Nuance or anyone that cares to comment.
Back in post 73 after a number of USA posts noting limited dealer numbers, I commented that I had not heard Vandy's and being in Oz, it might be difficult. Well amazingly enough, I have just discovered that I have been driving past a dealer on my way to and from work each day, for years. He has models 1, 2 and 3 (plus other brands such as Quad and Naim) set up so anticipating a good listen ASAP. Have no clue yet as to what he is like as a dealer and we may or may not hit it off
like I have with my current one.
Anyway, based on the fact that budget may interfere with a dream solution, what would existing owners say about the relative sound characteristics and perhaps value for money of the 3 models mentioned. It would be for moderately loud but non cranking stereo only duty in a medium sized room. What differences should I listen for between models or should I just concentrate on listening to one only such as the 2ce signature and use that to judge the overall Vandersteen sound? Having said that, I doubt if I could stretch to the 3s as I have sources, amp, cable etc to get as well as a separate existing HT system to support
but would like to know the differences anyway. Thoughts?
