Originally Posted by rebkell
Is there any chance the cable is bad, is there any way you can connect the same cable that goes to your tv to the OnAir device,(aka a known working cable and connection, you may be doing that now, but it's not clear in your posts if that is the case or not) I don't get any kind of db reading on ATV, but I do get one on DTV, but as far as the OnAir tuner goes, it should show a good picture if the tv does.
I don't think it's the cable's problem. I used several cables that I did confirm worked with my TV and they just didn't work with the OnAir tuner. While it was searching for DTV channels, I saw the db were around 10 or so. No channels were found. For ATV just a couple of grainy channels.
For you, did you just simply connect the cable to the wall to the same jack that the antenna was connected to and did a channel search?
