AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Westinghouse 42" LCD w/1080p Part II, MSRP ONLY
Westinghouse 42" LCD w/1080p Part II, MSRP ONLY - Page 29
post #841 of 7781
Originally Posted by BryanDoyle View Post
Yes, it is going to RGB. The issue at hand is either the XBOX 360 isn't sending the 16:9 flag at 480p or the TV is ignoring the 16:9 flag sent by the XBOX 360
The only setting listed for the RGB port is 480i.
https://www.westinghousedigital.com/...p-monitor.aspx
Is it a handshake issue?
post #842 of 7781
Originally Posted by Fragster View Post
Hey BryanD
From your xbox 360 issues, your only option is the VGA cable........to get the DVD's up-converted to 720p (widescreen).
On the same note, Im jumping on this thread from the other 37w3 one as there appears to be more posts regarding XBox 360 performance here so u guys have any pics of the 360 with the Westy?
S
PS: Very close to pulling the trigger on the 37w3.
What kind of photos do you want? Dashboard, DVD, Games? I was just looking to get 480p widescreen if possible. I know that there is a 16:9 flag for that format to use and either the TV is ignoring it or the XBOX doesnt output it.
post #843 of 7781
I am using the YPbPr Component Video 1 input - capable of 480i/p, 720p, 1080i. I can see the XBOX output 480p, but again its the widescreen flag thats not getting used properly. I am almost certain that stretch mode in 480p simply pulls it to widescreen instead of zooming in, so it may just be a manual procedure with the same outcome. I am still looking into this.
post #844 of 7781
Does anyone if this type of issue is covered by the BestBuy "In-home" Warranty service?
-Argus
Originally Posted by pendola View Post
Well I got my Westinghouse from BB yesterday after waiting about 3 weeks for it to come. And guess what??? I got a defective unit with vertical banding across the entire screen. I checked the firmware and it was 1.19. I called them and asked if they could send another out on the truck and exchange it but they told me no. Now they said I have to return the defective unit and place a whole new order and that their research department would give me the lower sale price I paid a few weeks ago. Anyone else had this problem? Did they give you the correct sale price after it was all said and done? Was it a big headache?
post #845 of 7781
I wouldn't do it that way. Once they replace the TV, I think they consider the service plan void and you lose out on the plan. Read the fine print before making a decision.
Bryan
post #846 of 7781
Just as I'd suspected, the 480p signal through the DVI input from my Oppo on Standard Mode is windowboxed (I was mistaken when I said that it was pillarboxed earlier). Using Fill Mode makes it fill the screen, but 720p and 1080i both fill the screen on Standard Mode. The flagging theory may be correct.
post #847 of 7781
OK, I am going to contact westinghouse tomorrow. I have a feeling that they are just going to tell me to hit the stretch button.
Bryan
post #848 of 7781
http://www.xbox.com/en-US/press/2006...e-features.htm
this is the spring update if it aksed you to update when you turned the unit on then it did update correctly.
here is the part about upscaling
"DVD player outputs at native resolution over VGA connection"
post #849 of 7781
XBOX 360 Playback
I am getting a 4:3 picture even though the XBOX is set to widescreen 1080i. I assume this is because the DVD outputs 480p, but the image is actually squished as if the XBOX is sending out the correct signal. Is the only solution the fill option? The image looks like the proportions are correct (nobody is fat), but the screen gets cropped a bit.
Bryan
Bryan,
I have my 360 connected the same way. I've seen no problems displaying dvds in widescreen with my 360. So far I've watched at least 7 or 8 different movies and none have displayed this symptom...
Originally Posted by fedex2go View Post
Well, here's a breakdown of 1080p HDMI on Westi42:
1. Samsung HD960 - Sparkles
2. Samsung BluRay - Sparkles
3. Helios 2085 - Sparkles
4. PC DVI-2-HDMI - Sparkles at @59Hz, able to get rid of them turning down the frequency to 55Hz.
Also, it's confirmed that Sceptre 37" (production date - March) is able do display all the above correctly, and that's with cheapo-cheapo HDMI cable.
Also confirmed - expensive HDMI cable (0.5" inch thick) doesn't help Westi42 to get rid or the sparkles.
I e-mailed (twice) Westinghouse tech support on Jun.23rd with the picture I made (with blue sparkles) - it's almost 10 days now - no answer.
I hooked my pc up with a DVI (pc side) to HDMI (tv side) cable. No sparkles playing any wmvhd clips or dvds. When I checked the menu for the tv it showed it was receiving 1080P content. I don't however have anyway to test straight HDMI to HDMI.
post #850 of 7781
Hello,
can you tell me the resolution you use on your PC's videocard and vertical frequency?
THANKS!
post #851 of 7781
Could someone who's gotten their Harmony 880 setup for the 42w2 please PM me, i've got some questions about how to get Logitech to make it work.
post #852 of 7781
Hello,
THANKS!
GeForce 6600GT PCIe running 1920x1080 @ 59.94.
It started at 60 Hz but seemed a little fuzzy so I dropped it to 59.94. That didn't seem to make a difference so I think the problem was my eyes and the distance from the screen.
post #853 of 7781
okay, did a search, didn't find (so if it's in this thread, many apologies).
I have an overscan issue (or underscan?) in that I have a bunch of components running through a JVC receiver that upconverts to HDMI. DVD via component looks fine, but my S-video to HDMI Directv box to Westy produces the top 3 lines with the picture info (white pixelated lines, sync detail I assume). Any ideas how to rid this?
I have another unit as well, and with my HD TiVo box connected via HDMI, HD looks fine, but SD, I have the same exact issue (but not in HD). Ugh...
post #854 of 7781
Now that I've had my set for about three weeks, I thought I'd post my mini-review in case it is helpful. Fortunately, this forum was very helpful in knowing what to expect, so the "bad" things about the monitor were pretty much already known. This is my second HD set--I was having no luck getting my previous 6-year old Toshiba 40" CRT RPTV repaired (long story), so I'll make some comparisons to that set along the way.
I have firmware 1.16.
Observations:
- No lockups.
- No problems with the remote or slow response.
- True HD is stunning and the higher resolution of this set compared to the old CRT RPTV is immediately apparent.
- DVDs are probably a wash--the black levels were still a bit better on the old CRT set, but the perfection of convergence, geometry and the lack of a RPTV "hot spot" gives the Westinghouse some points also.
- I can see motion blur on most LCD sets after looking at them in the store for awhile. I did that for a long time with this set before deciding to buy. Now that it is at home, I think I can only very rarely see it, and it may not even be the panel that is at fault. So, that is impressive.
- My audio receiver does not have adjustable delay, but the video processing is apparenly fast enough on the Westinghouse to not cause any lip sync issues, which is a big relief.
- There is some backlight banding, pretty much as described elsewhere in this forum. So, instead of seeing geometry distortions when there is camera panning in the old CRT set, these bands are sometimes visible. But, overall the illumination is much more even than the CRT RPTV set which was noticeably brighter in the center vs. the edges. Even movie theaters have that to some extent. So, I consider it a minor defect.
- The biggest shortcomings of the set to me are:
(1) the lack of more aspect ratio controls. Primarily, the missing mode is a "zoom" mode for watching older non-anamorphic widescreen DVDs and letterboxed SD. (2) for the best black levels, you have to be very close to on-axis. There is a watchable picture over a very wide area, but the very best viewing is within 20 degrees or so of each side of dead center. Vertically, it is probably an improvement over the CRT RPTV, horizontally it is no better and maybe worse.
I don't want to end on those negatives, because overall I can't think of any other set in the 42-inch size that I would rather have. I find myself mesmerized by the picture, which says something since I have been watching HD for many years.
Mark
post #855 of 7781
Bryan,
So, you can use the TV set to standard, not fill, and you get a movie that spans the entire width of the display? (with possible letterboxing depending on the movie's widescreen proportion). Also, what firmware do you have?
Bryan
post #856 of 7781
After just speaking with the Westinghouse CSR and explaining the two subtly visible vertical bands on my set, and determining my set as being officially "defective", and stating that I was in the greater Los Angeles, CA area, the CSR explained that I could wait until after Thursday of this week (Westy office(s) are on holiday and performing some computer system upgrade) to call back. When I call back after Thursday, he stated that it was highly possible for me to do the following, because other support cases have been resolved in a similar manner:
- Take my set into their distribution center in the greater LA area
- Bring an HD source in, such as a notebook computer + a DVI cable
- Exchange my set for a brand new set right in the distribution center
- Test the brand new set right in the center, with my HD source plugged in.
- Keep testing until I find a good set.
I'm not sure how much weight I'd put into what I've been told, but with the distro center only 30 miles away from me, I'm willing to give it a shot this / next week to validate what I've been told.
post #857 of 7781
where is it located?
post #858 of 7781
thanks for the mini review mark
good to know that this sets quality is confirmed by a long time viewer or hd material.
the only comparisons left to be made are with the upcoming 1080p sets from the bigger name companies and how much better the picture can be given the price differences.
i'm looking forward to a direct comparison to the sony sets since i know sony will definitely provide a quality picture. the samsungs so far have left something to be desired and they are quite a bit more expensive
post #859 of 7781
message truncated for space saving...refer to post #856...
mbuchana,
Echo most of that review. HD on this set is incredible. I'm surprised though that you didn't mind the remote, which requires some couch acrobatics for me to get it in the right reception cone for the IR receiver. My wife finds this to be the most annoying aspect of the unit.
I still get some audio out-of-sync, even coming from the built-in speakers. I'm going to try to understand this some more when I'm back from vacation--like how much video processing is being done based on the source when this happens (how much upscaling, is setting the sharpness to anything other than "0" slowing it down? etc...).
post #860 of 7781
The Westy distro center is supposedly located in Santa Fe Springs, CA.
post #861 of 7781
wow that is not far from me. I say 15 miles or so.
post #862 of 7781
I just got done watching madagascar on HBOHD on this set and it was freakin amazing, not the best CGI movie but it looked so good I could not turn the channel. HD is just so amazing, I had a 27 inch Samsung CRT HDTV for 3 years and it did good HD but nothing close to the westinghouse.
Once calibrated properly and using the SM codes to fix the color this TV's colors rivals any CRT I've ever seen and the resolultion blows anything away.
post #863 of 7781
just re-checked my settings via dvi to hdmi(westy side) from my pc. radeon 9800pro
dvi out.
saw sparklies at default refresh rate around 60hz
played around in powerstrip lowering refresh until sparklies were eliminated
they are gone according to my eyes at a
vertical rate of 48.099
horizontal rate of 53.438
when the westy is turned off and on it seemed to revert back to it's standard refresh rate but as i clicked on the pc window it snapped back to the pc''s set rate above.
1080p through hdmi no sparklies whatsoever.best i could do for now until they make a blue ray player that's worth getting so we can test the hdmi to hdmi hookup.
just one note: i thought hdmi wasn't supposed to display a 1080p picture though hdmi without hdmi on both ends? or does that only apply to the new players with hdcp?
post #864 of 7781
Okay, I turned my backlight from 0 to 50 and above, wow the colors really pop this time. So, my recommended setting would be backlight 50, brightness/contrast/saturation around 50, hue about 0, and sharpness (0 or whatever, it doesn't seem to make any difference). Of course, PeterS's SM settings are awesome and easy to do. (Note if you get a white screen, don't panic. You are just at a signal-less input, try to use your menu to switch to a known input.)
My DVI1 now works after hooking up with DVI2 without problems. It used to give me "signal out of range." It looks there is some memory effect that ties the two DVI inputs together.
post #865 of 7781
Backlight settings from 0 to even 100 will not change the overall contrast too much. I personally think you'll sacrifice grey details more than gaining more of blacks..... I have mine set around 45 to 50 most of the time. I like achieve good black, but I also like to see darker details in the movies..... instead of all black.
post #866 of 7781
Does anyone on here know how to remove the bottom base stand. I just bought a wall mount and want to hang it up there, but the manual has nothing about removing the base stand. Any help is appreciated. Thanks
post #867 of 7781
Looking at it from the back, you'll easily see 4 screws that you need to remove. Simple as that.
post #868 of 7781
Is anybody else experiencing delays in the BB delivery of the westy 42? I ordered mine on that Saturday sale with delivery on 6/24, then 7/3, now 7/14....
post #869 of 7781
They are available on BB site for delivery now, so it must be getting better in terms of availability. Earliest date available is now 7/10
post #870 of 7781
I had a confirmed delivery date of 7/2 to Santa Monica, CA that went unfulfilled. However, I won't mind too much as long as I get firmware 1.19.
However, it does suck that they don't even call you to tell you that they can't make the confirmed delivery date!
