Folks, here's Bill Mac's system. A beauty.
. I am very computer challenged and have yet to tackle posting pictures. I wanted to post my HT/Audio room as to get suggestions on room treatments. I want to try to keep it as tasteful and simple as possible. I assume that panels should be on the wall behind the R&L front and center speakers. And some sort of bass trap for the left front corner. I have seen some corner placement treatments that are cylinder shaped (pie shaped on the inside) to fit tightly in the corner. This is the route I would like to take as a straight panel in the corner would come too far into the room. The room is not the best as one side is open and placement for the L front speaker is close to the couch. But I do find the SQ to be very good but thought some room treatments might make it better. The inwall speakers are not used anymore as I had a Yamaha 3090 with front effect speaker outputs.
. I would appreciate any advice on treatments and their placement.
. My thoughts are the same as yours hoping that minimal amount of panels will be helpful. It does look better with the cables through the stands, a little work but well worth it.
. Yes the coffee table has got to go maybe after the holidays. We are thinking of some kind of ottoman to fill the space. Covering the plasma is is a good idea but with my luck I will jar the panel of its mount
. So I will have to deal with the reflections off of it.
. A great group of members and we all try to help each other out. I have not heard the 805s so I can not help you there but I am enjoying the C1s very much. I am sure there are a few members here who have heard them though. I have been looking at the F112 but it is not in the cards right now. Excellent sub and I would bet it would be great with the C1s.
. I have heard it mentioned but not sure if it is something I could do with my poor computer skills.
). You guys will have me to Jr. Audiophile status before I'm done
