Originally Posted by Artwood
No. LCD blacks are even gray in broad daylight.
That's simply not true with the latest panels that have "true" 1300:1 (not dynamic) contrast ratios.
The latest BRAVIAs (V2000, the European Equiv. of the V2500 coming out in USA in a couple of months) are
totally black in anything other than a pitch-black room.
They're still not quite as good for shadow detail though. (and colour rendition / motion handling isn't even close)
Originally Posted by JohnnyRey
I was going to go with an LCD over a plasma because of burn in, but after doing some research, I don't really think it will be a problem. I'm not sure why anyone would go with an lcd..considering they are so much more money, and simply don't have the PQ that plasmas have.
Am I wrong here?
From what I've seen, it's not an issue with the 9th Gen Panasonic panels. I've heard of a little image retention with the HD panels, but I didn't see any on my ED one after hours of gaming, or having a channel logo in a corner, and that's without having run it in, or turning the settings right down. Apparently once they're run in (1000 hours) you won't even see image retention on the HD ones.
Originally Posted by tvbug
Naaaah
LCD is gonna go the way Sony Betamax did versus the VHS.
Plasma is King and shall rule the kingdom.
But Betamax was better...
I reckon LCD will "win" on the sales, because prices are coming down drastically, and they're getting bigger & better all the time, but I doubt they'll be up there with Plasma for image quality unless they can come up with a good solution to the sample-and-hold effect. (ClearLCD may or may not work - I've not demoed one of those LCDs, but it's only applied to 480i and 576i currently, so it's pointless right now anyway)
Originally Posted by gdog2004
You guys can debate that LCD's dont have great blacks but all I can tell you is the sharp 45"
at costco had blacks on level with the BEST plasma there. The panasonic. The Maxent plasma was very gray and washed out in comparison to the sharp. The Sony Bravia did not look as good as the Costco sharp aquos. Now in some PQ test the panasonic plasma MAY have better blacks.. MAYBE--but barely noticeable during normal viewing. Throw in the fact that there is no burn in with lcd and the resolutions can be greater and lcd seems to be a bit better. Oh and as far as gaming--the sharp has a 6ms response time. No lag there. However I could see why people choose plasma as I have seen many great plasmas--but the sharp and the new samsung are the only really great lcd's Ive seen. The sony bravia was pretty good as well. With larger LCD's becoming more affordable Plasma will die a slow death.
Only in a bright room. Plasma blacks get
worse the brighter the room is, and LCD gets better. This is due to Plasma being a light emitting technology with a big glass panel, and LCD being a light blocking technology with a very anti-reflective matte coating. (the high ambient light basically "cancels out" the LCD backlight)
In a dark room, there's no contest between LCD and Plasma right now, but it's getting closer all the time. LCD just doesn't have the depth to the image plasma has though, regardless of black levels.
