Originally Posted by Garman
That's exactly what I am using, also as far as the counterfeit knock offs it was a huge problem years ago, but Dynaudio pulled the raw drivers from the market as you use to be able to get kits and build your own from Madisound in Wisconsin, but the cabinets and crossover were very different.
May I know what AV receiver you are using to drive the C2s/SCX/SRs? And what stereo amp are you using?
For the stereo amp I am considering the Gryphon Diablo, Musical Fidelity M6PRE/PRX, Plinius 9200, Pass Labs INT-150 and the YBA Passion 600 PRE/AMP. For the AV receiver I will be using Pioneer SC LX-83 but my main concern is that it may not have enough power to drive the power hungry SCX center. I considered Excite X12s as the rears before because an independent lab test showed they have a nominal impedance rating of 10 ohms instead of 4 ohms that Dynaudio humbly claims, but I think the SRs will be driven properly by many good quality AVRs.
Also many thanks for the link in another thread, by close examination my wife and I both conclude even the budget Dynaudio Excite speakers have a better build quality than the flagship Monitor Audio Platinum speakers that are made in China. Your link does show Dynaudio maintains the highest standards of European craftsmanship, and that's why I have yet to see any cosmetic imperfection on all the Dynaudio speakers I have came across, and that's also why I always suggest Dynaudio speakers to AV newbies with a realistic budget in this forum and the local Chinese forums so that they will enjoy in music and home theater for many years to come.
