I'm wondering if anyone has had any issues with the heat generated from fireplaces with you lcd/plasmas mounted over the fireplace..?
Is this really a concern w/ the heat generated over fireplaces? I'm looking to mount an lcd/plasma over a fireplace but want to see if this is really going to be an issue.. Seeing as how many people have this done, it shouldn't be, but I just wanted to make sure. Are there any simple things that can be done to help prevent any problems w/ the heat from the fireplace?
Any input is appreciated. Thanks.
