Featured Stories
DirecTV HD TiVo HR10-250 Continued
post #2 of 586
6/19/06 at 8:23am
- Ethek
- Trader Feedback: 0
- offline
- 72 Posts. Joined 3/2005
- Thumbs Up: 10
- Select All Posts By This User
post #3 of 586
6/19/06 at 8:28am
- Iceblade
- offline
- 1,929 Posts. Joined 3/2000
- Thumbs Up: 11
Do you mean is D* carrying your local multicasted channels? No, they aren't. They are not carrying the digital versions (HD if you want to call the LiL channels that) in MPEG2. I am not certain that they are carrying the multicasted channels even on the MPEG4 LiL feeds. The MPEG4 discussion thread could probably answer that for you.
However, if you are just asking if the HR10-250 can pull in all the OTA stations including multicasted ones using an OTA antenna, then the answer is an emphatic YES.
Hope that helps,
Jeff
Hope that helps,
Jeff
post #4 of 586
6/19/06 at 8:29am
- joetoronto
- offline
- 2,105 Posts. Joined 1/2003
- Thumbs Up: 10
if you mean the sub channels, yes you can, Ethek.
have you done a "scan for off-air channels?
post #5 of 586
6/20/06 at 9:42pm
- mdrums
- offline
- 629 Posts. Joined 12/2003
- Thumbs Up: 10
post #6 of 586
6/23/06 at 6:18am
- gwlbe
- offline
- 277 Posts. Joined 5/2003
- Thumbs Up: 10
I just got the free HD DVR installed, great machine, but:
1. I cannot get the digital audio out to work with my receivers, I went thru the menu and set it dd5.1 out on.
2. Watching HDNET, I paused the pic and toggled thru the 1080i, 720P, 480P. 720P looked the worse and I didn't notice much difference b/w 1080i and 480P if any?
3. Is there any way to remove some of the off-air channels that don't work?
4. any way to determine the amount of space left on the HD.
Couldn't find the answers in the manual.
Thanks in advance.
All in all, pretty cool.
Thanks in advance.
post #7 of 586
6/23/06 at 6:34am
- joetoronto
- offline
- Thumbs Up: 10
Thanks in advance.
Thanks in advance.
1. are you using toslink/optical cable?
2. what's the native resolution for your set? i think allot of people expect more of a difference between resolutions when they first check it out, i know i did.
3. yes go into setup, settings, channels and then channels you receive. once your there, uncheck the channels you don't want.
4. no, unfortunately. i keep an eye on it by counting approximately how many hours of recordings i have. for example, i add 2 hours for each HD movie to 1/2 hour and one hour shows, when i get close to 25 HD hours, i start deleting shows i don't really want.
the unit can hold 250 hours of SD programming or 30 hours of HD, if i remember correctly.
enjoy, gwlbe.
post #8 of 586
6/23/06 at 8:16am
- gwlbe
- offline
- Thumbs Up: 10
Thanks for the quick reply.
Yes I'm using the Toslink, still nada on both my Denon and Yamaha receivers.
Sony WS510 not sure manual doesn't state native resolution, just says it accepts 480P,720P & 1080i. My Panny AE300 front projector is 1/2 1080i. I notice the same on my upscaling DVD player that not much difference b/w 1080i and 480P on the Sony. On the projector big difference.
Thanks for the info
Sure wish they would activate the USB ports.
Thanks for the info
post #9 of 586
6/23/06 at 8:21am
- joetoronto
- offline
- Thumbs Up: 10
Thanks for the info
Thanks for the info
you have a toslink cable going from the HR10 straight into either your dennon or yammy and you get no sound?
what happens if you turn off the DD in the settings, have you tried that?
how big is your sony TV?
post #10 of 586
6/23/06 at 10:17am
- gwlbe
- offline
- Thumbs Up: 10
post #11 of 586
6/23/06 at 12:42pm
- sgibson
- offline
- 581 Posts. Joined 7/2002
- Thumbs Up: 10
Per pg. 32 of the DirectvHR10-250 pdf Manual..."While a cable is connected to the
HDMI Output jack, the Component Video Output is disabled. You can't view video
from both the HDMI Output and the Component Video Output at the same time."
I have to unplug my HDMI switch (feeding InFocus SP4805 projector) whenever I want to watch Panny PT51HX41E RPTV thru component.
Anyone know of any other solutions?
TIA,
sgibson
TIA,
sgibson
post #12 of 586
6/24/06 at 5:09am
- joetoronto
- offline
- Thumbs Up: 10
TIA,
sgibson
TIA,
sgibson
here you go, tia.
post #13 of 586
6/24/06 at 5:56pm
- sgibson
- offline
- Thumbs Up: 10
post #14 of 586
6/25/06 at 4:28am
- joetoronto
- offline
- Thumbs Up: 10
post #15 of 586
6/25/06 at 8:52am
- HDTVChallenged
- offline
- 7,565 Posts. Joined 1/2002
- Thumbs Up: 29
HDNet is a 1080i channel. If I recall correctly the WS510's are CRT based and 1080i native. The vast majority of these types of sets do *not* do a very good job with 720p sources ... (often they are bobbed and cropped to 540p.) You are probably better off leaving the HR10 at 1080i for all HD programming.
I tested my "720p accepting," Toshiba, CRT based set with a native 720p source (local ABC affiliate) during MNF. Toggling between 1080i, 720p and 480i/p output on the HR10, it was clear that the TV was demoting the 720p input to 540p ... YMMV of course.
One more thing: the Sony's have a DRC circuit which is just a fancy name for a scaler/upconverter. As I understand it, the device has several settings one of which promotes 480i/p to 540p by 960.
post #16 of 586
6/25/06 at 5:55pm
- steelerhater
- offline
- 90 Posts. Joined 9/2002
- Thumbs Up: 10
Did a search but couldn't find anything. My digital audio stopped working right in middle of a movie. I've switched cables, that didn't work so I know it is not the cable. I know the component sound works, so it is not my receiver. Also tried moving input on receiver from 2 to 3..still no sound. Has anyone else had their digital output die?
TIA.
TIA.
post #17 of 586
6/25/06 at 6:18pm
- huberjgl
- offline
- 424 Posts. Joined 4/2003
- Thumbs Up: 10
post #18 of 586
6/26/06 at 3:10am
- joetoronto
- offline
- Thumbs Up: 10
TIA.
TIA.
no but what do you mean by "component sound", steelerhater?
post #19 of 586
6/26/06 at 7:02am
- theesir
- offline
- 40 Posts. Joined 6/2006
- Thumbs Up: 10
post #20 of 586
6/26/06 at 9:26am
- hyperliteg4
- offline
- 3 Posts. Joined 6/2006
- Thumbs Up: 10
I recently tried calling yesterday because I am getting my new D* service on monday. What I really wanted was a DVR but I've got this whole trade-off with either recieving local channels in MPEG-4 HD with the H20 reciever or getting the DVR now (Tivo box) functionality and no local channels. I know I can get the off-air antenna for local channels but I was told my someone else in our area that it doesn't work too well.
When I called, they told me initially next month the new DVR will be released. I tried calling again about it because I was trying to get more info about having a DVR now and upgrading later but they didn't seem to be too helpful. One person said next month, the other person said in FEBRUARY (geez!!) and the same difference in answers when I asked about upgrading if I were to get it now. One said I could be paying $0 or $99 to upgrade and the other said I could be paying full price.
So who should I believe and what should I do? Should I just get the H20 now and wait on the DVR until the HR20 is released or should I get the HDTivo box, miss out on local channels and upgrade the to HR20?
post #21 of 586
6/26/06 at 10:12am
- joetoronto
- offline
- Thumbs Up: 10
i would definitely get the HR10 now, only god knows when the HR20 will finally be released and besides, you really have nothing to lose anyway.
post #22 of 586
6/26/06 at 4:39pm
- Robert Holloway
- offline
- 1,340 Posts. Joined 3/2003
- Thumbs Up: 10
I am sorry if this has already been asked.
I subscribed to Direct TV and wanted to get the Tivo 10-250 to time shift HD TV
My main interest was stuff off the networks, ESPN then movies off HBO etc.
Now I'm hearing that the 10-250 will not record HD CBS, NBC, Fox, ABC off the networks from my Direct TV.
Am I missing something here as it all plays perfectly well on my projector.
Many thanks
Rob
Many thanks
Rob
post #23 of 586
6/26/06 at 6:15pm
- huberjgl
- offline
- Thumbs Up: 10
Only if you live in an area that has MPEG4 HD Locals via DirecTV.
LA and NY HD locals are still MPEG2, as they are the DNS HD Networks provided by DirecTV to those who don't have HD locals available by satellite yet.
You'll be able to record/time shift HD locals if you can get them from an antenna (OTA),
and will be able to for some time.
Jerry
post #24 of 586
6/27/06 at 6:41am
- chamartin
- offline
- 33 Posts. Joined 6/2006
- Thumbs Up: 10
post #25 of 586
6/27/06 at 6:49am
- ScoBuck
- offline
- 1,025 Posts. Joined 12/2005
- Thumbs Up: 10
I have the AT9 since January - it delivers a beautiful signal. It is larger and heavier than the triple dish, but in my case that is NOT an issue nor a problem. It is not visible unless you are a distance away from my house, and it was securely installed with monopole supports.
If this is similar to you, I would have the 5lnb installed. It will allow you to immediately be able to take advantag of any new MPEG4 channels (and they WILL be starting to add some this weekend) - such as the local RSNs.
You still can have the HR10-250 DVR with this dish, but you can also have H20 HD receivers. When the new HD-DVr comes out, all you would have to do is plug it in to the wall.
There is a new 'slimline' 5lnb dish to be launched but there has been NO hint of when. My own feeling is that you almost have to be able to reduce rain fade with the current larger current AT9 version - so if the size of the dish doesn't scare you I would go ahead with it.
post #26 of 586
6/27/06 at 7:03am
- joetoronto
- offline
- Thumbs Up: 10
that's news to me, from what i hear, the HR10 will NOT work with the new 5 LNB dish.
post #27 of 586
6/27/06 at 7:05am
- ScoBuck
- offline
- Thumbs Up: 10
post #28 of 586
6/27/06 at 7:19am
- ScoBuck
- offline
- Thumbs Up: 10
went to DbsTalk.com, see many people stating things like the following in their signatures:
10 year D* Customer
Panasonic TH-50PX50U
5-LNB/H20
(2) HR10-250's
(2) Harmony 880's
Sony DAV-FR8 HT
SAT-B2 RCA Receiver (10 Years old)
SD-DVR-40 and 80
bunches more with similar statements about AT9 and HR10-250
10 year D* Customer
5-LNB/H20
(2) HR10-250's
(2) Harmony 880's
Sony DAV-FR8 HT
SD-DVR-40 and 80
post #29 of 586
6/27/06 at 7:35am
- joetoronto
- offline
- Thumbs Up: 10
i stand corrected, the HR10 IS compatible with the new 5 LNB dish, it's NOT able to receive Mpeg4 signals though.
i did a quick search over there and this statement from litzdog911 confused me.
"I think they are now available. You need both the new 5-LNB dish and an H20 HiDef Receiver to view them. The HR10-250 DVR is not compatible with the new MPEG4 channels. Note also that DirecTV is only providing CBS, NBC, ABC and Fox local HDTV channels. You'll need an over-the-air antenna to receive PBS and other local HDTV broadcasts."
sorry about that.
sorry about that.
post #30 of 586
6/27/06 at 7:52am
- chamartin
- offline
- Thumbs Up: 10
Back to Forum: HDTV Recorders
- DirecTV HD TiVo HR10-250 Continued
Currently, there are 1645 Active Users
(396 Members and 1249 Guests)
Recent Discussions
- › West Palm Beach, FL - HDTV 49 seconds ago
- › OFFICIAL Samsung Smart TV "Evolution Kit" Thread 58 seconds ago
- › The Official Xbox One thread... 1 minute ago
- › Marantz AV8801 Preamp/Processor Official Owner's thread 1 minute ago
- › 2013 Formula 1 in HD 1 minute ago
- › Sony HW50 / BenQ W7000 / Epson 5020 / JVC RS55 / JVC RS 46 / JVC... 1 minute ago
- › PC as distributed audio source (interfacing to amp) 2 minutes ago
- › Soundbar installation trobles 2 minutes ago
- › Do you have image burn-in with your Panasonic Plasma? 3 minutes ago
- › Difference between 2.0 using surround decode, 5.1 with EXTD... 4 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
