Originally Posted by swanlee
On the comcast box press the menu button that is physically on the front of the cable box, not on the remote, press it once quickly and release it, don't hold the button down, do this with the unit turned off, This will let you enter the user config area and you can change the resolution that the cable box is outputting.
On another note, has anyone ever gotten stuck pixels fixed on this unit? I have 2 stuck pixels and 1 dead pixel, Tried pressing lighlty on the stuck pixels with the eraser end of a pencil, I hooked my pc up to it and ran several pieces of software that are suppose to fix dead pixels, ran them for a couple of hours.
nothing yet has fixed the stuck pixels.
3 out of 2 million isn't that bad. Actually it's really good. if they're not clustered together, you'll never see it at the viewing distance. Instead of paying attention to 3 dead/stuck pixels.....try to pay attention to the rest of 1,999,997 pixles that work beautifully.
Just my $0.02.
