you now have an alternative.
John
PS: The above statements regarding the sound are the collective opinion of my 15 regular evaluators and viewers at my home theater. None had a differing opinion this time.
post #3116 of 3260
Craftech,
In the player's Setup for Audio, the "Bitstream" setting can be selected only for:
SPDIF (digital connection), and
HDMI
In both cases the sound decoding is done by the receiver and not the player. (For HDMI, to have the player do the decoding, the player needs to use PCM)
The 5.1 Multichannel analogs will only transmit in PCM. All audio codecs can be sent via the analogs, DD and DTS plus the new ones DD Plus, DD TrueHD and DTS-HD. Of course CD audio is in PCM by default and the HD-A1 is an extraordinary CD player.
With your present firmware, your DD TrueHD can only be in Stereo format, as you know. On all HD DVD's I believe you can select DD Plus.
As a matter of interest, my first HD-A1 had firmware 1.0 and my present one has 2.0. The PQ is very good in all respects.
As for DD TrueHD:
I was most impressed with the sound quality of the dialogs with "The Perfect Storm". It was as if the actors were in my room and not using an electronic mike of any sort. The surround aspect of DD TrueHD can surprise you, in the same movie one scene below decks while several crew members are talking, one of them comes out from the head and the door closing is so real that I turned my head to see who was there to my left.
For special effects in DD TrueHD, "Batman Begins" gives you a good ride from an audio standpoint.
And "Phantom of The Opera" is offering wonderful music and singing in DD TrueHD. But that movie is one of the first ones in HD DVD and has the lower sound volume... therefore, one needs to increase volume.
post #3117 of 3260
Craftech,
HDMI
As for DD TrueHD:
Glad it's working out for you, but hardly a recommendation for a gamble. "It worked for me therefore it will work for you". I am sure you have read as many horror stories with no consistent pattern here as well as I have.
My method delivers sound on a par with SD DVD 5.1 audio (hard to beat) whether it is my home theater receiver doing the work or not. Two channel True HD didn't impress me nor the fifteen others who came to this conclusion after extensive A-B comparisons. Jacking up the volume produced audible distortion that was especially noticeable during quiet passages. It is NOT a solution. The industry missed the boat with the audio for this format and I cannot in good conscience recommend that people gamble on 2.0 with their expensive HD DVD player just to bring the audio up to the superior level of a cheap $40 SD DVD player when there is an alternative as I described above.
A simple search on these forums reveals this horror and the anguish of those who have no way to reverse this travesty of technology called firmware 2.0
John
post #3118 of 3260
WAIT!!!
I just thought of the ULTIMATE solution to the bad HD DVD audio tracks the movie industry created with this format.
Since the industry has pretty much been releasing box office flops on HD DVD why not buy the SD version in the $5.00 bin at Walmart and hook THAT up to your $40 Durabrand Sd DVD player and sound system.
Then you can connect the video of the $40 player to a little TV for the purpose of synching your expensive video system's HD DVD picture (only) to the cheap SD title's superior audio and have superior Dolby Digital 5.1 or DTS audio and beautiful HD DVD video for only $5.00 per title.
John
post #3119 of 3260
Craftech,
When you use SPDIF connection from the HD DVD player to your receiver, you get the very same DD or DTS surround that you get on a standard DVD player. There most be some basic thing you don't quite understand... with digital connection set to "Bitstream" it is the a/v receiver that does the decoding and there is no difference between an HD DVD and a standard DVD for the same movie under these circumstances.
post #3120 of 3260
Craftech,
The ears if fifteen people say otherwise. Try it yourself. The movie industry screwed up here when they authored the audio on the HD DVD titles as compared to SD DVD titles. I am reading similar complaints on the Blu-Ray forum.
John
  Back to Forum: HD DVD Players
