AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › HD72 and Panny 900 side-by-side
HD72 and Panny 900 side-by-side - Page 4
post #91 of 97
Thanks muncey,
Without stating it in my first post, that's been my top contender for a while.
The rainbow issue isn't something I've determined yet. I'll have to view some setups before making the purchase.
What are my limitations with lens shifts? I guess I don't understand the whole thing... Would I gain anything by having 768 vs. 720? What does that calculate to with my distance/mounting height/screen size? I've played around with some of the screen calculators but don't know that I'm looking at things the right way.
Brian
post #92 of 97
The IN76 doesn't have lens shift, either. It does have some offset though. Have you read:
http://www.projectorcentral.com/info...y_big_in76.htm
The 768 will let you show WXGA or XGA without cropping.
post #93 of 97
Originally Posted by muncey
the hd72 and hc3000 have large offsets and probably wont work well for you.
muncey
What is the minimum ceiling height for the hd72? I also have a ceiling that is a little bit taller than 8'.
post #94 of 97
Brian
muncey
Not true with a 92" screen and 8' ceilings - these projectors will work great for you. The big thing is not wanting to calibrate, which makes the IN76 the best choice with it's accurate factory calibration.
post #95 of 97
You're fine for a screen size 106" or less.
post #96 of 97
Cool.
The calibration thing is more about sticking $500 into a $1500 investment. I'm having a hard time with that idea, whereas my current 32" HD-CRT is completely dialed in with DVE. Don't get me wrong - I totally appreciate a properly calibrated display. I wouldn't consider owning anything without my own "calibration", it's trying to justify the professional job if it's unnecessary by simply buying a different projector that is already "factory set", so to speak... Part of it is not completely understanding what a pro cal offers. What does it tweak that I can't do on my own?
Uatatoka - about where would a HD72 or the Mits put my image - too high or too low?
post #97 of 97
I'm aiming for 120" - my screen is 134". Am I dead in the water?
This thread is locked
