Chazanova, those are nice-looking custom stands. Do you know that the foot in the center of the TV--the thing with the 'toe' sticking forward...is easily removeable? Remove two screws, push 2 snaps, and pull it to the TV's rear.
I'm building a combination centerchannel speaker and stand for mine. A cabinetmaker/friend is cutting and assembling the system from 1" MDF; I'll be doing everything else. The speaker is rather ambitious--it'll use, in an MTM trio, the same Sonic Craft 6-1/2" bass/midrange drivers and Dayton tweeter as my main speaker systems...
...to which AVS won't let me post a link...
and will have 4 more of the 6-1/2s as bass-only drivers, all in an open baffle. I'll drive the bass system thru an old Dahlquist LP-1 active-low-pass filter and use another channel of the Outlaw 770. The LP-1 has bass-level controls so the system will be easily tunable for voice articulation or music (more warmth).
I'll post some pics when I'm finished....if I get to 5 posts by then.
He decided, after sticking his fingers in his mouth while playing, that it would be a good idea to give dad a heart attack by touching the TV. I think I broke Mach I getting over to where he was at and moved him away from the TV, but not before the damage was done. 2 very visible yuck-marks on my otherwise pristine TV. Heeelp!! Will the included blue cloth be enough to wipe that away? Is there some type of cleaning kit you've used that's effective against saliva?
