AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › official eyeFi LX4200 42" LCD 1080p owners' thread
post #1 of 21
there is quite a bit of information posted for the eyeFi 47" LCD monitor and i would recommend those interested in the 42" read the 47" thread (LX4700)
the 47" model received good reviews on its thread
however, there is very little information for the 42" model in that thread
the 42" was described in one post as looking better than the 47" when viewed side-by-side
the 42" monitor is not listed on eyeFi's product page - eyeFi is very responsive to e-mails - they reassured me that the LX4200 is a current model and sent, as requested, the owner's manual (will add link to attachment soon)
i was also reassured by eyeFi that this set accepts 1080p from a PC source
i've ordered this set from sam's and expect it in 7 to 10 business days
i will post more info when i receive the set
if you already have this set, please share your thoughts
thanks
post #2 of 21
Looking forward to your review.
Can you answer the following:
- Is the frame as nice as the 47"?
- SD picture quality (terrible on the 47")
- Which inputs take 1080P
post #3 of 21
Looking at Westi but having trouble finding in stock. Came across this set listed on Sam's Club website. No costco around here.
Interested in anyone's thoughts on it especially compared with the Westi set. I'm itching to get a 1080p 42-47" set....
post #4 of 21
sorry for taking so long to follow up on my initial post
i had a technical issue with the monitor and wanted to resolve it 1st
the enclosure for the 42" is nothing like the 47" - all plastic
but it still looks nice
the lcd panel is framed by a large clear frame of plexiglass - it's a nice touch
overall, i'm pleased w/ the set - however, this is my 1st venture into HD-land and i'm pretty easy to please (especially since there aren't many/any choices right now)
the blacks aren't as dark as i'd like - they do glow a bit
i have not yet calibrated the set - a friend owns a "spider" and she said i could borrow it
i am driving the monitor from my PC @ 1080p @ 60Hz via DVI->HDMI cable
the best 1080p video i've found so far is the HD WMV demo: The_Living_Sea_1080.wmv
it's on microsoft site
windows/windowsmedia/musicandvideo/hdvideo/contentshowcase.aspx/
(sorry, avs forum won't let me post a full url since i'm a new member)
this video looks spectacular
i'll be watching the thread and will try to answer questions
you may need to guide me w/ the technical stuff since i am pretty much a noob when it comes to LCD/HDTV stuff
post #5 of 21
after i setup the monitor, got it connected and pretty much had a visual orgasm when i popped in a movie, i was shocked to find it could not handle small fonts properly
single pixel lines were not being displayed properly!
for instance a vertical red line may be displayed as red, white or black depending on where it was displayed on the screen (same goes for green and blue)
attached is a bitmap that demostrated the problem in a very obvious way
since this set is to be my computer monitor for my new HTPC (and my only PC), this artifact was not acceptable
i called tech support (# is on the box), they took down details and said somebody would call or email - that was almost a week ago - not a peep from tech support
i was going to call them again tonight, but decided to 1st play around a little more
long story short, my video card was sending the monitor 1080i and this was causing the problem - i'm surprised it couldn't handle 1080i properly
after some fiddling around with my vid card's config software (geForce 7900GT) i was able to get 1080p as a HDTV option (god only knows how i finally got it to appear! it took a lot of random monkey-like key presses)
one of the main take-aways here is...
don't assume you're getting 1080p if the set's "info" screen says "V Freq: 60 1920x1080"
post #6 of 21
since this unit is simply a monitor and does NOT have a tuner, the qually of SD depends on your source, tuner, capturing software, upscaler etc
my cable quality is just okay, i'm using an ATI HDTV wonder tuner and using beyond TV to capture the video
naturally SD quality totally sucks when compared to HD (not always though - i've seen some really crappy HD OTA broadcasts - so much data reduction it looks worse than SD!)
i'm attaching a couple images i screen captured (using PC screen capture software - this is independent of the monitor) - the "a" images are reduced to comply w/ avs forums "max-size" constraints - the "b"-"c" images are actual size (however, they are converted down to a jpg which affects the quality a bit)
naturally, the monitor displays these images, as is
anyhow, i'm happy with the SD i'm getting w/ my setup - i think i've just gotten used to the really poor signal i'm getting from my cable company
post #7 of 21
more SD images...
post #8 of 21
so, i put my old 27" CRT next to the LX4200 and the quality was close enough
there was an occasional artifact (jitter) on LX and it was not as crisp as the 27" due to all the processing required to take that NTSC signal up to 1080p
but from a distance, it's not that noticeable
post #9 of 21
user manual is too big to upload
LX4200_v08.pdf 299.23046875k . file
post #10 of 21
2can, thanks for posting all the info above.
It's too bad that the 42" doesnt have an aluminum frame like the 47" :-(
That was the main reason I would have bought it over the Westy 42", all else being equal (pic quality, processing, etc).
I'm leaning towards one of the following now (in order of preference):
- 47" Eyefi
- 47" Westy
- 42" Westy
Have to wait and see what my size/budget needs will be later this winter (I may move).
post #11 of 21
Any images of HD video, like actual programing.
post #12 of 21
Any updates?
post #13 of 21
viewing from an angle...
blacks are their blackest when the monitor is viewed from directly in front
however, the picture does not deteriate much at when viewed from extreme angles
i'd say it has a 170 degree viewing range - at 170 the problem is not the monitory, but simply the angle)
post #14 of 21
after several months i am still very happy with my choice
when the image quality is good - the montor really shines
i've attached a snapshot of a good HD image (from the imax deep-sea sample from the MS wmv-HD sample site)
but, the image doesn't do it justice
post #15 of 21
any banding?
any backlight bleeding?
post #16 of 21
no bleeding or banding
the only picture quality issue is that the blacks aren't black enough
some light does make it through the lcd - not too bad though
post #17 of 21
I have a couple of questions.
1) The HD channels are letterboxed (top and bottom). I have tried every setting in the "window" menu, but nothing helps. Aren't all the HD channels sent in 16x9? There is no help from the cable box, as there is nothing to change. The weird thing is that I have two cable boxes. The one I use is an odler one that has the HDMI input to the tv. The "newer" version has only component (Comcast told me no one used HDMI, so they stopped putting it on the cable boxes). When I put the new box to the monitor via component, I get no letterboxing. Instead, it expands the image until some of it is lost. For example, when I watch ESPN HD, I can't see the left and right edges of the ticker at the bottom of the screen. That is really annoying. Again, there doesn't appear to be anything to change in the box itself. And the menus on the monito don't do anything to fix it. Any ideas?
2) The second problem has just started happenign this week. After 3 montsh of flawless operation, the monito has begun shutting down after an hour or so of oepration. I have changed variable one at a time to try to isolate the issue, but to no avail. My only idea is that it is not cooling properly, so shuts down when it hits a certain temperature. I turn it back on, but it shuts down immediately unless I leave it off for a while. Any ideas?
post #18 of 21
sorry, i'm not going to be of much help - i'm using a PC to drive my monitor - don't know much about set-top boxes
1) what resolution does the monitor say it's using when using HDMI? this does sound like an issue with the signal coming out of the comcast boxes
2) this sounds bad - mine has never shutdown on me before - cooling sounds like a good theory - maybe blowing air through the vents can confirm the problem - mine doesn't make any noise - i don't think there's a fan inside that could go bad
post #19 of 21
I thought about setting up a fan to confirm the problem being heat.
When the info flicks on the screen, it always says 720 x (whatever). It's never 1081. It seems to be the box, but neither box works right. One box gives me black bars and the other box cuts off the sides of the screen. I'll have to call Comcast.
post #20 of 21
Is this wall mountable, if it is what kind of I should buy, universal or any model or type?
post #21 of 21
thanks
