Just want to add that for many people (both users and professional reviewers), Audyssey performs very well. Here is a repeat of my post after I setup Audyssey on my 4306, correct distances, good xover settings, and bass equalized to 28Hz at least as good as what I was able to do with a BFD.
I've had my 4306 for a week now, and have just compared the Audyssey EQ for the sub frequencies to the what I previously was getting with my Yam 2095 and a BFD. For my setup, there is no doubt that the 4306 w/ Audyssey is doing as good, if not better, as the Yam 2095 w/BFD. Here are the results:
4306 w/EQ on: 28Hz-140Hz, +/-4 dB
2095 w/BFD: 28Hz-140Hz, +/- 7dB
The two are actually fairly similar below 80Hz, the biggest difference between is in the region between 80Hz-140Hz, where I assume the Audyssey is doing more than just sub correction, here are the results:
4306 w/EQ on: 80Hz-140Hz, +/-3 dB
2095 w/BFD: 80Hz-140Hz, +/- 6 dB
I'm using the crossovers recommended by Audyssey, which are:
60 Hz - Mains
80 Hz - Center
100 Hz - Surrounds
I've also checked all of the levels with Avia HT Setup Disk, and all of the channel levels are spot on.
One other interesting thing the Audyssey did, when I was looking at the response curves in the Graphic EQ, they were set for the most part +/- 2 dB of flat, with the exception of the 500Hz-1kHz region, here there was a -5dB cut for both the L & R speakers. I looked up the speaker's response curve (Norh 6.9 SM), and they have a 5dB peak starting at 500Hz and extending past 1kHz. So it looks like Audyssey is doing a good job of flattening out the sound field for a uniform response.
I realize not everyone has had similar experiences with Audyssey, but for me it is working about as good as could be expected. So far I like the results of having it engaged.
60 Hz - Mains
80 Hz - Center
100 Hz - Surrounds
Pathetic I know
. Besides you have Klipsch speakers, you could drive them properly with a clock radio and have watts left over.
