Another home theatre project is born! WAHHHH! Im beginning the fun process of remodelling my downstairs den into a home theatre. It was a 1970s den complete with fire engine red carpet (presumably to match the fire engine red toilet that was in the downstairs bathroom when we bought the house
). The red carpet was an amazing eye grabber, but its run its course. I had been using this room as my home office for many years. Almost the last room of the house that I havent remodelled so Im really excited to blow this room up and get started.
About Me
Primarily, Im a DIYer. Drywall is the exception though. Wont touch it. I know my limits too. Im not the most comfortable with electrical, but Ive done it in my bathroom remodels and was pretty successful at that (i.e. the house hasnt burnt down.
). Im a computer nerd, so the electronics are more a less a no-brainer.
I do get to the point where Im not a complete fanatic about audio/video. I reach a point where everything is "good enough." Ive seen many demonstration theatres with ridiculously expensive equipment, and the pic quality isnt anything I could really tell a difference between that and my Panasonic AE900. I love Panasonic equipment! Everything Ive ever owned (including a 1985 CD player) from them has ever blown up. Thats getting bang for your buck!
Room Dimensions
The room itself is about 22' long x 13.5' wide x 7.75' tall. Sounds big until you see the fireplace that sucks up a lot of space. The real useable footprint is 16.5' x 13.5'.
Goals
- 3 or 4 wall sconces. 2 (or 3) on one side of the room, and 1 on the other side of the room. I could put 2 on the back wall. Im undecided there and thought I might use that wall space for decoration (movie poster maybe).
- 2 rows of seats. My ceiling if kind of low 7'9" so probably a 6" riser is all I could deal with. Hopefully, I can comfortably seat 6, but looking to seat 8. Got a big extended family... Just 4 of us in the house though that would use on a daily basis.
- Wood! I love woodworking! Anything I can do with some wood moldings and columns in here, and Im all for it! I want to make wood columns with a cabinet grade cherry or oak for the sconces. I need some media shelves and bookshelves too as I have a lot of those to store.
- Equipment closet. Just to the right of the fireplace is an existing closet 2'd x 2.5'w. A perfect equipment closet! Its stuffy, and I am concerned with airflow there. I did have a ton of spare junk in there before so Ill need some new place to throw my junk.
The Challenges
My room is not without its design "challenges."
- FIREPLACE - The focal point is a big old 7.5' w x 7.75' h red brick fireplace. Its been used twice in the 12+ years that we've lived here. Its a perfect place for the screen actually. My buddy said I should not put the screen there but on the opposite wall that has a 6.5' x 2' window. I could do that, but it would really make putting in 2 rows of seats difficult because row #2 would be basically right up against the hearth of the fireplace. Just wouldnt "look" right. Im not completely opposed to it, but getting a floor plan that can seat a crowd of people would be a challenge that I need some help resolving. One idea I had was to put 1 chair on each side of the fireplace so as to not block the firebox with a chair. An end table could go in between I suppose. I dunno. Needs some more thought. Im still pursuing using the fireplace as the primary screen locale.
Center speaker troubles
My B&W center speaker is close to 12" deep (with grille on). No exactly an easy mountable item to jut out from the fireplace. Any ideas?
Infinity 4000?
I did some research on other center speakers and found the Infinity 4000 which is a mere 4" deep, and it looks like I could mount it right on the brick too. I could probably line the speaker wire behind the screen itself and it would be nice and hidden.
Left/Right Front Speakers
Depending on the speaker layout, Id like to try and reuse my rocking B&W 603s speakers that have served me well for many years. I cant recess them, or hide them particularly though with this fireplace. However, with the screen I picked out, I can build some 4" wood columns (oak or cherry) on the edge of the fireplace and drop the speaker wires all the way to the bottom of the column. The speaker could sit on the hearth right next to the column and the wires could be pretty well hidden that way.
Ive got a pic of my first proposed screen layout with my existing L/R speakers, but cant post until Ive graduated to 5 posts.
). The red carpet was an amazing eye grabber, but its run its course. I had been using this room as my home office for many years. Almost the last room of the house that I havent remodelled so Im really excited to blow this room up and get started.About Me
). Im a computer nerd, so the electronics are more a less a no-brainer.I do get to the point where Im not a complete fanatic about audio/video. I reach a point where everything is "good enough." Ive seen many demonstration theatres with ridiculously expensive equipment, and the pic quality isnt anything I could really tell a difference between that and my Panasonic AE900. I love Panasonic equipment! Everything Ive ever owned (including a 1985 CD player) from them has ever blown up. Thats getting bang for your buck!
Room Dimensions
Goals
The Challenges
Infinity 4000?
I had mulled over getting some nice glass doors installed on it, but the opening is so non-standard that Id have to get some custom made doors for it. Thats typically a $1000 expense (if you want nice doors anyway). I wouldnt mind covering that up myself since we rarely ever used it. I think I burned wood in it twice in the 12+ years we've lived here. That room has some excellent temp control where its the warmest room in winter and coolest in summer. Didnt plan it that way, but it sort of works out. Never really needed it. My upstairs fireplace in the living room is the one that gets used.
