AVS › AVS Forum › Video Components › Home Theater Computers › AutumnWave / OnAir USB HDTV Tuners
AutumnWave / OnAir USB HDTV Tuners - Page 98
post #2911 of 2947
Originally Posted by kiwifatcat View Post
I believe you need to load the Nvidia drivers off of the install disk.
It seems to be working as-is, so I am reluctant to mess with success. I guess if installing something farkles it I could roll back.
do you still have the win7 32 bit drivers?, I was able to locate win7 64bit but not the 32bit, or xp dirivers.
would like to get use out of the GT and can't find the 3.2 p3 drivers now that autumnware is gone.
http://landiss.com/share/OnAir/
post #2912 of 2947
Thank you so much, I have been searching Every site I could find online, and was not able to find these drivers. (everything pointed to the dead Autumnwave site)
post #2913 of 2947
Hello
I know of someone who is going to have an , "Estate Sale", this weekend. The seller has lots of electronics to sell. Among the booty of misc AV stuff, there is an OnAir GT, looks sorta new? Whole lot of stuff for $150.00. Speakers, dvd's & players, lots of vhs tapes, a turntable, I think i saw a receiver or two. All kinds of different computer cards: sound, video and useless modems. and a tangled mess of cables. oh, theres also a couple of old tv's in the mix - again, also useless (unless i put one out in the shop?)
Should I buy this. I don't really have a real need for anything, but I do sort of want a tuner for the 'puter.
Whatcha guys think. Is it wise to still purchase an OnAir GT?
post #2914 of 2947
The OnAir GT is worth $150 by itself, and appears to work fine even in Win 7. (I have only 32-bit, can't tell you for sure about Win 7/64.) Let me know if you find a VHS VCR that can play PAL tapes.
post #2915 of 2947
Well, I picked up all of the stuff, (got there early ) and the GT was in the box and all of the accessories ?
but no CD for anything - no program, no drivers, no manual, etc.
I kept looking online and did not find anything. Everything kept going to a "Closed" Autumnwave, website?
I then looked here and just above this post I saw the "landiss" website posted by Dan in St. Louis - thanks.
But...
Which program do I need to download? I think I have the correct driver figured out?
I have:
  • The OnAir GT
  • XP OS
  • Asus Laptop
Any help would be appreciated.
btw... no luck on a PAL style VCR. Looked like everything was for here in the states?
post #2916 of 2947
It looks like I am using version 3.2.0.4 driver (GT_Drv3204_beta_2008.zip) on a WinXP laptop. I think it is best to use the same version of program and driver.
Next challenge: Has anyone gotten the OnAir GT and TSReader Lite working on Win 7 (32-bit)?
post #2917 of 2947
Partial answer: Using the 320P3 program and 3203 driver, and setting both OnAir and TSReader program compatibilities to WinXP/SP3 and run as administrator; it seems to work. There may be some glitches I have not yet found and the Aero interface goes away while the OnAir viewing program is running (but returns when it is closed). It may turn out to be that some of the above settings may not be necessary, but I will leave that as an exercise for someone else.
post #2918 of 2947
Another interesting experiment would be to try the 03 driver (for TSReader compatibility) with the 04 program (for Aero compatibility). Who is game ?
post #2919 of 2947
It would be great to hear of any recent developments in this area -- that is, affordable DTV tuners with good sensitivity, an external antenna connection, and user-friendly control software.
Thank you!
post #2920 of 2947
was so disappointed that onair is out of business.
haven't had time to read 98 pages. i found this page (http://landiss.com/share/OnAir/) with a bunch of drivers. anybody use these yet? specifically with windows 7.
post #2921 of 2947
http://www.avsforum.com/avs-vb/showt...7#post19824327
post #2922 of 2947
I had no idea they were no longer around!
Anyway I have a new computer and need to install the program, but I have Creater, not GT. Should I install it off of the disc, or try one of the programs at http://landiss.com/share/OnAir/? If so, which one? It's W7 64-bit.
Whoever maintains the link above, thank you!
PS - I went back the thread and saw Dan in SL is the Ryan who had helped me in the past. I didn't see the CR driver initially in the link above, but I installed it. PQ is a little rougher than what I saw with my old computer, but I'll fiddle with it. It's at least running. Thanks again!
post #2923 of 2947
Notti,
You can clean up the video by installing the Nvidia PureVideo code from the CD. With some difficulty, it can also be found on the Nvidia web site, at least it could a year or so ago. You will need a key to enable that software. If I recall correctly, the key was on a sheet of paper that came with the unit. If you previously installed the OnAir code and Nvidia driver, the key should already be on your computer.
Greg
post #2924 of 2947
Originally Posted by gfbuchanan View Post
Notti,
Greg
Thanks for the suggestion, Greg. I think I still have the CD and the code. It looks a lot better today. I guess I had to restart the PC to run it stably. I'll blow it up on my projector to examine the PQ more closely. Thanks again.
post #2925 of 2947
Actually, Ryan was a gentleman in Tech Support at AutumnWave. I'm just a retired teacher in Saint Louis.
post #2926 of 2947
I'm still using mine where my Samsung http://www.avsforum.com/avs-vb/showthread.php?t=728392seems to be done.
post #2927 of 2947
Has anyone found a workaround for this problem?
In Win7 (32-bit), the first time I try to use my OnAir Gt after re-booting, the application freezes. I have to unplug the power cable to the OnAir, use the Task Manager to close the frozen app, and then plug the power cable back in.
I'm hoping for a fix that will let me just leave the OnAir USB cable plugged in and not have to unplug it every time I reboot.
Thank you!
post #2928 of 2947
After installing the latest NVIDIA video drivers (8.17.12.8562), I can now longer decode video from subchannels (audio) on Win 7 64 3204 driver, but after uninstalling those and installing the 3203 and 3202 drivers, I can decode subchannels. One subchannel still comes in messed up with ON GT program but with those drivers but comes in normal on windows media center and on a converter box hooked to a bedroom TV. My video card is Nvidia 560M 2X SLI.
post #2929 of 2947
Thank you, n. We ought to be writing down these quirks and work-arounds since AutumnWave is defunct.
post #2930 of 2947
Anyone installed the the NVIDIA 295.73 drivers?
post #2931 of 2947
Any Windows 8 beta testers here?
post #2932 of 2947
I expect to test Win 8 in the next week or so and will try my OnAir GT as well.
post #2933 of 2947
Any news on that?
post #2934 of 2947
Any news on that?
I'd completely forgotten this post, thanks for reminding me. I got as far as installing and running Win8 for a bit, but didn't get to test my OnAir.
Fact is it didn't take me long to conclude that win8 is completely irrelevant except on tablets (at least the preview, which forces you to use Metro for everything). I was hugely disappointed. I didn't even reinstall it when my hard drive broke a few weeks ago.
I may still get back to it when Microsoft puts out a new version. I cannot imagine they would completely abandon the entire installed base of desktop and laptop users. I am not a Microsoft basher (not much anyway) so I have hopes still ;-)
post #2935 of 2947
Anyone know if this tuner is compatible with win 8 64 bit? Damn, i can't believe this guy is out of business. i wasted $150 on this tuner and now it's unusable... frown.gif
post #2936 of 2947
Can't say I'm surprised the company's out of business. The OnAir was a nice tuner, but grossly overpriced, IMHO. I picked up a used one on ebay several years ago to check it out and sold it after just a few weeks. My V-Box USB-A-3560's are much better at picking up weak stations for a fraction of the cost. In fact, they are much better than the SiliconDust HDHomeRun Dual in this area.
post #2937 of 2947
It works in Win8-x32. I have the software installed on my laptop. I haven't converted my HTPC to Win8 yet, so can't say for sure in regards to x64. My guess is that it works.
I've had good luck with this tuner. I'm sure there may be newer hardware that is better, but it has served me quite well.
post #2938 of 2947
I respectfully disagree.
The OnAir was among the most sensitive tuners available at the time. It received both analog and digital signals, making it equally useful behind a satellite TV box. It accepted composite video and S-VHS formats as well. And, it was powered by the USB cable. Its scheduler was a piece of cake to set up. Well worth the price!
I learned about it from the area-wide engineer for a broadcast chain. He carried it and a laptop. Often he would arrive in a town the night before his scheduled appearance and, with his OnAirGT and TSReader, reviewed the station's parameters from his motel room. When he went to the station the next morning he already knew what needed to be done. Imagine troubleshooting a digital TV station with a laptop and a $150 USB-powered box!
post #2939 of 2947
I never said the OnAir wasn't sensitive. I was comparing my V-Box tuners to the SD HDHR Dual, not the OnAir. I just said the OnAir was grossly overpriced compared to whatever else was available. Granted, I was only comparing digital tuners and not the other features of the OnAir. I got my V-Box tuners used for about $50 apiece vs. $120-150 for a used OnAir GT. The V-Box was every bit as sensitive as the OnAir when I compared them side by side. Both are great tuners, but the V-Box was by far the better bargain if you only needed a digital tuner, IMHO. I was able to purchase six V-Box tuners for about the same price I would have paid for two OnAir GT's.
post #2940 of 2947
Go back and read your message again. Your first three sentences all relate to the OnAir, and then you say "My V-Box USB-A-3560's are much better at picking up weak stations."
Only after that do you mention the SD.
I cannot defend the cost of the OnAirGT if all you need is a digital tuner. For my uses, the inclusion of NTSC and baseband video inputs is vital. I wish I could find a replacement product that does as well.
