post #1 of 1
Is it just me, or does the flake in this paint cause just enough diffusion to smooth the image? (In my case 720p, 10' wide.)
I've moved from a Da-lite HCCV screen to a DIY screen using WOP as a topcoat. Before I added the top coat (when it was just a flat basecoat) screendoor was roughly as visible as the HCCV screen. After adding the WOP, their was no loss in "real" resolution, but it does appear that the interpixel gaps are less visible.
To make sure I wasn't losing any actual resolution I popped in an xbox360 game and could still clearly make out the jaggies, so each pixel is still showing definition.
The end result is a natural image that is "like butter."
Anybody else experience this?
