AVS › AVS Forum › Audio › DIY Speakers and Subs › Limited space in RV - DIY powered sub make any sense?
post #1 of 8
Our RV has a 5.1 surround sound system in it which utilizes a small (I think about 4.5") passive sub recessed in the ceiling. Needless to say, this system is starved for bass.
I'd really like to replace the sub with a powered one on the floor, but about the only place I could put one is in a cabinet that has only 13" of vertical clearance. Also, the maximum width is about 8" and the maximum available depth is about 15". I'm finding it extremely difficult to find a decent sub that would fit into those size restrictions, so I'm toying with the idea of making one myself.
I've never built a speaker or sub before or even considered it, but it might make sense to give it a shot when the final appearance is a non-issue and improving on the sound shouldn't be too difficult. The challenge is that I have no idea what goes into making a powered sub or the principles to follow for good sound.
I've noted the Parts Express catalog seems to have a fair amount of do-it-yourself sub stuff. Would it make sense for me to even try to build my own sub? What price range would I be looking at?
Where should I start?
Tim
post #2 of 8
Try posting in the PartsExpress forum. There was talk over there a few months ago about a line of small TangBand subs. 6.5" I think they were. They might be what you are looking for.
post #3 of 8
Yeah, two of the Tang Band 6.5" subs would definitely put some thump in that space. The problem you would run into is getting a port in that space. The TB6.5's don't do well in a sealed enclosure. Give us some more details of your space.
post #4 of 8
With a 13"x 8" baffle clearance, i thinks he will have to default to one TB with a forward firing port.
post #5 of 8
I think this 6.5" driver is going to be available very soon. Lower Fs, more excursion, smaller enclosure requirements. MUUUCH better than the TB sub driver but a little on the pricey side. Just give them a call and get amp / enclosure recommendation if you are not comfortable designing the sub yourself.
Mpyre audio driver, 6.5" subwoofer, at acoustic-visions
Allan
post #6 of 8
Could you make that cabinet into the sub? I do not know what it is constructed out of, but maybe it is possible to install a Dayton 8 inch driver (like 295-100)? With a cabinet vol of .9 cubic foot, a 3 inch port 6.3 inches long would work using that driver. Then hide your sub amp some where near by.
post #7 of 8
Unless your RV is constructed more solidly than most, I would not use the existing cabinet as an enclosure. You will rattle your dishes, and your cabinets. You pretty much have to make an enclosure and hide it in a cabinet - unless you like the sound of things rattling. But you probably already knew that.
post #8 of 8
Yea, after remembering what the inside of an RV looks like, and the materials they are made out of, I'd have to agree you're right.
This thread is locked
