weird 23, Sounds like you have things dialed in just fine. My room is somewhat narrow. And while I've positioned my speakers to sound the best they are going to sound, given the size of the room, I know that they could benefit from a wider room and acoustic treatments. I've heard your speakers in a much larger room. I really enjoyed what I heard from that experience... greater deminsionality and wider sound stage. I'm experimenting with acoustic treatments and that's getting rid of the echo in my room. I started out with Contours S3.4s and the smaller Contour center at a previous residence. I enjoyed them a lot! Back then, I was using B&K separates and an Arcarm DVD (FMJ) player. At my present residence, and new relationship, the idea was to upgrade the system (C2s and SCX) and move to a larger house. Well, as you know, the real estate market went south and we found ourselve staying put...with the small room. I listen at moderate levels... genre ranges from Sinatra to the Stones and everything else in between. The S3.4s are probably more suitable for the room size. But, after having the C2s in this room, It's tough knowing that I'm giving up performance. But, then again, this room is HT. I have a large and powerful, clean amp and the Theta CBIII. I was hoping to retain some of the performance by getting the S5.4s.
Hey Sparks,
Before switching out your C2's I'd work on the room acoustics first, you may be able to solve the problems your hearing and keep the C2's.
Send an email to GIK Acoustics,
Enclose pics of your room in the email and measurements of your speakers if possible. They'll come up with a plan to best optimize your room acoustics, it's a free service with no commitment to buy.
For speaker measurements I use this,
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-792
This kit is really easy to use and takes the guess work out of optimizing your speakers positioning. I've found that being able to see what's going on in the room really helps me understand what's going on and gives you an indication of what you need to do to correct any acoustical problems rather than just shooting in the dark.
I'm going to be doing some more experimentation dialing in the room acoustics further in the new year, going to try adding some diffusion. I've read that diffusion works well at increasing the soundstage size in smaller rooms.
weird 23, Thanks for the info. I'll take a look at those cites you listed and see if I can't dial my room in further. I, too, heard about how beneficial duffusion can be. This kit you speak of, is exactly what I need.
Thanks again. I'll keep you posted. Happy Holidays to you and to all of the Dyn guys on this site.
sparks81
Apart from the first 2 days of their arrival when I marveled at its bass (compared to my Focal Electra 1008Be), I start to realize I'm having a major, major synergy issue. It's pretty much unlistenable at the moment, sounds bright/grainy (some of you would say hard to believe, coming from Beryllium) and nothing sounds right 150Hz and up. A visiting friend last night for poker gathering put it the best - a stock cheap car stereo with an expensive sub.
With the Sig's I swapped electronics 3 times during the break in (450 hrs) before putting the Octave and Meridian back in. Had my Yamaha CDX1030 with a Bryston 3BSST and some adcom pre (pretty lame combo). So I can't say if the break in time was different. Also being impatient I ran the C1's and Sig's 7/24 for 450 hrs. Also my system is on twice a day for usually 2 hrs then when I get home 3 - 5 hrs. Weekends 8 - 10 hrs a day. So Khin give them at least 50 or better 100 hrs more. Per Tyler and Mick the C1's have the hardest time breaking in. Not sure but maybe the time in the turtle express shipment they reverted back to new sounding
