Recently I have done some testing of screen samples from Da-Lite. I have samples of the High Power, Video Spectra 1.5, and High Contrast Matte White. After some experimenting I thought a good material would be a combination of the High Power (retro-reflective) and the High Contrast Matte White (light grey).
I went to a local fabric retailer and wandered around looking for a material better than the bed sheet I am currently using for a temporary screen. In the upholstery section I came across a material that was composed of a very fine woven synthetic material with a vinyl like backing. The woven material was a very fine clear monofilament that gave the surface a reflective and some retro-reflective behavior. The backing material gave the color to the surface. There were several colors including white and a light grey. It came in rolls that were 60" wide. It looked so interesting I bought 3 yards of the light grey.
My temporary screen setup is a sheet of cloth suspended with bungee cords in the corners. I added loops to the corners of the new cloth and tried it out. The performance of this cloth was an amazing improvement over the white cotton sheet. The colors are very bright and vibrant. The contrast is great, with very black blacks and very white whites. The image looks good from any angle. One unusual thing I noticed is that the pixel grid is not visible even from a few inches. The pixel grid seems to get lost in the very fine weave of the cloth. The image is very sharp and seemed to have a 3D quality to it.
This material would work very well stretched over a frame or contact cemented to a large sheet of MDF. Since it comes in 60" wide rolls you could make a 104" x 58" (119" Diag) screen.
I called the store to get more detail on the material and here are the details.
Retail Store: Rockland Textiles, Ottawa, Ontario, Canada
Supplier: J. Ennis Fabrics
Material: "Sportlite", 1000 Denier Nylon, water proof backing
Price: $11.95 yd
For a little over $30 you could make a very nice screen. I strongly recommend that if you can get yours hands on some of this material (light grey or white) that you give it a try. I wish I didn't have to use a roll up screen. I'm actually worried that the High Contrast Matte White material from Da-Lite won't look as good.
Price: $11.95 yd
